Old 01-21-2021, 11:57 PM #31
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
Originally Posted by 91foxbody View Post
So you ended up getting 1.25'' lift in the rear with the 1'' coils? Interesting.
Correct, 1.25” with B12’s in the rear. I will report back after a few weeks should things settle further after more time and miles.
Installed 17x7” TRD wheels with stock 265 sized Falken WP AT3 in SL. These tires compliment the Bilstein ride. Very happy with the result so far.
Bilstein 6112/5160 + B12 Springs-f83c5e9b-b298-41de-b8b5-4741573cbb9e-jpg
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 12:15 AM #32
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by MAST4R View Post
It all depends.
With 600lb springs and the 1.2 setting (4/2) I got more like the 0.8" setting with just 3/16 steel skids and sliders. With the 650lb springs and everything else the same, I am getting a bit more than 1.2" in the front.
I personally replaced the springs because the 600lb is too soft with the 6112 for any serious desert use.
So that is the correct way of putting it, which I did not know until yesterday.
The spring is NOT 600lb. The spring is much softer than that while the valving is stronger. This explains the puzzling behavior in extreme for suspensions terrain (where the front felt many times it would bottom out but did not at the last moment as the shock prevented it).
It also better explains why offroad comfort is superb on the standard springs.
(no complaints on 650lb, it is good but it is not plush)
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 01-22-2021, 12:46 PM #33
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
Looks great, thanks for sharing! So your total lift in front was 2.0-2.5'' and rear was ~1.25''? Looks like there is still about 1'' of rake. Did it align alright without UCA?
91foxbody is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 12:40 AM #34
Glad to help. Yes, Bilstein 2” setting of 6/4 compensated for drivers side lean perfectly. Lifted 2” on passenger side and brought drivers side up 2.375” to level.
Stock UCA’s- My alignment tech got caster to 2.9 on both sides. All is within spec and drives great.
Old 01-23-2021, 01:08 AM #35
You’re the man, thanks for the follow up! If you ever come up to PDX I owe you a beer or three.
Old 01-23-2021, 10:56 PM #36
Chop311 Chop311 is offline
Chop311 is on a distinguished road
i have the 5100s for up front. hoping the 1.75 notch is enough up front to pair with the 1" b12s and 5160s
Chop311 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 02:08 PM #37
JSBTRD JSBTRD is offline
JSBTRD is on a distinguished road
6112 with 5150 rear and original rear springs
Looking for input from the thread... recently upgraded my suspension from factory stock to: Bilstein 6112's at 1.2" (4/2) setting in front and Bilstein 5160 in the rear but left the factory stock springs untouched. Both front and back level at 21.5" center of wheel to fender, but it seems that the truck tends to have a reverse rake at times, especially when 100 to 200lbs are added, or the truck sits on an incline. I'm considering upgrading the rear springs to Bilstein B12's to get an extra 3/4" to 1" in the rear, for just a slight forward rake and I figure the B12's are better able to support the occasional 100-200lbs vs factory springs, when adding weight without having a reverse rake.
Anyone have any similar experience and how did you correct any reverse rake?
Thanks!
2018 TRD Off Road Premium - Non KDSS
Bilstein 6112/5160 + B12 Springs-dsc_0083-jpg
JSBTRD is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 03:39 PM #38
Mr_Bingley Mr_Bingley is offline
Mr_Bingley will become famous soon enough
Completed install and reporting back in the event it helps someone else. There are conflicting reports of actual lift achieved with different circleclip settings. I almost went with 1.6” setting based on reports of getting more than expected. I ended up choosing 6/4 for 2” and glad I did.
** 2 days and a few miles of settling in, I’m very pleased with the result. Front lean leveled perfectly and ended up 2” up front and 1.125” in the rear. Below are specs and parts used:
Front- Bilstein 6112 set at circle clip 6/4 for 2” on non-KDSS
Rear- Bilstein 5100 and Bilstein 1” coils
Measurements, taken from base of rim to wheel well, full tank.
Before:
DF- 28.625”
PF- 29”
DR- 30.875”
PR- 31”
After:
DF- 31” (+ 2.375”)
PF- 31” (+2”)
DR- 32.125” (+1.25”)
PR- 32.125” (+1.125”)
Looks great! what was the rough cost for this, since you saved a good amount by not getting the KDSS?
Mr_Bingley is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 01:30 AM #39
Thanks!
Sounds like you potentially got more than 1.2”. Recommend that you measure ground to frame behind front tires and in front of rears. I also suggest bottom of wheel to fender (as finding center of hub can be difficult to get an accurate reading).
Those measurements will help you find true rake under different loads. From there, you can consider rear spring and/or different setting up front.
Old 01-27-2021, 01:36 AM #40
6112- $750
5100- $200
B12- $200
I ended up buying from 3 different companies to avoid lengthy back order wait times.
I had Ironman lift with UCA on my 2020. It was good, but this Bilstein setup is a much more accurate result and I like the ride better for a DD.
Old 02-09-2021, 02:17 PM #41
dullallday dullallday is offline
dullallday is on a distinguished road
Where did you get the 6112s from? I've been waiting for mine since November.
dullallday is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 12:26 AM #42
I had the same thing happen- cancelled that order. Called around and found them in stock at Caliraised Off-road. Purchased over phone and shipped same day. Great experience, will buy from them again.
Old 02-22-2021, 11:24 PM #43
Clintorious801 Clintorious801 is offline
Clintorious801 is on a distinguished road
Has anyone ran the heavy duty 6112s without added weight? I plan on doing front bumper/winch soon just thought I'd ask if it would be too stiff without the weight. Thanks for any input.
Clintorious801 is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 12:38 PM #44
Toyotaro Toyotaro is offline
Toyotaro is on a distinguished road
I'm in the same boat. I got 6112s with 650lbs springs and I'm still waiting for full skid, slider, slim front bumper. It's going to take a while. Curious to know how is the ride quality without extra weight....
Toyotaro is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 11:39 AM #45
The 600 lb coils ride smooth, almost factory ride without as much diving around corners and while braking. Many kits from King, Icon, Ironman, etc come paired with heavier 650 lb coils. I would think the ride will be a touch more firm but very drivable and less squatting under weight. I wouldn’t change it now, but would happily change out mine to 650’s with no weight, FWIW.
additional , front , lift , weight , winch
Bilstein 6112/5160 Rear Springs Question MK_Ultra 5th gen T4Rs 11 06-20-2018 01:22 PM
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
FS: Bilstein 6112 / 5160 Susp. For 5th Gen (SF, CA) - $650 Xtremluck For Sale: Suspension/Wheels/Tires 3 12-08-2017 05:03 PM
Bilstein 6112/5160 vs Fox 2.0 - ??? fifthcircle 5th gen T4Rs 48 11-08-2017 09:24 PM
FS: Bilstein 6112/5160 RockyRider For Sale: Suspension/Wheels/Tires 7 12-31-2016 02:43 PM
