10-10-2019, 09:24 PM
Phone Issues - IPhone update?
Anyone having issues staying connected on calls after the newest iPhone update?
I updated my phone Sunday night, now when ever I call someone using the hands free I stay connected for about 3-4 mins then the toyota system freezes for a couple of seconds, says call ended and then completely resets... wait for the Toyota logo to come back up, everything.
Makes calls just fine everything like it used to but won’t allow me to talk more than a couple of minutes...
Any suggestions? I’m blaming the iPhone update as it wasn’t doing this last week before the update.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
10-10-2019, 09:54 PM
Real Name: Bob
Real Name: Bob
I have not updated the iPhone software from 12.4.1 to 13.1.2 but for about the last 2 weeks, I am dropping Bluetooth connectivity on phone calls after 3-4 minutes and the HU says “call ended”. However the phone is still connected to the other party and the call can be continued by lifting phone to your ear. The only way to reconnect Bluetooth is to restart the truck.
There have been other threads regarding this same issue but have not paid attention to them because I was fine until now. Not sure what is going on here.
Let us know what you find out.
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
10-11-2019, 07:25 AM
Yep this is pretty much exactly what happens. Except my head unit just resets itself automatically...
Ill see if I can dig up these threads you speak of today
10-11-2019, 08:23 AM
Try deleting the BT connection between your phone and HU on both the phone and HU. Make sure you delete/forget both sources on each device and not just disconnect BT.
Once you pair the devices again, see if this makes a difference.
If you want it done right, do it yourself!
10-11-2019, 09:13 AM
did this last night - didnt test it out yet.
Also found the thread about updating the head unit. Will try this too at some point today.
10-11-2019, 12:30 PM
Real Name: Bob
Real Name: Bob
Actually never thought of that.....might work, I'll try it and report back. See that you are close by, I'm from the Gibsonia area.
Sold: 2011 SR5
10-11-2019, 01:05 PM
I am in the Zelienople area. Small world!
10-12-2019, 11:16 AM
This is the exact issue I had/have. I went with a new iPhone (which had iOS 13), but also deleted all the Entune stuff at the same time, so wasn't sure where the problem lay. The iPhone X I had originally was rock solid.
I've done all the minor updates, and continue to have the problem. I've reset the head unit numerous times, used the secret menu to delete all info, un-paired/re-paired a billion times, etc. in all combinations. The last thing I did out of desperation was to reinstall Entune on my phone and set that back up. I've only made one short call since then, but it stayed connected the whole time. Will try to give it a longer test this weekend.
The other thing that happened as part of this is the system in general seemed to get less responsive. i.e., when calls came in, sometimes the touch screen wouldn't let me pick it up. Or sometimes the steering wheel controls wouldn't let me, or wouldn't let me disconnect (or there'd be a super-long lag). Unsure what the connection there is, but again this didn't happen until the new phone and iOS.
Frustrating to say the least...
10-12-2019, 09:38 PM
i just got the new iphone 11 pro and can't connect to my blue tooth either. its not even finding it on my cell phone. try to reset and etc.
10-15-2019, 10:57 AM
New iPhone11 issues
*** FIXED******
Im having the same issue but it starts when i connect BT and entune after starting the truck. The HU keeps resetting after 30 seconds. I have to turn off BT to listen to the radio. I killed all the connections and started over as recommended but that did not help.
*** RESOLUTION ***
Turns out i had a bad iPhone 11. It was glitchy in other areas besides Bluetooth. I went in to a sprint office and the rep said the phone was bad and the antenna specifically was bad. New phone is much faster and responsive. Better call reception, apps launch faster and my Bluetooth connection to the 4R doesn't drop anymore.
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
Reason: Issue Resolved
10-15-2019, 02:28 PM
I just went to the dealer for this, repeated reboots after 60 seconds if I have bluetooth enabled. They did a system reset and checked to make sure the previous system flash upgrade they did over the summer was still the latest version.
Then they said the radio needs to be replaced. $870 estimate plus taxes. I left without replacing the radio and I'll be looking at aftermarket options I guess.
I'm out of warranty- 82k. 2016 TE
10-15-2019, 10:08 PM
FYI for those with Bluetooth issues since upgrading to iOS 13 and or purchased an iPhone 11/Pro which comes with iOS 13. Apple has released iOS 13.1.3 today and one of the fixes they addressed was with Bluetooth disconnecting on certain vehicles.
I’ve updated mine and although did not have a long period of time to test, it did not disconnect for me during phone calls this afternoon.
10-16-2019, 10:36 AM
Didn't work for me
Thanks for the tip. I grabbed the update last night and tried it out. Unfortunately i did not fix the issue. I deleted all the old pairings and redid them, then restarted both and still no luck. I did have some brief success and was able to listen to a 3 min song but when i started to add my contacts, it disconnected again.
i have no doubt this issue will be resolved with more updates. No need to run out and get a new stereo (unless you're looking for an excuse).
Round Rock, Texas
10-16-2019, 10:39 AM
I too update to the newest release yesterday 13.1.3. I drove around for about an hour and my HU never shutdown. Where as before it would shutdown every 5-10 min!!
19 T4R ORP Icon 2.5 CDCV, 74Weld UCAs, Icon Overland rear springs w/ Icon 2.0 Resi, 285’s KM3, Icon rebounds, 4:56 Yukon gears, YOTAWERX AD Prem tune, Sumo Springs Blue bumps, magnaflow side exit, S&B intake. KC hidden bumper Rough Country 20”LED, RIGd tire carrier, frontrunner full roof rack, RIPP coil packs, victory ladder, BD Fogs, DRT hitch skid, MORE CO2 bracket, Rigid DSS Pro ditch lights
10-16-2019, 10:42 AM
Running into similar issues.
My main problem is with Carplay. I have a 2020 4Runner and carplay becomes completely unusable when taking a call. The entire system freezes up and the call becomes choppy and staticky and neither person can hear each other. This is ONLY happening on my iPhone 11 Pro on iOS 13. I have no issues with carplay and using my workphone which is an iPhone 7 Plus and absolutely no issues with carplay on my 11 Pro in any of my other cars.
I am urging people to write to apple and toyota to get this fixed, I dont know who need to fix it but if no one brings it to their attention, they wont know.
