Old 10-09-2019, 08:54 AM #1
DavidR1's Avatar
DavidR1 DavidR1 is offline
DavidR1 will become famous soon enough
DavidR1's Avatar
33x 10.50 Tires?
Has anybody run these tires? I have searched, but can't find a single thread on the subject.
I don't think I need these very wide tires that so many run. I'm pretty fine with my 265's, but would like a bit more height. The 33x10.5 would be taller but only a bit wider than stock, so I think this would work well for me anyway. Just curious to see if others have tried these and what were your thoughts?
DavidR1 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 08:55 AM #2
gearguywb gearguywb is offline
gearguywb is on a distinguished road
Look for 255/75/17 or 255/80/17
2019 TRD OR Premium. Dobinsons extended travel, Goodyear dura-trac 255/75's, pro wheels, sliders.
gearguywb is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 09:56 AM #3
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I don't know anything about them but the Kenda Klever RT come in a 33x10.5x17 size. BFG makes the KO2 in a 34x10.5x17 size as well.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 10:06 AM #4
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
I was so tempted to pull the trigger on the KO2s in this size, but the price was just too much for me to justify. I think they would be a really good performing tire though, and a lot less weight than a 285/70 or 75.
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 10:13 AM #5
sn_85's Avatar
sn_85's Avatar
Yeah they are quite pricey but I had a set of 265 C-rated KO2's that lasted me 60k miles with plenty to go so I do think they are a durable tire that wears well over the long haul. They're also D-rated and weight about 54lbs. I think they're the perfect size tire for our 4Runners but you're right, the cost is something that gives you pause.
Old 10-09-2019, 12:18 PM #6
There are a few options.
Cooper Discoverer, 255/80/17 is 32.8 x 10.2
BFG Mud Terrain 255/80/17 is 33.3 x 10.0
Nitto Ridge Grappler has a 255/80 as well
Old 10-09-2019, 07:20 PM #7
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I would by a similar tire in a size that is cheap AND you can get out in the World when you destroy one........not have to order an wait for.
83Mule is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 08:02 PM #8
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Sorry...I don't follow. Why would a 34x10.5 be significantly lighter than a 285/70? It's only a little narrower and larger in diameter?
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 09:26 PM #9
zw470's Avatar
zw470 zw470 is offline
zw470 has a spectacular aura about zw470 has a spectacular aura about zw470 has a spectacular aura about
zw470's Avatar
Compared to my C-load 285/70 KO2s the 34x10.5 are 5lbs heavier, .7" taller and .5" narrower.
zw470 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 09:40 PM #10
I suppose it all depends on your definition of significant. I guess I was really referencing the 285/75 in particular, because it is (almost) a true 34" tire, and is 5 lbs. heavier, which I consider significant enough to consider. But you are right, I did throw the 285/70 in there as well, and it's a mere 2 lbs. heavier in the E load range, which is insignificant in my book. The 34x10.5 is also a D load range, which if BFGoodrich made the 285/70 in a D would most likely be about the same weight.
And as was mentioned above, a C load rated KO2 is indeed lighter.
This is another reason why I opted to not go with the KO2 34x10.5
33x , bit , run , tires , work
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Tires tires tires Maxxis Trepador VS Goodyear MTR KaliKid General Discussions 3 11-18-2015 11:44 AM
2015 Trail edition 18"tires and Cooper Tires rubbing xtreme-24 5th gen T4Rs 5 11-29-2014 11:11 AM
Suggestions on snow tires or all terrain tires for a 2002 2WD 4Runner Limited? sienna221 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-14-2014 03:39 PM
Upgrade Tires, CV Boots are now leaking after upgrading tires and need advice. AZ4runner08 4th Gen T4Rs 20 02-16-2014 06:21 PM
