Old 10-08-2019, 10:54 AM #1
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Dash cam add a fuse? Which fuse to use?
Guys like the title says, I have a new Street guardian dash cam I am going to hardwire in. I have a micro fuse kit, with a few add a fuses. Question on the fuse box, I want something that is only live while motor is running. Likely Ill put a 10amp fuse for the camera as its low amps. Whats the best terminal to splice into? Want to make sure I dont steal any juice from anything that hits high amps on start up (then dips upon normal running). Any ideas?
Thanks
Grug556 is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 04:01 PM #2
DigitalRJH DigitalRJH is offline
DigitalRJH will become famous soon enough
Try the INJ under hood fuse, or just use a blank in the in cabin fuse box.
DigitalRJH is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 04:24 PM #3
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
I have a garmin with the parking mode cable. It requires a constant source, and and ignition source of power. Here's what I used for both:
I posted many more photos on a thread, but I'll be damned if I can find it right now. Sorry.
FWIW, the micro fuses have little indentations where you can touch them with a multimeter probe, and use the screw post at the fuse panel as a ground. You can quickly find the difference between ACC power and BATT power at the fuse panel
Dash cam add a fuse? Which fuse to use?-3-10-2018-10-17-28-am-jpg
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 04:38 PM #4
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Use this blank
Old 10-09-2019, 01:37 PM #5
Grug556's Avatar
Grug556's Avatar
I ended up using IGN 10AMP. Is this a bad spot or ok to use? Has power only when truck is on. Dead when off. I have two ten amp fuses.
Ok? Or problems cutting in with an add a fuse to the IGN?
Old 10-09-2019, 02:09 PM #6
Real Name: Chris
Real Name: Chris
That should be fine, the one I posted above is an empty circuit that's only on with ACC so you wouldn't have to worry about impacting any other fuses
Old 05-17-2020, 11:24 PM #7
COGoalie COGoalie is offline
COGoalie is on a distinguished road
Updated fuse panel for 2020 Venture w/o KDSS
Just bought first 4 Runner and trying to wire in dash cam similar to original poster. I need a constant on and one to be ignition controlled.
I was going to use the empty fuses described in replies but my fuse panel is different. Attached is photo of it.
My 4 Runner doesn't have KDSS, so I was thinking of taping that circuit. That is ignition controlled I believe.
Any suggestions for an always on one to use? Is there another that "looks used" but isn't based of vehicle options?
Thanks.
Dash cam add a fuse? Which fuse to use?-screen-shot-2020-05-17-9-21-24-pm-jpg
COGoalie is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 06:23 PM #8
caw4runner caw4runner is offline
caw4runner is on a distinguished road
I used the KDSS
I used the KDSS fuse location and so far my fuse tap kit seems to be working ok.
caw4runner is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 01:05 AM #9
jd_old_n07 jd_old_n07 is offline
jd_old_n07 is on a distinguished road
Thanks.
What fuse did you end up using for the "always on"? Dealing with the same issue right now as well on my 2020 ORP. Thanks!
jd_old_n07 is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 10:06 PM #10
jinta's Avatar
jinta jinta is offline
jinta is on a distinguished road
jinta's Avatar
I recently added a dash cam. I ended up using the obd fuse because it's always hot
jinta is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 09:31 PM #11
Ellivron Ellivron is offline
Ellivron is on a distinguished road
Did you figure out your fuses for it?
Ellivron is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 09:42 PM #12
nm_t4r nm_t4r is offline
nm_t4r is on a distinguished road
Viofo A129 Duo+ - I used the blank (ACC power) under the TOWING BKUP with a 10 amp fuse to power my dash cam and switch bank. I also ran the dual power and ground to my RTMR fuse box for constant power forPparking Mode.
nm_t4r is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 11:40 PM #13
Figured out my issue. I was using the ACC fuse for ACC+ cable, too direct for that to work properly. I had to turn on Accessory power first (two push start presses) and then start it.
I ended up using the P/OUTLET 15A for ACC+, P/SEAT F/L 30A for BATT+ and it's all working now.
Old 04-16-2023, 12:22 PM #14
DuDuq DuDuq is offline
DuDuq is on a distinguished road
For reference
On a 2022 trd pro i ended up using the kdss for the ignition(non equipped kdss) and an open slot for battery power in the same column.
DuDuq is offline   Reply With QuoteReply With Quote
amps , cam , dash , fuse , running
LED grille lights - Add a fuse using the tail light / side marker fuse DigitalRJH 5th gen T4Rs 8 03-19-2019 04:44 PM
FS: Blue Seas 5026 Fuse Block and ANL Fuse, $30 shipped, Sterling, VA svana For Sale: Non-T4R Items 0 02-18-2019 11:12 PM
Using blank fuse slots on factory fuse block to create new circuits 4runnerlaw 5th gen T4Rs 3 08-31-2017 11:05 AM
Brand New Pre-wired Bussmann RTMR Fuse Block and 80A Fuse cutty01 For Sale: T4R Items 3 04-15-2016 10:27 PM
Help! Blew a Fuse for Radio/Cigarette Lighter, where is fuse? 4Running Daily 3rd gen T4Rs 4 09-09-2012 02:40 PM
