Old 10-11-2019, 02:19 PM #1
M_RED M_RED is offline
M_RED will become famous soon enough
Cargo / Ski boxes on a '19 TRD-Pro tubular roof rack..
Since I searched a lot and found little info, I thought I would share my findings in searching for a cargo/ski box for my 4runner that is compatible with the 2019 TRD-Pro Rack.
My criteria started out as a box that fits my longest skis, (194s) and and a few snowboards (so it needed to be wide) and works with the tubular TRD-Pro rack... This proved to be more difficult than I thought....
First off, any of the boxes with recessed channels for the cross-bars is going to fit poorly, if it all. NO amount of shifting crossbars would allow a super low profile INNO box fit. The other big hurdle we hit, was most boxes couldn't shift far enough forward to open the hatch. Which was something I found unacceptable. So I started looking for flat bottomed boxes, Thule has some, and one that is long enough for my big pow skis...
At the shop (rackNroad in Seattle) the guys helped trial fit a few boxes. Very few wouldn't crash into the rear tubular bars....After the 4th or 5th box, we eventually found one that fit, a Thule Box. And due to a very upswept rear edge, it looked like it would fit with cross bars on the lower..
Here is the Thule Box mounted on crossbars on the top tube of the Rack:
And here she is nestled down on crossbars mounted on the lower tube, with a few mm to the rear lateral tubes, and fully open rear hatch. It over hangs a bit more than I would like in the front, but should be fine for now...
One thing that does annoy the heck out of me, is access to the key/lock. It is a tight fit as it lines up directly with the top tube of the rack. I'm trying to tell myself that the lock becoming hard to reach is a safety feature.... I'll see how annoying it gets when it is freezing cold and covered in snow..
M_RED is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 03:24 PM #2
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
Good info, I myself have been doing some research to no avail on finding anything that would fit our stock Pro racks as far as roof top tents and etc. It almost seems that the rack is just for carrying light stuff and/or for cosmetic perks. Planning on replacing it with a longer and lower roof rack in the future so I can install a Tepui Hybox on it. My other option was to just get a over landing trailer. Hopefully within the next year we might get a little more support from the aftermarket products since the 2020 Pro's have the same rack.
ProLee is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 03:31 PM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Hey! I used to work there! RackNRoad that is.
The FJ has the same-ish issue and rack deletes were created for that. I Found that most factory racks were the pits for over-all usability. On our 97 i removed the factory track and installed longer tracks (Thank you RNR for teaching me that) for more capacity and extendability of the rack.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 05:41 PM #4
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
TIL the pro rack isn't really a rack, it's still got normal crossbars. Even more useless than I originally thought!
I'm impressed you managed to fit a cargo box up there though
llDemonll is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 08:14 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You can fit 194's in there? Must be close. When I skied competitively years ago, I had 210's for GS (Head Competition) and 220's for Downhill (Heart Javelins). I had a roof rack that fit on top of my car with suction cups and clips that attached to the rain gutter. It worked great and was lockable. I guess rain gutters on cars are a thing of the past though - good luck.
Old 10-16-2019, 04:46 PM #6
The Box brochure thinks 205s will fit,,, it would be snug!
I can fit everything I need..
a pair of 185s,
161cm Snowboard
a pair of 194s, and a pair of 195s.
Old 10-16-2019, 07:38 PM #7
flyrv9's Avatar
flyrv9's Avatar
Looks good - I'm surprised all that fits. I did notice when storing skis bottom to bottom that they can rub some which dulls the edges that I spent time sharpening. I first used electrical tape; which froze and was a PITA to pick off. I ended up using a couple of towels instead.
Old 10-17-2019, 11:17 AM #8
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Thanks for trying this all out. The box actually looks good on the lower mount!
I have an older Mont Blanc box, hopefully it fits. (2020 on order) I also went out and bought a stock rack, (although mainly for parkade clearance) we will see how it goes.
MGordo is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 02:46 PM #9
Purely conjecture, but I think the cross bars on the lower tube of the TRDPro rack is super close to where they would be on a non Pro style rack... within a half inch, I would bet...
Old 10-24-2019, 06:25 PM #10
mountainmanTRDPro mountainmanTRDPro is offline
mountainmanTRDPro is on a distinguished road
Thank you M_RED for the information! Can you give specs on the Thule box model? Also, could you share the vehicle clearance with the box on the lower mount?
mountainmanTRDPro is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 08:59 PM #11
Color matched the box.... it looks better in the sunlight..
Old 12-21-2019, 02:36 PM #12
Do you know what you ground clearance is with the box? Any issues with parking garages? Thank you
Old 01-08-2020, 06:01 PM #13
Buckeye4Runner Buckeye4Runner is offline
Buckeye4Runner is on a distinguished road
Did you ever find out the THULE model of the cargo box that this guy fit on top of his TRD PRO?
Buckeye4Runner is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 10:58 PM #14
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
It amazes me that they even put this rack back on vehicles after seeing how horrible it was with the FJ. They literally created a kit to do a roof rack delete based on how useless these things were back then.
Has anyone compared the two with specs, I feel as though Toyota found a warehouse with thousands of FJ racks left over and just found a way to make money off them.
Grape Ape is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 11:06 PM #15
bmrplatinum bmrplatinum is offline
bmrplatinum is on a distinguished road
These look good. May have to consider....
bmrplatinum is offline   Reply With QuoteReply With Quote
box , boxes , fit , rack , rear
WaterTight Boxes for Roof Rack Simpleman74 5th gen T4Rs 31 01-26-2018 11:48 AM
Favorite Roof rack Boxes? Cr4zy4runner General Discussions 8 04-26-2017 07:11 PM
Roof rack boxes Yotta 5th gen T4Rs 11 10-22-2014 07:42 PM
Sport tubular roof rack for 4th gens 08medic4x4 For Sale: T4R Items 6 04-10-2014 07:57 AM
Tubular Roof Rack Cover tbm General Discussions 0 03-18-2012 07:06 PM
