Old 08-24-2019, 07:43 AM #1
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
are longer bolts and spacers needed?
I bought a 3" toytec lift that came with a differential drop kit, I have an SR5 and added the TRD aluminum skid (factory steel sitting in the garage). when I drop the differential am I going to need longer bolts and spacers for my skid plate?
mr.walleye is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 07:46 AM #2
eelliiss's Avatar
eelliiss eelliiss is offline
eelliiss will become famous soon enough
eelliiss's Avatar
I don't have a diff drop, but the sway bar spacers included in the lift kit will make the front bolts that come with the TRD skid plate too short to catch. You'll need 60mm bolts up front to make it work.
eelliiss is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 08:34 AM #3
Whippersnapper02's Avatar
Whippersnapper02 Whippersnapper02 is online now
No need for the diff drop.
Whippersnapper02 is online now   Reply With QuoteReply With Quote
Old 08-24-2019, 10:35 AM #4
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
Don't need the Diff Drop, but it helps keep the cv axles closer to factory angle. Better in the long term especially if you go maximum lift height.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 02:07 PM #5
I've read about not needing the drop, but it came with the kit and I will install it, I see no reason not too.
Old 08-24-2019, 05:57 PM #6
Crossfit4runner Crossfit4runner is offline
Crossfit4runner is on a distinguished road
Yes you will need longer bolts and spacers. I had that same problem a couple of months ago. I had to put spacers on the back where the dif is and also double them up in the front.
I too was told that the dif drop wasn’t needed and I also felt the same as it’s there I’m going to install it.
Crossfit4runner is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 12:05 PM #7
sac602's Avatar
sac602 sac602 is offline
sac602 is on a distinguished road
sac602's Avatar
I just did this so figured I would bring this thread back to life for anyone's benefit. The ToyTec sway bar drop is 10mm. So I replaced the bolts that came with the Skid with 10mm 1.25 60mm bolts on all 4 TRD skid bolts. This does leave a gap between the skid support and frame cross member where the jack point support goes (center jack point between skid and frame cross member), so unless you also add 10mm spacers between the skid and the frame support I would not use the skid jack point.
2014 LE-Attitude Black with front end conversion. Warn 100022 bumper/ smittybilt x20 winch. Toytec Ultimate lift / Camburg UCAs. Fn Fx(pro) rims (www.importequipment.com center cap decals), 285/70 r17 Ko2. ZenonDepot H11 HID Kit | Xtreme HID
[Philips Bulb 4300K] / Morimoto XB Led fogs, DiyBriGuy.com Front/rear camera override. Removed 3rd row seats for fridge / drawers. Odyssey Batterie 34R-PC1500T - needs Odyssey Group 34 Battery Spacer. C4 Ladder, Prinsu rack
sac602 is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 01:55 PM #8
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
I had the same issue with my standard SR5 skid. I installed spacers in the back only so it was tilted. I wasn't thrilled with that, so I talked myself into upgrading to an RCI skid plate that accounts for the diff drop.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
bolts , differential , longer , skid , spacers
longer front wheel studs for spacers chipsahoy 3rd gen T4Rs 2 03-27-2020 09:01 PM
Part number needed: valve cover bolts and oil cap O ring sakoluvr 3rd gen T4Rs 9 03-20-2018 02:18 PM
285/70/17 Wheel Spacers Needed? TechControl 5th gen T4Rs 13 03-01-2015 12:27 AM
Longer rear shocks needed with Cornfed? Seatown 4th Gen T4Rs 2 08-01-2011 10:23 PM
1.5" daystar lift, longer shocks needed ? maxspeed96ct 3rd gen T4Rs 4 12-15-2010 12:22 PM
