Old 12-26-2021, 03:11 PM #1
Naylor99 Naylor99 is offline
Naylor99 is on a distinguished road
Sony XAV-AX8100 Head Unit upgrade
I just ordered this as a bundle from Trail Grid Pro. My only real unhappiness with my 4Runner is the entertainment screen. The screen itself is tiny, and the lack of Apple Car Play is annoying. (I've gotten used to having it in my Corvette, and miss it when driving the T4R.)
Anyone done this?
Sony XAV-AX8100 Plug & Play Bundle | '10 - '19 4Runner
2018 Limited 4x4, Magnetic Gray/Redwood FN 17" Type X, Mich Defender 265.70.17, LED upgrades (XD Low Beams, DD Turn as Tail, DD Switchbacks, LEDs inside and out), Bully Step, N-FAB Nerf Steps, Front Spacer lift, DR900S-2CH Dashcam, and more...
Naylor99 is offline   Reply With QuoteReply With Quote
Old 12-26-2021, 08:57 PM #2
OutBreak's Avatar
OutBreak OutBreak is offline
Real Name: Cas
OutBreak will become famous soon enough
OutBreak's Avatar
Real Name: Cas
Anyone done this?
Hey I just did this install last month, it was pretty straight fwd. I did have some hang ups with my anytime front/ rear backup camera but Cliff was on point when it came to support. He took the time to video call and walked me through the fix. I definitely support Trail Grid Pro, just from customer service alone they are great!
Sony XAV-AX8100 Head Unit upgrade-20211031_141959-jpg
Whosoever is delighted in solitude is either a wild beast or a god.
OutBreak is offline   Reply With QuoteReply With Quote
Old 12-26-2021, 10:58 PM #3
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
It covers half the AC/Heater vents.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 11:17 AM #4
Looks great!. I'll have to move my phone mount, but with Apple CarPlay on that nice new touch display, I will no longer need the phone screen to be quite so accessible.
I understand the concern about air flow, but this phone mount covered a fair amount, and I never noticed a big difference. And I live in Texas, so there's that.
Old 12-27-2021, 12:03 PM #5
trapshot68's Avatar
trapshot68 trapshot68 is offline
trapshot68 is on a distinguished road
trapshot68's Avatar
Willing to clarify? I was actually going to ask them about the integration to Anytime Backup (who's always been helpful), but since you brought it up...
TIA.
trapshot68 is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 10:47 PM #6
OutBreak's Avatar
Real Name: Cas
OutBreak's Avatar
Real Name: Cas
TIA.
The integration now works flawlessly now with both my front and rear camera. A set of wires needed to be disconnected then reconnected to another set to work with the switch. It was a simple fix once cliff explained it.
On the vents, it does cover some of the areas. I took some better photos front and side. Not sure how worth it would be or if it would make much difference, but I have to imagine someone could 3D print some contraption that blocks the air from flowing through those portions. It doesn't bother me, nor does it seem to get to hot behind the unit if the heat is going.
Sony XAV-AX8100 Head Unit upgrade-20211230_212055-jpg  Sony XAV-AX8100 Head Unit upgrade-20211230_212118-jpg
Old 02-25-2022, 02:09 PM #7
jbtaco2002 jbtaco2002 is offline
jbtaco2002 is on a distinguished road
firmware upgrade
hey all,
i bought this head unit and wondered if anyone updated Firmware? mine had 1.0 for both CPU and MCU, and i'm trying to install the latest 1.31 and it appears stuck? been at 50% on the progress bar for 20+ minutes so far.
the 3 files for the update are the only files on the thumb drive. i'm afraid to interrupt and possibly brick this thing!
HELP! lol
jbtaco2002 is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 03:18 PM #8
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
Interesting the kit uses pac and not maestro.
Cheers! is offline   Reply With QuoteReply With Quote
Old 04-09-2022, 06:57 PM #9
The only issue I am having with this setup is that my Sirius is not working. Apparently there are two antenna connectors, and I connected the adapter to the wrong one. (White instead of black in my case). Problem is, I cannot find the second cable/connector behind the dash anywhere. Anyone point me to where under the dash that cable might come from? The white connector cable comes form above the air vents... if this rings a bell with anyone, please share.
The connector looks like a half dome on one end and inside you can see an antenna type round contact.
Old 04-10-2022, 02:39 PM #10
Replying to myself here in case anyone else needs it. The black connector is part of a large bundle that goes left-right just under the radio opening. I had to find it by feel. That hasn't solved my problem, but now I am connected to the right antenna cable.
Old 04-10-2022, 04:08 PM #11
osugsxr osugsxr is offline
what dash kit is offered with trail grid pro? Is it different than crutchfield? Also did you use the OEM brackets to be able to mount it in a lower position? I'm debating the sony 9500 ES model 10.1" screen or a 2020 + OEM with apple car play
Old 04-12-2022, 02:42 PM #12
Your options are silver or charcoal. Not sure who makes it, but mine looks great. The bundle comes assembled, so it mounts where it mounts. My son did his own, using a larger screen - might be the one you mention. He's happy with it.
Old 05-27-2022, 09:19 AM #13
thanks, I've been searching for awhile and think I may have found a used 8100 at $350. Ill need to pick up the necessary wiring harness for the 4runner still and metra kit. Plan is to use the lower mounting points to not cover the vents. So hopefully this purchase goes through
Old 06-28-2022, 08:29 AM #14
kept searching and may have found a used trail grid pro 8100 bundle at a good price. I'll need to purchase the back up camera wiring though since the seller has a 10-13 model. Would the maestro kit be a better buy vs using the pac system? Any benefits ? Does the 8100 have real time data on the car using the obd2 port?
Old 06-28-2022, 01:00 PM #15
I4CUTigers I4CUTigers is offline
I4CUTigers is on a distinguished road
My understanding is that the module (pac, instead of Maestro) that TGP uses does not do any obd2 readings. One of the reasons I built my own kit on crutchfield, with a Kenwood dnr1007xr and a maestro rr2. Just finished wiring an arb air compressor to a digital switch in the head unit with room for two more accessories. Has obd2, 4 camera inputs for my own multi terrain monitor, wireless CarPlay, and hdmi screen mirroring while on the road. I can even change factory settings like rolling down the windows with the key fob.
Very happy.
I4CUTigers is offline   Reply With QuoteReply With Quote
annoying , apple , car , play , screen
SONY 1-Din Head Unit - NY KingPrat Free 3 01-19-2018 02:22 PM
New head unit Sony XAV-62BT histine 4th Gen T4Rs 4 10-29-2011 10:48 PM
