Old 10-10-2019, 03:40 PM #1
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Transfer case lube...
Transfer case oil/lube/gear oil is it being "used" or "getting worn down" only in 4HI and 4LO
Or all the time even in regular 2wd? Kind of like its there the oil in transfer case just sitting there in 2wd, but will start recirculating and really lubing stuff once 4wd turns on...
  Reply With QuoteReply With Quote
Old 10-10-2019, 05:16 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Yes, transfer case gear oil is only being "used" when front drive is engaged by selecting 4Hi or 4low. On a limited AWD its used all the time, I think you're asking about the selectable sr5/trail/OR/Pro platform
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 12:00 AM #3
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
I’ve also wondered the same. Having the lever type transfer case with the ability to disconnect, I would assume the transfer case is active in 2wd, thus your fluid is circulating in the TC driving the power to the rear wheels, which probably is a good idea to drain and fill every 30k.
Now if you were in 2wd with the drive selector in neutral, you are still engaged at the TC, just not the transmission. Or if you were in D but the TC is in neutral, you wouldn’t go anywhere since the TC shift lever is in “N” position. (Don’t think anyone would ever be in the drive position with the TC in neutral, knob type TC selector doesn’t have “N” position, SR5, Limited)
I’m planning to drain and fill the TC at 30k with Ravenol 75w. Most people on the forums that have reported draining their TC at 60k ish seem to have relatively clean fluid, but still shows signs of use. I guess it also depends if you use 4wd often.
Someone correct me if I’m wrong....
engeeoh01 is offline   Reply With QuoteReply With Quote
2wd , case , lubing , oil , transfer
Transfer case lube. vicpick58 5th gen T4Rs 87 03-03-2022 12:30 PM
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
