Old 03-04-2020, 11:44 AM #16
BarrRunner's Avatar
BarrRunner BarrRunner is offline
BarrRunner is on a distinguished road
BarrRunner's Avatar
Originally Posted by Sauss View Post
I wanted to bump this thread to ask a question. I just bought the 6112/5160 setup. I’m going between the 1.2” and 1.6” setting for the front. If I do the 1.6” setting, will I need the B12 1” coil springs to keep the slight forward rake? I have a 2018 SR5 4wd non KDSS. If anyone has a done this setup or have another rear spring idea to get the 1.6” lift in the front do you mind sharing some pictures? Thanks in advance. I’m also planning on KO2 tires but torn between 265 vs 275.
I did the 2" setting (6/4 for non-kdss), and used the Eibach 1" in the rear. Sits pretty level with 275 ko2.
Bilstein 6112/5160 + B12 Springs-pic-jpg
2019 TRD OR, Kings, JBA UCA, SCS Stealth 6, 285/70/17 Ko2
BarrRunner is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 01:21 PM #17
Sauss Sauss is offline
Sauss is on a distinguished road
Originally Posted by safdSA View Post
Just had 6112/5160 installed yesterday! I stuck with Bilstein springs. Love the ride. Night and day over stock.
That looks awesome. a couple questions for you:
1) what setting did you use for the front? 1.6" or 2"
2) which Bilstein springs did you use - 1" or 1.5"
3) are you running 265 size tires?
thanks for sharing.
Sauss is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 01:22 PM #18
your truck looks clean. i think 2" is too high for what i need. so if i did the 5/3 setting for non-kdss, then do you think ill get significant forward rake with the 1" rear springs?
Old 03-04-2020, 01:39 PM #19
BarrRunner's Avatar
BarrRunner's Avatar
Maybe a little bit of rake with that setup, if you can live with it I say go for it. You could instead do a 1/2" spacer in the rear
Old 03-04-2020, 01:40 PM #20
safdSA safdSA is offline
safdSA is on a distinguished road
All good questions!....but I don't know! I'll call the shop and ask. I told them I just wanted 2.5-ish of lift and they set it up.
Tires are 255/75, just to be different
thanks for sharing.
safdSA is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 12:47 PM #21
aznxpsyko aznxpsyko is offline
aznxpsyko is on a distinguished road
How are you guys adjusting the clips on the 6112? Are you removing the entire assembly from the vehicle? I have mine set for 2.4", but it is still not leveled with my rears with 5112 & icon 2" springs. Looking to bump the fronts a notch higher, but don't want to go through the pain of reassembling since I have KDSS
aznxpsyko is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 07:16 PM #22
doubt you can compress the spring while mounted on the truck. Just pull them off and have a shop compress them and move the clip up. its worth the hassle for that extra lift. i'm on top setting, with KDSS and DirtKing uppers. Drives amazing.
Old 04-13-2020, 10:13 PM #23
esteban008 esteban008 is offline
esteban008 is on a distinguished road
Thought I'd add to the thread... Installed 6112s(6th circlip)/5160s with B12 1.5" springs in the rear on my 2016 Trail Edition (w/KDSS). Gained ~2.5" up front and ~1.25" in the rear. I initially installed the 1" B12 rear springs (only gave ~3/4" lift), and wanted a little more so I swapped them out for the 1.5".
Bilstein 6112/5160 + B12 Springs-4runner_t4r-jpg
esteban008 is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 03:03 PM #24
s13vlad s13vlad is offline
s13vlad is on a distinguished road
Question for people running Bilstein 6112's! I just got mine in today and the instructions say that the 5/3 settings give 1.6 inches of lift, and the 6/4 give 2 inches. This is different from before where where they said 5/4 gives 1.85 which is what I intended to do... Has anyone installed it recently, and if so, what did you go with? Did the 6/4 actually give you 2 inches on a non KDSS model, or was it more? I tried to call them to ask what has changed to have them tell you to go 2 clips lower on one side, versus 1 before, and he basically told me he had no idea...
s13vlad is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 09:51 PM #25
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
It all depends.
With 600lb springs and the 1.2 setting (4/2) I got more like the 0.8" setting with just 3/16 steel skids and sliders. With the 650lb springs and everything else the same, I am getting a bit more than 1.2" in the front.
I personally replaced the springs because the 600lb is too soft with the 6112 for any serious desert use.
Old 06-25-2020, 11:41 PM #26
From your experience, is the 2 inch option actually 2? I'm trying to avoid having to get UCAs for now as well and maintain MPG's, not sure how much lifting will impact it tho really, especially if im raising the back too so its not level. I also ordered the wheels t13 rear springs which are stated to give 1.5, but others have said 1.25 is what it really does. I read through some of your posts to see stuff you said about having the same setup, which was help. Ive also been torn on the 1 or 1.5 rear springs..... I want to keep it simple and avoid having to get UCAs for now, so I dont want to lift it too much. I also want to have some rake to keep it how Toyota intended, and also when I row my time attack car. My experience is also from the racing world where springs have nothing to do with height, because you adjust it all at the coilover.... so this has been a bit different since you end up preloading the spring and get that height, versus picking the spring rate you want and adjust height separately...
