Old 10-07-2019, 09:30 PM #1
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Does break in matter?
New owner 2020 4wd 4 runner sr5 premium. Im the only one that test drove it. Had plastics everywhere not even prepped for.showroom that new. Windshield full of plastics and labels.
Anyways when i got my new 2018 yfz450r se quad I broke it in HARD i made sure to giver hell without hitting rev limiter first 5 hours and oil changed it and all is good. On motorcycles i am a real believer to giver hell off the showroom floor after a good warmup never had issues over the years...
On my new 4 runner it only has 76 miles after test drive and after some city trips. It had 11 miles when i test drove it.
Should i stomp on it a little to maker scream a little. Ive been easy on the 4 runner and a little get on it just a little. The first 4nrunner i ever test drove another one i gaver hell LOL !! With filipino older sales guy hanging on. LOL funny stuff.
I hope i dont start a pissing contest.
Take it easy first 300 miles or get on it once in a while?
  Reply With QuoteReply With Quote
Old 10-07-2019, 09:34 PM #2
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Putting shifter to left of D does it just lock no higher than 4th gear or holds gears longer too kinda sport mode?
If in 5th and move shifter to left will it downshift to 4th and stress engine tranny high rev it?
Can i put it in left the S while driving?
Old 10-07-2019, 09:38 PM #3
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Anxious to tow my trailer and quad. Any harm before the 500 mile book recommendation?
Old 10-07-2019, 09:45 PM #4
DenverTiger504's Avatar
DenverTiger504 DenverTiger504 is offline
DenverTiger504 is on a distinguished road
Personally, with a new truck like that I would stick with just in D and see how it performs. I would drive it as you normally do and it will break in your driving habits overtime. Enjoy the new truck.
2016 Trail | KDSS | Bilstein 6112 2.7” | Eibach Pro-Truck Rear Shocks and 1” Springs | 285/70/17 BFG KO2 | SPC UCAs
DenverTiger504 is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 09:50 PM #5
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
Give her hell!
I'm also in the giver-her-hell camp, and a former auto and heavy equipment tech. I usually drive normally for the first 200 miles or so. Then I find a little-traveled road or new neighborhood street with no houses built yet and break in the brakes first.
45 mph to 5 mph gently 3 times, then 45 to 5 moderately 3 times, then 50 to 5 abruptly 3 times, and back up to road speed to cool off.
Then, proceed to work up to full throttle blasts in forward and reverse. Shift to 4Hi, do the same. 4Lo, same. Get everything good and hot. You want gear faces front and back, rings, bearings, everything to experience load and initial wear.
Drive normally for another 1800 miles, change oil and filter. I drive my vehicles for decades and the drivelines never give any trouble. It's always ball joints or electrical gremlins.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 09:52 PM #6
Putting the shifter to the left will hold the upshift until you nearly the hit the rev limiter, then the computer shifts it anyways. Downshifts are normal upon braking. If you pull the shifter back to downshift, the computer will only let it downshift in an acceptable RPM range that won't blow the engine, and it will beep at you until the RPM comes down enough.
Old 10-07-2019, 10:28 PM #7
57HotrodVW's Avatar
57HotrodVW 57HotrodVW is offline
Real Name: Eric
57HotrodVW will become famous soon enough 57HotrodVW will become famous soon enough
57HotrodVW's Avatar
Real Name: Eric
From the "Breaking in your new Toyota" section of the owner's manual:
"To extend the life of the vehicle, observing the following precautions is recommended:
  • For the first 200 miles - Avoid sudden stops.
  • For the first 500 miles - Do not tow a trailer
  • For the first 1000 miles - Do not drive at extremely high speeds
  • Avoid sudden acceleration
  • Do not drive continuously in the low gears
  • Do not drive at a constant speed for extended periods"
57HotrodVW is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 10:56 PM #8
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Every performance car I had was "drive it hard" from the get go. As long as you're varying rpms and not redlining, do what you want. Also, 11 miles means it was test driven by others regardless of all the plastics being on it. Every 4R I got to check out had literally 1 mile on the odometer.
pointman is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 07:20 AM #9
ryan87 ryan87 is offline
ryan87 is on a distinguished road
I would drive it normal with varying rpm but wouldnt tow for 500 to 1000 miles for the sake of the R&P. based on gear swaps, I have never bought a new vehicle (next year hopefully)
2012 TE
ryan87 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 07:38 AM #10
Maingear Maingear is offline
Maingear is on a distinguished road
old materials and enginering techniques would leave you with glazed cylinder walls and piston rings that dont seat if the engine was babied.
New tech has computers that learn how to respond to your needs. Dont give the software false impressions, drive it like you drive it. Code in the ECU is there to prevent damage.
2013 T4R SR5 stock 200,000 mile club
Maingear is offline   Reply With QuoteReply With Quote
drove , hell , miles , runner , test
Icy roads: AWD vs 4WD? Does it matter? Supermoney 3rd gen T4Rs 9 12-12-2016 03:04 PM
Does it matter if I get a 4x4 for not?? MadxMan 4th Gen T4Rs 36 09-18-2016 10:16 PM
New to T4R and SUVs for that matter AKUMA03 New Members 4 05-04-2011 03:48 PM
hard break during 'break in' phase Fareastplaza 5th gen T4Rs 3 04-05-2011 12:16 PM
