Old 10-12-2019, 11:04 PM #16
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Originally Posted by KP Texan View Post
Just replaced the 4 year old battery in my 2012 since it wouldn't hold a charge, and I've been watching the voltmeter much more closely over the past few days. Voltage seems to be normal and stays fairly steady (14.0 volts or so after I start driving, and then settling to around 13.9 volts).
Hi KP Texan,
All Alternator voltages fluctuate some, due to what the voltage Regulator's job is. It's there to maintain a safe voltage charge flowing to the battery, ...and... the vehicle's electrical system operation! Voltage flux is affected by, ambient Temperature, load demand fluctuation, wire length/diameter, and distance!
You don't (judging by your statement), have anything 'Abnormal' about your alternator's behavior, so you can just Relax and enjoy the security of the new battery, Okay(?)!
rig, cheers! Lol!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 10-12-2019, 11:15 PM #17
Maingear Maingear is offline
Maingear is on a distinguished road
Pull the ground straps on the chassis, frame, and engine and shine them up. Better yet run copper grounds to the body ground locations from the battery. I did this to a celica and the power windows sped up significantly.
2013 T4R SR5 stock 200,000 mile club
Maingear is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 08:43 AM #18
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Well, that's a bit unnerving to hear (just remember it's a gif so its playing over and over - the dip only happens once while braking). I'll check out the bulbs and any grounds also just to make sure those are good to go. I hate things like this that may or may not be a problem - I'd almost rather deal with something going out completely than wondering!
@rigtec mentioned "voltage droop" in one of his posts comparing his new high current alternator compared to the stock one. Maybe this is one of the symptoms he's referring to?
I checked my voltage meter over the weekend and it actually does exactly the same dip as yours, I just never really noticed it! So, no worries, all is normal!!!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 10:07 PM #19
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Thanks guys! I feel much better about it now.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 10:15 AM #20
Humble Leader's Avatar
I replaced my dead battery yesterday and I too was paying some closer attention to the voltage meter in the dash. sits just left of 14v when vehicle is running. sometimes when I press the brakes, same thing happens, slight dip then comes back up. seems to be when I'm stopped in park it's most noticeable, doesn't happen too much when I'm driving. no headlight dimming or interior dimming. all lighting is OEM. edit: I first noticed this when it was cold out and blower fan on full, defrosting windows and high heat setting
I also noticed this happens when I put the truck in reverse from park but don't let foot off the brake. It seems to stay a bit lower until I go back to park/drive/neutral. perhaps rearview camera/reverse lights drawing power or how they are wired. I've seen some posts on other forums with 80 series LC doing the same thing but haven't heard about a 4runner doing it
I assume this is also normal, battery terminals/connections are clean and tight. as rigtec mentioned, the alternator seems to be doing it's job by regulating the charge. you don't know what you don't know, I'm surprised I hadn't noticed this earlier
Old 01-12-2022, 02:51 PM #21
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
**** the volts.. measure your CCA to find battery life.
I run a tender on mine, battery is over 6 years old now. Without the tender I think the battery would get maybe 3-4 years max.
Keep the terminals clean, use a terminal cleaner and then use the red magic spray to minimize corrosion.
Our stock batteries are 550CCA panasonics on the old ones. I like to aim to keep it above 500ish. I check it only when parked and sat overnight.
Grug556 is offline   Reply With QuoteReply With Quote
normal , time , voltage , voltmeter , volts
Intermittent Idle Fluctuations AND Random Stumbling aontkos 3rd gen T4Rs 7 01-01-2019 03:42 PM
Voltage fluctuations Dezerts10 3rd gen T4Rs 12 01-19-2018 09:22 AM
First noticeable lift changes Bijan 3rd gen T4Rs 2 09-07-2015 05:43 PM
No load idle fluctuations in park and neutral HELP thedan12845 General Discussions 9 07-30-2014 10:40 PM
AC Temp Fluctuations During Idling. WFO_Racer 5th gen T4Rs 0 08-14-2010 10:22 PM
