Old 10-08-2019, 01:13 AM #1
mrfobbyaccent mrfobbyaccent is offline
mrfobbyaccent will become famous soon enough
Anyone experience clicking noise from the front end?
Hi Everyone,
I have a 2012 4runner with 95K miles on the odometer. I was backing out of my driveway today and I heard a loud clicking noise while turning towards the passenger side.
Has anyone ever experienced any clicking noises from the front end of their 5th gen? I know it's definitely not my CV axles, as that was one of the first topics that showed up during my search. I'm really hoping it's not my steering rack and hopefully just a small suspension component.
I recorded a video, but the click is to distorted due to all the white noise. Also, you can only hear it if you have the windows down. It's dead silent with the windows up.
Notes: The click is very distinct and only happens once when turning. It's not a constant clicking like a destroyed CV axle. It also occurs shortly after one full turn of the steering wheel. It only happens on driveways, and it's perfectly fine going in reverse on flat surfaces.
Thanks everyone!
RoyalOrigin
mrfobbyaccent is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 09:09 AM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
That sounds exactly like a bad CV (Clicking only when turning).
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 10:33 AM #3
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
If it’s only clicking once, might be brake pad shift. However, is it clicking on the turning part or on the stopping while tuning? Also when was the last service of the driveshaft?
The turning may be unrelated except to open up the area allowing you to hear the click better.
Stock UCA?
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 12:00 PM #4
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
Yep, very intermittent, almost sounds like a loose bolt , that I can't find.
zonzin is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 01:29 PM #5
Stock UCA?
Thanks for the feedback.
I am pressing on the breaks when backing up. I'll look into the brake pad shift.
What kind of service do you perform on the driveshaft? I grease the u-joints every 20K. Should I be aware of any other services?
No, I'm running a icon uni ball UCA, which I use Dry PTFE on every time I wash the rig.
It sounds more like a loose bolt not sitting flush to the mount, which in turn is rubbing against a surface which then makes a click noise. (If that makes sense)
RoyalOrigin
Old 10-08-2019, 02:50 PM #6
Jarheadoo7's Avatar
Jarheadoo7's Avatar
80% it’s the UCA iniball. I had those they are garbage. 30k in Ohio weather and it was garbage. I switched to delta joint. Now all I hear is the squishy of the UCA bushings.
How many miles on the uniballs, where do you live (salted roads?)
Old 10-09-2019, 01:13 AM #7
I live in southern california so salt isn't an issue. I have about 25K on the uni ball joints. They could be the noise, but typically the noises i've heard about with the uni ball joints are multiple clicks or the squishy bushings. It maybe time to rebuild the coils and uniball.
This is a very distinct click only occurring in reverse going down an angle. I am going to bring it to my local shop to get checked out.
RoyalOrigin
Old 11-23-2020, 12:03 PM #8
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Did you ever find the cause? I have this noise and am leaning toward the pad shift diagnosis.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 03:25 PM #9
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Check your LCA mounting bolt torque.
delloro is offline   Reply With QuoteReply With Quote
clicking , noise , steering , turning , windows
Clicking noise front passenger hambone575 4th Gen T4Rs 2 07-10-2018 07:07 AM
PUZZLER - Clicking noise from the front passenger side GO_USN 5th gen T4Rs 25 05-08-2016 09:32 AM
Front suspension clicking noise? What else should I replace at 135k? Strider 4th Gen T4Rs 4 06-14-2015 04:17 PM
Mysterious Clicking Noise From Front Breaks MLeggett 4th Gen T4Rs 19 01-28-2015 10:35 PM
front wheel clicking noise at extreme turns (sometimes) pyrodork Classic T4Rs 9 04-07-2005 03:49 AM
