10-11-2019, 12:18 PM
Will 295/70/17 rub the UCA with -10 offset 8.5” width wheels?
Just wondering if I need to go -38. Would probably prefer the -10 if I can get away with it.
Thinking of the SCS wheels with those specs. Thanks!
Yes I know different tire brands are different sizes but I was wondering if it was close or just not an issue.
I figure there is probably someone running these exact same specs who can chime in. I don’t wanna get the -10 then realize I need spacers
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
10-11-2019, 12:30 PM
Why not get the ones with the bigger offset, that is what I am doing when I get new UCA's.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
10-11-2019, 12:38 PM
I was thinking the -38 will rub more on the outside and maybe I’ll have to modify the pinch welds as well..
Also sometimes I think the -38 is too aggressive (undecided on this)
10-11-2019, 12:43 PM
Which UCA's do you have? Maybe get different ones that won't rub. I run 305's and I don't rub at all with +1. I know there are brands that won't rub on 295's
10-11-2019, 12:46 PM
I have Icon tubular. Haven’t tried the combo to see if it rubs yet, but want to do it right the first time..
10-11-2019, 01:42 PM
I don't recall hearing that Icons rub on 295's or larger regardless of offset. However, it's possible. JBA is the only (aftermarket) UCA brand I remember hearing of having problems with rubbing the control arm. Why not contact ICON and see what they say?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
