Old 07-05-2021, 02:47 PM #46
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
6 month lift report. I’ve put just over 4k miles on, no squeaks, drives is still very smooth. This is a DD, it has seen no serious off road use.
Just took measurements on flat ground and find no settling. Below is before measurement center hub to fender : actual lift achieved - current measurement center hub to fender … current measurement bottom of wheel to fender.
DF 19.5” : +2.25” - 21.75”… 30.625”
PF 19.875” : +2.125” - 22”… 30.875”
DR 21.75” : + 1.25” - 23”… 32”
PR 21.75” : + 1.25” - 23”… 32”
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 11:43 AM #47
donkability's Avatar
donkability donkability is offline
donkability is on a distinguished road
I will be doing this 6112/5160 soon waiting on back order, Im in the process of picking out new wheels and tires, stuck on the tire size, 265, 275, or 285 ??? thinking on going method 701 and bfg / ko2. SOS
donkability is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 12:40 PM #48
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
I'm on the list with my local shop for your exact setup; no clue when it will come in but I'll keep the thread updated. I've bounced around to various different lift ideas but a small lift via 6112/5160's seems to be the most viable for me.
91foxbody is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 01:07 PM #49
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Also checkout KMC's Bully OL or Impact OL (Made in USA). Have the same tech as Method Trail Series for keeping bead on at low pressure.
Go with 285/70R17's; lots of tire brand/tread choices (Kenda AT2's are awesome and have 50K mi warranty), minimal to no trimming required (for 0mm offset, more if you go wider or spacers).
dezertbomber is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 01:13 PM #50
attackmac attackmac is offline
Real Name: Mac
attackmac is on a distinguished road
Real Name: Mac
5100
Originally Posted by Chop311 View Post
i have the 5100s for up front. hoping the 1.75 notch is enough up front to pair with the 1" b12s and 5160s
Hi I was just wondering if you actually finished this build. I already got my 5100s for the front and I set them to the .85. Really close to level but I'm looking to go a little higher in the front in rear. Do you know if 5100 in the front (1.75 setting) and b12 1.5" in the rear is close to level or is there still a rake?
attackmac is offline   Reply With QuoteReply With Quote
Old 07-17-2022, 11:28 PM #51
GAsr5 GAsr5 is offline
GAsr5 has a little shameless behaviour in the past
Bump for this
GAsr5 is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 01:10 PM #52
krish422 krish422 is offline
krish422 is on a distinguished road
Front Bilstein 6112(650lb springs) - set at 6th clip on both sides
Rear - 5160 & B12 springs(36-281824)
Hub to fender measurements
DF - 24
PF - 25
DR - 23.75
PR - 24.25
I am planning to adjust clip settings to #5 on driver and #3 on front and decrease the front lift height by an inch. I will post the measurements after adjustment.
Rago hidden winch mount
Warn winch
RCI full skid plate setup
Victory 4x4 roof rack
krish422 is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 05:06 PM #53
EDC4rnr EDC4rnr is offline
EDC4rnr is on a distinguished road
I got around 24” (hub to fender) in rear with the bilstein B12-36281824 and one ome trim spacer on drivers rear. This is with a full tank and sliders. It’s nice to see others getting the same amount of lift as advertised.
EDC4rnr is offline   Reply With QuoteReply With Quote
additional , front , lift , weight , winch
Bilstein 6112/5160 Rear Springs Question MK_Ultra 5th gen T4Rs 11 06-20-2018 01:22 PM
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
FS: Bilstein 6112 / 5160 Susp. For 5th Gen (SF, CA) - $650 Xtremluck For Sale: Suspension/Wheels/Tires 3 12-08-2017 05:03 PM
Bilstein 6112/5160 vs Fox 2.0 - ??? fifthcircle 5th gen T4Rs 48 11-08-2017 09:24 PM
FS: Bilstein 6112/5160 RockyRider For Sale: Suspension/Wheels/Tires 7 12-31-2016 02:43 PM