What is your 2 cents for someone in my shoes? Do the 1.6 setting and get a 1 inch spring? Go for 2 and stick with 1.5 rear spring? My logic initially was even if i do 1,6 in the front and get a 1,5 rear spring, it will retain what is stock. However, the TRD Pro is an incher higher in the stoc to begin with, so its really not a big deal going 1 or 1.5 even with the front raised 1.6 inches. I have the springs ordered as of an hour ago, but can always call in the morning to try to have them send me different ones, I suppose.
I've been going back and forth a lot on what to do here, so input is welcome...
Old 06-26-2020, 08:45 AM #27
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Here is what I did, if it helps at all. The rear spring guess work can drive you nuts. It is compounded for me since I tow and have a RTT in the summer.
The height adjustable rear springs from Eibach were my solution. I bought the medium version for 250 lb load. I installed them first at the lowest setting and measured the difference front to back. (No tent)
I already had my 6112 assemblies on clip #4 (KDSS) for 2”. I have read and heard the more preload the harsher the ride with these, so instead of having to disassemble I bought a 1/2” spacer. (1” lift) After measuring I decide to use it to get a 3” lift. VERY tight fit BTW.
The front was crazy high. Ran it up and down the bump in my driveway a dozen times and it settled. More around 2.75 of lift in the end.
This gave me 1/2” of rake, which looked great but..
Then I put my RTT on and the trailer, negative 1/2” rake.
No biggie since I had adjustable springs that can go up another 2.5”. It does require lifting the back to lessen spring tension and removing the tires. Now I am around 1/2-3/4” rake loaded up. MUCH easier adjustment than pulling the 6112s. Pricier...yes, worth it for me...YES!!
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 01:34 AM #28
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
I have a 2021 TRD ORP, no KDSS, no 3rd row, only added weight is Sliders. This is a daily driver.
On order is 6112 (600 lb springs) & 5100’s and 1” Bilstein B12 (BIL-36-281817) rear coils.
From reports I’ve read, I’m planning on setting Circlip to #5/3 for 1.6 up front to lift/level PLUS expecting @ 3/4-1” in rear from B12’s.
I hope to end with a small lift, maintain 1” rake, easily maintain factory alignment, and run A/T 265/275’s.
Anyone have feedback on actual lift obtained with 6112 front setting at 1.6” vs 2”?
Anyone have actual lift measurements from this 1” coil?
I want to get this ‘right’ the first time and avoid a reverse rake at all cost. Thanks in advance for your feedback.
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 09:06 PM #29
Completed install and reporting back in the event it helps someone else. There are conflicting reports of actual lift achieved with different circleclip settings. I almost went with 1.6” setting based on reports of getting more than expected. I ended up choosing 6/4 for 2” and glad I did.
** 2 days and a few miles of settling in, I’m very pleased with the result. Front lean leveled perfectly and ended up 2” up front and 1.125” in the rear. Below are specs and parts used:
Front- Bilstein 6112 set at circle clip 6/4 for 2” on non-KDSS
Rear- Bilstein 5100 and Bilstein 1” coils
Measurements, taken from base of rim to wheel well, full tank.
Before:
DF- 28.625”
PF- 29”
DR- 30.875”
PR- 31”
After:
DF- 31” (+ 2.375”)
PF- 31” (+2”)
DR- 32.125” (+1.25”)
PR- 32.125” (+1.125”)
Bilstein 6112/5160 + B12 Springs-26d4033a-e904-4d68-8da6-eb897b4084b2-jpg  Bilstein 6112/5160 + B12 Springs-bf34d4da-c4ee-4f5d-9125-afb3b8ba355f-jpg
Old 01-21-2021, 02:38 PM #30
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
So you ended up getting 1.25'' lift in the rear with the 1'' coils? Interesting.
91foxbody is offline   Reply With QuoteReply With Quote
additional , front , lift , weight , winch
Bilstein 6112/5160 Rear Springs Question MK_Ultra 5th gen T4Rs 11 06-20-2018 01:22 PM
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
FS: Bilstein 6112 / 5160 Susp. For 5th Gen (SF, CA) - $650 Xtremluck For Sale: Suspension/Wheels/Tires 3 12-08-2017 05:03 PM
Bilstein 6112/5160 vs Fox 2.0 - ??? fifthcircle 5th gen T4Rs 48 11-08-2017 09:24 PM
FS: Bilstein 6112/5160 RockyRider For Sale: Suspension/Wheels/Tires 7 12-31-2016 02:43 PM
