Old 10-16-2019, 11:05 AM #16
Dmsea1's Avatar
Dmsea1 Dmsea1 is offline
Dmsea1 will become famous soon enough
Dmsea1's Avatar
Originally Posted by ant the ninja View Post
Running into similar issues.
My main problem is with Carplay. I have a 2020 4Runner and carplay becomes completely unusable when taking a call. The entire system freezes up and the call becomes choppy and staticky and neither person can hear each other. This is ONLY happening on my iPhone 11 Pro on iOS 13. I have no issues with carplay and using my workphone which is an iPhone 7 Plus and absolutely no issues with carplay on my 11 Pro in any of my other cars.
I am urging people to write to apple and toyota to get this fixed, I dont know who need to fix it but if no one brings it to their attention, they wont know.
I just emailed Toyota via the Toyota login - I will let everyone know if I get a response.
Dmsea1 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 11:22 AM #17
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
I recently picked up a new iphone 11 promax and am having problems too. The phone connects fine, but as soon as i receive a call a minute or two into it the car will disconnect from the phone entirely. i can't re-add it until a restart most of the time.
Never had any issues with my 7 plus.
tm965 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 06:57 PM #18
xdiep23 xdiep23 is offline
xdiep23 is on a distinguished road
Have you tried to update to iOS 13.1.3 which was released yesterday. 11 Pro Max with no Bluetooth drop since updating. Noticed my AirPods connect much faster now as well.
xdiep23 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:16 AM #19
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
my phone is messed up after that iphone update APPLE....
I have an appointment today (to fix iphone) probably waste an hour going through everything ive tried
I made it to 4 mins on a call last night with no dropping
just havent had time to call someone for longer.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:09 AM #20
no, will update today, thanks!
Old 10-17-2019, 11:19 AM #21
svowels svowels is offline
svowels is on a distinguished road
Same issue here. 2020 LE. Exact same problem. If I stop and restart the car it clears up. Hard to do on the highway! Taking truck in on Monday.
svowels is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 10:39 AM #22
Bugser's Avatar
Bugser Bugser is offline
Real Name: Bob
Bugser will become famous soon enough
Bugser's Avatar
Real Name: Bob
Originally Posted by meder24 View Post
Try deleting the BT connection between your phone and HU on both the phone and HU. Make sure you delete/forget both sources on each device and not just disconnect BT.
Once you pair the devices again, see if this makes a difference.
Thanks, @meder24 That solved the problem.....have not updated to the latest iPhone software since the bugs need to be worked out first.
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
Bugser is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 11:11 AM #23
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
I have not done my iPhone or my wife’s. Holding off. No reason to update yet if all’s working well. Hopefully apple gets it corrected.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:41 AM #24
update did not fix the issues for me. will delete phone pairing and try again without syncing contacts
Old 10-28-2019, 11:49 AM #25
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
For me, turning off "LTE" in settings solved the bluetooth call dropping issue. Found this solution on an Apple forum and seemed to be the same resolution for everyone.
Grape Ape is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 12:25 PM #26
where is that?
Old 10-28-2019, 01:51 PM #27
where is that?
Under settings> cellular > cell settings
Old 11-14-2019, 05:52 PM #28
bbaxter51's Avatar
bbaxter51 bbaxter51 is offline
bbaxter51 is on a distinguished road
bbaxter51's Avatar
This is driving me crazy. I'll try disabling LTE but it's not loading any of my call history, favorites or anything. Is there a setting on the new iphone 11 i need to change to allow this? I'm on my phone in my 4R constantly and can't have hands on the phone anymore due to laws. ¯\_(ツ)_/¯
bbaxter51 is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 09:51 AM #29
I think that part has to do with "syncing contacts" under Bluetooth (on phone) -> click on your toyota and it should be one of 2 selections you can enable.
Old 11-21-2019, 09:57 AM #30
here is what I have tried so far:
-Update the etunes app - FAILED
-Update heads up display software - FAILED
-Update iphone software - FAILED
-Delete pairing and re-pair phone to 4runner - FAILED
-Delete pairing and repair phone to 4runner with disabling sync contacts - FAILED
Just dropped another call this am after 2 mins like everyone else... My display unit just resets but this time it re connected my call after having to dig into my pocket, switch phone call to speaker. The 4runner took the call back once the unit was fired up....
I disabled LTE per comments above - well try that.
call , head unit , iphone , issues , phone , reboot , update
Qi Wireless Charging Phone Mount for iPhone XS Max Naylor99 5th gen T4Rs 15 02-09-2019 10:35 PM
Iphone phone dock cd4pro 5th gen T4Rs 0 01-18-2018 08:13 PM
Custom dash mount for phone, iphone, iPad, or tablet JMS87 5th gen T4Rs 20 03-24-2015 01:23 PM
Cell Phone Suggestions other than iPhone 5? Hepar Off Topic 37 04-17-2013 11:03 AM
Android Phone Update Delays Thai Off Topic 17 02-14-2012 02:51 AM
