10-12-2019, 08:34 PM
#16
Originally Posted by RedRunner_87
I have run the KO2's in the mountains of CO year around and they are great snow tires. I never had any issues with them in the snow and ice. I have heard the Duratracs are great as well. I think you could run either one year around.
Not sure what's different in Chicago than CO? I tried 2 sets of KO2s thinking 1st set was a lemon. They are awesome in summer, quiet and handle great. Anything cold and wet? like driving on banana peels, not safe at all. Many have also stated this. Yep, its got a snow symbol. works great in snow but sure as hell sucks on wet cold roads, the compound gets funky and makes driving fun long as your into daredevil stunts
10-12-2019, 09:06 PM
#17
My KO2s are pretty good in fresh snow but are not good on ice and slush and even normal rain. And get much worse as the tread wears. I have to put it in 4-HI when it rains heavy with them. I'll probably get Falken Wildpeaks or Duratracs (in E) next time. The Duratrac have weak sidewalls though.
99 SR5 v6 4WD
11 SR5 v6 4WD
10-12-2019, 09:28 PM
#18
Originally Posted by Ripper238
Well quiet relative to KO2s and some others. I don't mind a little bit of noise, as long as a little bit of music cancels it out.
On my old car I would change out my PSS tires every 30k anyway so I won't mind doing it with the R4 if need be, but that would suck. Lol
Doesn't sound like you would get them again.
Sent from my SM-N960U using Tapatalk
I never had more than the one set. The racquet was awful and they wore pretty fast, I've had 2 set of Ridge Grapplers since. Much quiter, Longer Life, and similar wet traction. Far better off road. However, wayyyyy heavier
10-12-2019, 11:54 PM
#19
I am not sure. I barely ran 4WD with them in the snow. Could have been because I had them on a 3rd gen and runner 285's, so it didn't have the power to get me in trouble? But I liked them. My brother-in-law is running them on his Taco and says they are pretty sure footed in the snow.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
10-13-2019, 12:25 AM
#20
Not a fan of my ko2. They arent that good in the rain and snow. Won't be getting them again. I live in a wet and cold climate.
10-14-2019, 03:45 PM
#21
I switch between my stock Limited 20's and 275/70/17 KO2 tires. It is getting to be to much of a nuisance. I will never do it again. When both sets wear out I am just going to run KO2 tires in load range c full time.
10-14-2019, 04:01 PM
#22
Real Name: Ben
Real Name: Ben
I've had 275/70R17 K02's on my 4Runner for about 30-35,000 miles so far, and other than the weight, I don't have a single bad thing to say about them. Maybe I got a special set, but mine have provided confidence inspiring traction and handling in all weather and road conditions. I think they provide ample traction on wet roads, think they perform extremely well on snow and ice for an all season tire, they're quiet, strong and they wear like iron.
If Firestone releases the XT in a 275/70R17, I may try that when my BFG's wear out, but they've been an exceptional, if challenging to balance tire for me.
41 PSI up front and 38 PSI in the rear unloaded, if I'm loaded up to road trip I'll bump it up to 44 at all four corners.
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
10-14-2019, 04:22 PM
#23
Getting 255/75 Duratracs installed on November 2nd all year use, but primarily wanted something solid in the winter that wasn't a winter tire.
10-14-2019, 05:33 PM
#24
Im on my 2nd set of Duratracs on my 4Runner and I love them. Some people complain about traction in the rain and ive never had an issue. I run E-rated one too, BUT i DO NOT jack the tire pressure up. I personally run about 34-35psi year round for normal driving and have aired down to 28-30 in the winter during some heavy snow conditions, like continuous driving in 8-10in and below 50mph. My last set I put over 60k miles on and they had 8/32nd's of tread still on them. I just didnt keep up on rotations like I should have....even thought I manage a tire shop lol. I have never had a single issue in rain or snow, on ice I just watch my driving and havent had any odd issues there either.
2012 Salsa Red Trail with KDSS
5100's with lift,285/70/17 Duratracs,some extra wattage and speakers in the stereo system.
2003 Chevy Tahoe 4x4 - 20in Rep's, lowered and loud 4x4
2002 Ford Crown Vic Sport - new project
10-15-2019, 09:44 AM
#25
I've had multiple sets of E-load DuraTracs on my 3/4 ton truck, and use them as my daily driver tires on my 4Runner. They've been great on dry pavement, snow. They lose a little traction in wet roads, but honestly, I have not driven a tire to date on a truck or SUV where I said "wow, this really has great wet traction"... never found one yet.
Like just about any chunkier tire, they do need to be frequently rotated and balanced to keep quiet. Since I get mine from my local Goodyear place about a mile away, they rotate and balance for free for the life of the tires, so I'm in there about every 4000 miles. Heed this advice, or they will get noisy.
That said, K02s are probably the most popular tire on 4Runners for a reason. They're a good all-around tire. My only fear with the tread pattern was hydroplaning.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
10-15-2019, 10:00 AM
#26
CO is really dry in winter. The snow is usually that powder stuff not the heavy slushy snow. And once it's plowed the wind evaporates any moisture left so you have pretty dry roads most of the time. If you want the best Chicago tire you should get a set of Blizzaks or proper winter tires. Winter tires are amazing, even when the road is dry at low temps because the compound stays sticky compared to A/Ts.
99 SR5 v6 4WD
11 SR5 v6 4WD
10-15-2019, 10:33 AM
#27
Real Name: Ben
Real Name: Ben
This thread got me thinking: has anyone here tried siping a KO2 to see how that changes traction and wear? I know several people who have had Cooper S/T Maxx tires siped, and they claim it improved wet and packed snow traction. Seems like it might be a viable option as long as you aren't doing a ton of high speed gravel driving where you would likely see significantly faster wear.
10-15-2019, 12:43 PM
#28
So it seems there is a difference in DuraTracs. Some suggest they bought E-load DuraTracs and i see some LT versions S and so on?
I'm not towing anything, but it does not mean i wont? I here the non LT versions are better for on road?
10-15-2019, 12:51 PM
#29
From every review I've read about duratracs from Canadians, they're good in snow but absolutely brutal on ice. Like bad, bad, bad.
I'm running 285 duratracs for the summer and have a dedicated winter set up with actual winter tires (265 blizzacks).
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
10-15-2019, 12:53 PM
#30
Main difference between the E rated and D rated ones is weight, D rated are about 6-7lbs lighter per tire in the 285/70/17 Size. They both 18/32nd's of tread So if you DONT need the heavier tire the D may be your options, which I think is the tire for the Colorado Bison or whatever. Which also has a rating of 121/118Q vs 121Q for the E rated.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
