View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 11-12-2019, 07:32 AM #151
bugkillr bugkillr is offline
bugkillr is on a distinguished road
I'm going to handle my own basic maintenance chores on my new to me 4runner. Looking at using the Quaker State Ultimate Durability 0-20 ,,,, has anyone found it hard to find? Amazon is out and my local Walmart doesn't have it. Strange...
Sent from my SM-G960U using Tapatalk
bugkillr is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 11:33 AM #152
drewsro's Avatar
drewsro drewsro is offline
drewsro has a spectacular aura about drewsro has a spectacular aura about
drewsro's Avatar
Originally Posted by 2016 4Runner SR5 View Post
Spec sheet, chemical makeup. Toyota oil has extremely high Moly, 787 PPM and that's the old formula. New formula is said to have an even higher Moly content however I have not seen a data sheet on it to verify those claims. Curious to see where this stuff comes in.
Here's what I can find:
https://pim.liqui-moly.de/pidoc/P000...20-48.0-us.pdf
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:43 PM #153
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
in the interest of helping you find an alternative from TGMO if necessary, here's a recent UOA someone ran with Redline 5W30 to show you the moly levels...almost all reports are 500+. you won't find a cost savings using Redline over TGMO but if for some reason you need to substitute and you insist on high moly, that is likely a good brand to consider.
their oil has a really strong High Temp High Shear rating as well, higher than some 30 weights...which means great things for long run (10k miles) durability and staying in grade under stress.
https://www.redlineoil.com/Content/f..._PROD_INFO.pdf
hope that may be helpful.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 10:07 PM #154
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Find Oil Change & Retail Locations Nearby | Quaker State lists locations that carry QS products. I just checked inventory at local Target stores. Not all stores carry 0W-20. Walmart is offering next day delivery to a store nearby.
DougR is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 07:24 AM #155
Thanks.
No Target stores within 70miles of me. And only 2 Walmart's within 12. I'll try Walmart's ship to store option.
Old 11-13-2019, 08:22 AM #156
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
^^^^^This^^^^^
Redline is a good High moly oil but has the added benefit of group 4&5 base oil, stays in grade too. Redline Professional Series oils All have a higher cSt across the line; good stuff. Guys over on the Ram forums call redline Hemi Homey, proven to be one of the best, and produced some of the best UOA’s I’ve ever seen.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 08:29 AM #157
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Originally Posted by mcox522 View Post
Same here, I just changed the transfer case at 31K miles. It looked about the same as the new Toyota 75W I put in it. It was pricey though at $87/ liter. Doesn't bother me though as I don't see a few extra $ worth possibly something going wrong prematurely and costing much more. I'm no expert but that's my thinking.
I changed the rear differential at 5K, 15K, and at 31K. Each time it was grey and had sludge buildup on the drain plug magnet. I used royal purple 75-90 this time and Mobil 1 previously.
I held off on the front differential until 31K as I had heard numerous people report that it looked new at this interval. When I changed mine it was the light grey in color and had a good amount of sludge buildup on the drain plug magnet.
Oil I change every 5K. I loin free in the AZ desert acms it's cheap to change oil.
CONCLUSION: For my driving habits I am going to change the differentials every 15K and transfer case most likely every 30K. The transfer case will probably be ok at longer intervals, but it will be easy to do every other differential change.
Judy thought I would share my experiences with the oil changes.
Sent from my SM-N960U using Tapatalk
^^^^^ That’s a solid maintenance strategy right there sir, that’s good stuff^^^
What engin oil are you running?
Old 11-13-2019, 12:29 PM #158
Daftjungle03 Daftjungle03 is offline
Real Name: Michael
Daftjungle03 will become famous soon enough
Real Name: Michael
I've pained over this as well for my 2019. After significant reading and research over at BITOG I came to a solid conclusion. The Toyota 4.0 isn't picky, is going to run longer than most engines regardless of what you put in it. I settled on QSUD 0W-20 and a factory Toyota filter. I did my first change at a little over 2K and will probably do another at 7500 and settle into a 7500oci from then on. You can pay as much as you want or as little as you want but in the end it probably will make little difference. For the last 32years or so I've bought into an early first change and then regular intervals after that. With QSUD and a factory filter I think the change was less than $30.
Now that being said if you have a sludgy DI engine you may want to look harder. I had a 2.7 Ecoboost that I only used Pennzoil Ultimate Platinum due to the reported issues.
Daftjungle03 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 12:38 PM #159
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Originally Posted by Hammer0313 View Post
OK guys here is an update:
The aluminum housing did not work for me, it didn’t leak but it did Seep oil very slowly. And the center tube didn’t seat very good at all, the slightest movement from side to side it would pop out. This was the OEM aluminum housing from Toyota! FYI- No need to bend the tabs to get the center tube out.
Rear Diff: Just look at the photos, rig only has 2966 miles on it and the gear oil looked worn. Glad I got that out!
That oil "looks" brand new to me. No pic of the magnetic drain plug?
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 12:42 PM #160
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Nope, no pic of the drain plug. My bad
Old 11-13-2019, 12:48 PM #161
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
QSUD? Definitely my favorite off the shelf oil to date, good molybdenum and very good price. Hard to beat!
I did my first oil change at 2300 miles and I’m glad I did, the oil filter housing had little silver flakes puddled in the bottom. It felt good to get that out!
Old 11-13-2019, 02:56 PM #162
Real Name: Michael
Real Name: Michael
Absolutely! I think it was $17.50 or so for 5qts, so I bought three so I can do it twice. I have nothing against TGMO but the price.
Old 11-15-2019, 11:09 AM #163
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Shell Rotella announces a new formula of the T6 full synthetic improving deposit control and oxidation control by 27%. And announces new T4 NG Pluse compatible with Diesel fuel, gasoline and natural gas. Cool stuff!
Shell Unveils Natural Gas Engine Oil | Transport Topics
Old 11-15-2019, 12:03 PM #164
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
This is “Hands Down” the best article on engine oil additives in plan language that I have ever read. Definitely worth the read!
Lubricant Additives - A Practical Guide
Old 12-03-2019, 11:39 AM #165
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
If your running a thicker oil pay attention; see pic!
I’m using a ODB sacaner/monitor that uses Bluetooth to communicate with my phone, got it set to monitor my fluids and a few others.
Engine oil Only got to 154.4 degrees Fahrenheit coming up from Florida to Georgia, running at 70-79MPH for over 8 hour. Most modern vehicles usually run 200+ degrees Fahrenheit. So what does this mean for the 20w oils and the 30w oils? Both will run thicker at operating temperature in the Toyota 4.0!
Most oil manufacturers will give you a cSt value at 104 degrees Fahrenheit and 212 degrees Fahrenheit on the data sheets. This gives you the viscosity range of that particular oil under normal operating temperatures. 212 degrees is a representation of the oil at Operating Temperature; so if your oil is running cooler it’s also running thicker.
Last time I was in Florida it was hot and and my oil temperature got to 173 degrees Fahrenheit, but I didn’t get a picture of it. So the ambient air temperature seems to have an affect on oil temps.
So if your running a thicker oil check the data sheet cSt and understand that your oil is running cooler/thicker.
Additional Info:
Oil- Amsoil 0w20
Air Temps- 47-61 degrees Fahrenheit
Speed- 70-79 MPH
Time- 8 Hours
Terrain- Moderate
5th Gen Oil Recommendation? New Owner!-c13f6b44-5f9a-4fcb-919b-d59e23bc024e-jpg
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
