10-08-2019, 10:54 AM
Dash cam add a fuse? Which fuse to use?
Guys like the title says, I have a new Street guardian dash cam I am going to hardwire in. I have a micro fuse kit, with a few add a fuses. Question on the fuse box, I want something that is only live while motor is running. Likely Ill put a 10amp fuse for the camera as its low amps. Whats the best terminal to splice into? Want to make sure I dont steal any juice from anything that hits high amps on start up (then dips upon normal running). Any ideas?
Thanks
10-08-2019, 04:01 PM
Try the INJ under hood fuse, or just use a blank in the in cabin fuse box.
10-08-2019, 04:24 PM
I have a garmin with the parking mode cable. It requires a constant source, and and ignition source of power. Here's what I used for both:
I posted many more photos on a thread, but I'll be damned if I can find it right now. Sorry.
FWIW, the micro fuses have little indentations where you can touch them with a multimeter probe, and use the screw post at the fuse panel as a ground. You can quickly find the difference between ACC power and BATT power at the fuse panel
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
10-08-2019, 04:38 PM
Real Name: Chris
Real Name: Chris
Use this blank
10-09-2019, 01:37 PM
I ended up using IGN 10AMP. Is this a bad spot or ok to use? Has power only when truck is on. Dead when off. I have two ten amp fuses.
Ok? Or problems cutting in with an add a fuse to the IGN?
10-09-2019, 02:09 PM
Real Name: Chris
Real Name: Chris
That should be fine, the one I posted above is an empty circuit that's only on with ACC so you wouldn't have to worry about impacting any other fuses
05-17-2020, 11:24 PM
Updated fuse panel for 2020 Venture w/o KDSS
Just bought first 4 Runner and trying to wire in dash cam similar to original poster. I need a constant on and one to be ignition controlled.
I was going to use the empty fuses described in replies but my fuse panel is different. Attached is photo of it.
My 4 Runner doesn't have KDSS, so I was thinking of taping that circuit. That is ignition controlled I believe.
Any suggestions for an always on one to use? Is there another that "looks used" but isn't based of vehicle options?
Thanks.
03-06-2021, 06:23 PM
I used the KDSS
I used the KDSS fuse location and so far my fuse tap kit seems to be working ok.
03-11-2021, 01:05 AM
Thanks.
What fuse did you end up using for the "always on"? Dealing with the same issue right now as well on my 2020 ORP. Thanks!
03-11-2021, 10:06 PM
I recently added a dash cam. I ended up using the obd fuse because it's always hot
03-16-2021, 09:31 PM
Did you figure out your fuses for it?
03-16-2021, 09:42 PM
Viofo A129 Duo+ - I used the blank (ACC power) under the TOWING BKUP with a 10 amp fuse to power my dash cam and switch bank. I also ran the dual power and ground to my RTMR fuse box for constant power forPparking Mode.
03-17-2021, 11:40 PM
Figured out my issue. I was using the ACC fuse for ACC+ cable, too direct for that to work properly. I had to turn on Accessory power first (two push start presses) and then start it.
I ended up using the P/OUTLET 15A for ACC+, P/SEAT F/L 30A for BATT+ and it's all working now.
04-16-2023, 12:22 PM
For reference
On a 2022 trd pro i ended up using the kdss for the ignition(non equipped kdss) and an open slot for battery power in the same column.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
