Old 10-10-2019, 08:50 PM #1
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Noticeable Voltage Fluctuations Normal?
Just replaced the 4 year old battery in my 2012 since it wouldn't hold a charge, and I've been watching the voltmeter much more closely over the past few days. Voltage seems to be normal and stays fairly steady (14.0 volts or so after I start driving, and then settling to around 13.9 volts).
The only exception to this is when I step on the brakes sometimes. I'm not sure how much my voltage drops so I need to put a multimeter on it, but there's a definite movement of the voltmeter needle on the dash when I do. It's not every time I brake, just the first time after not braking for a bit of time.
I've read the electric brake booster draws a lot of power, but I was just wondering if any of you guys have noticed the same thing? I'm just hoping it's normal, and not a sign my alternator is failing!
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 08:54 PM #2
keph13 keph13 is offline
keph13 is on a distinguished road
I know my headlights dim a bit when I hit the brakes - it hasn't seemed to hurt anything yet!
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 09:38 PM #3
Thanks! That’s one check for the “normal” box, haha.
2018 TRD ORP - Sold
Old 10-11-2019, 08:28 AM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
my 2012 is on the second battery and I get slight quick dimming on braking and on electric window when it hits max up. Would have to say normal as I'm at 182,000. Also, my voltmeter sits slightly left of center most of the time, moves a little with AC on.
If you look into getting into the radio service menu, there is a page in there that will show real time voltage! I think you hold the settings button down and turn your lights on and off 3 times to get in there. Just search the forum, you'll find it.
Also, important, check your terminal connections!!!! My wifes camry corroded so bad it threw up codes and the CEL.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 09:33 AM #5
Thanks guys! I'm pretty sure what I'm experiencing is normal - I haven't really even noticed my lights dimming, it's just that dip in the voltmeter needle that had me concerned.
@Old Red , it didn't even occur to me that the 2014+ guys don't have voltmeters in the dash (should've known this since I had a 2018). That may be the reason I haven't gotten many responses to this thread! As for my battery replacement, I'm hoping that because it was 4 years old and it had been drained down completely several times, it was just at the end of its life. For future reference, if your kids jump in the back hatch area of the 4Runner, make sure they don't turn the hatch light switches to on!
All of this being said, I think I'm going to run it up to a place that will do free alternator testing just to to rule it out and give me peace of mind.
2018 TRD ORP - Sold
Old 10-11-2019, 09:56 AM #6
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
I have a voltmeter on my USB plug mounted in the dash. Voltage will vary between 13.1 to 13.9
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 10:15 AM #7
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
As another reference point: I have Scangauge II and Voltage will vary between 13.4 to 14.1- I see lower reading when it is hot outside and higher reading when it is cold, I am still on my original OEM (Panasonic) battery, it is 6 years old now.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 10:36 AM #8
Thanks everyone! Just ran out and did some testing with the service menu @Jivewalker mentioned. It looks like the voltage might drop to 13.8V or so for a split second when pressing the brake, or about a .5V change.
Engine Off, A/C on:
Engine On, A/C, Headlights on:
GIF of the voltmeter and service menu readout when pressing brake sometimes:
2018 TRD ORP - Sold
Old 10-11-2019, 03:21 PM #9
Jivewalker's Avatar
Jivewalker's Avatar
Service menu is handy, isn't it! You might also consider replacing your brake lamp bulbs or at least unplugging them and then testing, the lamps or harness connections could be your culprit if they are shorting. My gauge does not dip like that, makes me think short or bad connection.
I am fragile.
Not like a flower.
But like a bomb.
Old 10-11-2019, 04:02 PM #10
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by Old Red View Post
@KP Texan , At least you have a voltmeter...
Dimming headlights (after a new battery) plus the other dead battery might be the alternator starting to go. If it can't supply enough juice to charge the battery, and the draw of the headlights while braking causes a drop in light output as the engine RPMs go down, I would think maybe it is the alternator.
I just don't know what the reliability is with the OEM alternator. I know they last quite a long time, but don't know the track record personally.
Anyone know?
Limited experience here.
My 1988 left us at 305k miles with the original alternator. I had replaced brushes once as a preventive measure.
My 2001 had the brushes wear completely down at about 240k, had to replace the alternator because nobody carries brushes. I knew better...
Note: I have a 2006 Scion at 215k and a 2009 Corolla at 200k. Replaced brushes in both in the past few months, and they really needed it. I heartily recommend replacing brushes at 200k. It's the most frequent cause for alternator failure, I believe.
thennen is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 04:43 PM #11
Well, that's a bit unnerving to hear (just remember it's a gif so its playing over and over - the dip only happens once while braking). I'll check out the bulbs and any grounds also just to make sure those are good to go. I hate things like this that may or may not be a problem - I'd almost rather deal with something going out completely than wondering!
@rigtec mentioned "voltage droop" in one of his posts comparing his new high current alternator compared to the stock one. Maybe this is one of the symptoms he's referring to?
2018 TRD ORP - Sold
Old 10-11-2019, 06:47 PM #12
mike5 mike5 is offline
mike5 is on a distinguished road
Mine will drop from 13.8 to around 13.3 when braking initially. I see the needle move as well.
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 09:39 PM #13
Thanks! Nice to have another data point leaning towards the “normal” side. I honestly think most people don’t notice it because most owners don’t have a voltmeter! I was looking at gauge clusters online, and I think the only ones with it are ‘10-‘13 LEs and TEs. The SR5 in those years did not come with it from what I can tell.
2018 TRD ORP - Sold
Old 10-11-2019, 11:57 PM #14
My cluster has it, but I also have a volt meter plugged into the cigarette port. Easy to confirm quickly.
2013 T4R TE
My Adventures
Old 10-12-2019, 08:57 AM #15
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I have the scan guage on all the time .. 2016 runner. the voltage on cold start 14 volt range. when its warm/hot out the higher the air temps the lower the volts. 90F ac on the voltage is 13.1-13.4 volts..
air temps 20F 14.5volts.. this is why the voltage changes it is the voltage regulator ..
possible you could have fuse fingers corroded .. high moisture can cause this issue .. others also commented on how their voltage was as the same as my voltage operation..
on a GM vehicle the voltage stays at 13.7 volts when engine is running at normal temps.. when the air temp goes below 20F 14.75 volts sometimes 15 volts on cold start..
catrains is offline   Reply With QuoteReply With Quote
normal , time , voltage , voltmeter , volts
Intermittent Idle Fluctuations AND Random Stumbling aontkos 3rd gen T4Rs 7 01-01-2019 03:42 PM
Voltage fluctuations Dezerts10 3rd gen T4Rs 12 01-19-2018 09:22 AM
First noticeable lift changes Bijan 3rd gen T4Rs 2 09-07-2015 05:43 PM
No load idle fluctuations in park and neutral HELP thedan12845 General Discussions 9 07-30-2014 10:40 PM
AC Temp Fluctuations During Idling. WFO_Racer 5th gen T4Rs 0 08-14-2010 10:22 PM
