Old 10-09-2019, 05:04 PM #1
BJD275 BJD275 is offline
BJD275 is on a distinguished road
Parking light wire location 5th gen (2019) 4Runner
Hey all,
This may seem like beating a dead horse as I did search and there are 13 or so pages on the raptor light install however, I can't seem to find any that show where/how to tap into the parking light wire on the driver side for a 5th gen (2019) 4Runner (google has also failed me here).
I saw the post where they tapped into the parking wire going into the fuse box near the heel plate but I thought people were tapping into where the bulb connection was somewhere upfront, under the hood. Would someone please provide me a picture?
If there is a better solution to installing these lights to where I can have them on when the stick is on (any position) and off when it is off then I am all ears as the add-a-fuse option keeps them on at all times and I don't want that.
Thanks!
Brad
BJD275 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 05:45 PM #2
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
I simply tapped one of the wires to one of the side park lights in the headlight assembly. It's a little tight to get the plug out of there, but then I spliced into the wire. Do I remember which wire? No. But I'm pretty sure if there is a white wire with black stripe, it's a ground. You can probably tap either side, but if the bulb burns out you may lose power to your other lights if you use the ground side. Sorry, I'm not where I can get a picture to help.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 06:18 PM #3
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
Parking light +
  • Color: Green
  • Polarity: Positive
    pin plug (2F), pin 16
Parking light -
  • Color: Red
  • Polarity: Negative
    box, white 30 pin plug,
    pin 30
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 09:00 PM #4
Thanks for the help so far! This is my first wiring project so I have another (most likely dumb) question...
Am I splicing into these wires where they come into the fuse box? So the red positive wire from my LED lights spliced into the Green wire (pin 16) and black wire from LED lights spliced into the Red wire (pin 30)?
If you have a picture of this that would be even better.
Thanks!
Old 10-10-2019, 11:07 PM #5
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
Thanks!
Red to green, yes. Black to ground, anywhere, doesn't have to be pin 30.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 10-12-2019, 11:37 PM #6
I managed to get the ditch lights (Rigid D-SS Pros) installed...
However, the raptor lights are giving me trouble. When I got to the fuse box under the dash I noticed the wires are pulled super tight so I have to t-tap instead of splice. I was unable to figure out where to ground. Do any of you have any locations that are near this wire to where I don't have to tap another wire? Also, just to make sure, it is the green wire on the top left plug toward the bottom correct?
And because I can't figure out how in the hell to post pics on here with the image link using URL's (even after trying every photo bucket address) they are attached all out of order using the "manage attachments" section.
Thanks!
Parking light wire location 5th gen (2019) 4Runner-img_6886-jpg  Parking light wire location 5th gen (2019) 4Runner-img_6867-jpg
Old 10-13-2019, 08:17 AM #7
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:48 AM #8
TrkyMfns's Avatar
TrkyMfns's Avatar
I should mention, I do not recommend powering anything directly off of these wires. You should use these wires as a trigger for a relay. The last thing you want to do is pull too much current through your factory electrical harness.
4runner , gen , light , parking , wire
2008 4Runner Parking Brake Warning Light & ABS Light Flicker Simultaneously sant6236 4th Gen T4Rs 55 07-15-2023 03:34 PM
Parking Brake Wire Location gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 10 04-14-2021 11:33 AM
2016 parking light wire location... MadeInMaine 5th gen T4Rs 35 01-21-2018 10:17 AM
97 4runner parking light problem clay714 3rd gen T4Rs 3 06-28-2014 09:48 AM
Cigarette lighter wire tap - wire location? Nashvegas34 3rd gen T4Rs 7 03-03-2012 10:52 PM
