View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 12-05-2019, 01:35 AM #166
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by Hammer0313 View Post
I’m using a ODB sacaner/monitor that uses Bluetooth to communicate with my phone, got it set to monitor my fluids and a few others.
Engine oil Only got to 154.4 degrees Fahrenheit coming up from Florida to Georgia, running at 70-79MPH for over 8 hour.
my understanding is that our engines don't even have an oil temperature sensor, just a simple oil pressure switch for the dummy light. so, any idea where the scan gauge is pulling oil temp readings from?
no modern engine should be running oil that cold on a normal basis. that's waaaay under temperature for proper oil detergents to work right and would not allow for water vapor to burn off on a regular basis which creates other issues.
So the ambient air temperature seems to have an affect on oil temps.
temps will definitely climb above typical ranges in hot weather but regardless of how cold it is (within reason, not talking like -50 in Alaska), after extended normal operation the oil temps should always reach a consistent ceiling.
this is very strange.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 10:58 AM #167
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I have never seen an oil temp sensor on a vehicle for the engine.
transmission fluid temp is common.
Toyota does not have an engine oil pressure sensor . as you stated just a switch which is ODD IMO !!! I do have the scan gauge no sensor so no oil temp or pressure data...
I monitor the tranny temp all the time.. engine coolant temp is very stabil .. engine has a good coolant system.
I switched from mobil 1 engine oil to toyota engine oil .. engine is very quiet now..
catrains is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:16 PM #168
Woz1976-MT's Avatar
Woz1976-MT Woz1976-MT is offline
Real Name: Steve
Woz1976-MT is on a distinguished road
Woz1976-MT's Avatar
Real Name: Steve
Got my first UOA from Blackstone after using Amsoil SS 0W-20 (11,781 miles on the oil). Here it is for everyone's perusing pleasure.
5th Gen Oil Recommendation? New Owner!-uoa-jpg
- Steve
2016 Trail Edition | Classic Silver | KDSS | Entune with Nav | Factory Remote Start | TRD Pro Matte Black Wheels | Cooper Discoverer A/Tw LT265/70/17 Tires
Woz1976-MT is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 05:58 PM #169
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
I’m not sure where the sensor is but the temperature is quite alarming, i’m thinking about getting a thermal gun and measuring the pan temperature and comparing it with the gauge. I might try and surf YouTube tonight to see if I can find out where that engine oil temperature sensor is. Or maybe I’ll try and stop by the dealership tomorrow. This is definitely something I want to get to the bottom of.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 06:00 PM #170
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Fantastic report !!!!!! That Amsoil is serving you well, Fine job Sir
Old 12-05-2019, 07:02 PM #171
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
Originally Posted by catrains View Post
I have never seen an oil temp sensor on a vehicle for the engine. transmission fluid temp is common.
My 2019 Subaru Forester has an engine oil temp gauge. I was kinda surprised it has that.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 09:06 PM #172
MidniteTRD's Avatar
MidniteTRD's Avatar
definitely let us know what you find. my understanding, based on searching around on this forum, the FJ forums, and Tacoma forums is that the 1GR doesn't have an oil temp sensor (only sensors for coolant and trans temp), and a binary oil pressure sensor for the dummy light in the dash.
as for reported oil temps, seems to be a very hard bit of info to find. people seem mostly interested in running oil pressure, cool temp and trans temp gauges. very little info out there about indicated 1GR oil temps....most likely because these engines are so reliable, most people can't be bothered.
Old 12-05-2019, 09:23 PM #173
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Oil temp is going to be acceptable with a coolant temp of more than 180. Synth is stable to 425 so overheating the oil just isn't an issue except for the case of a catastrophic failure being imminent. I HAVE noticed the 4Runner has a ''lazy'' thermostat that takes a very long time to get up to temp even in 120 degree temps with the A/C on?! Anyone know if they are 195 thermostats?
83Mule is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 07:34 AM #174
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I would say it has a 180 degree thermostat judging by my gauge, or maybe a 185, I’ve never seen my coolant temps go over 190.
5th Gen Oil Recommendation? New Owner!-8dd00995-1c59-413f-a342-7628350bf8e3-jpg
Old 12-06-2019, 08:31 PM #175
83Mule's Avatar
83Mule's Avatar
I have not seen a thermostat colder than 192 in an emissions controlled vehicle in 30 years!......and a 180 would certainly cost some mpg! Engine must get over 160 just to go into closed loop on the ECU! Maybe the slow rise to temp is part of the reason We all are disappointed in the MPG? It would be running very rich until it gets up to running temp and that needs to be around 200 for efficiency.
Old 12-09-2019, 05:40 PM #176
your temps look normal but the engine oil temp does not look correct. should be 250F area .. temp is on your reader 150F ??? not correct.. engine oil gets way hotter than transmission and coolant .
pistons cause the higher oil heat.
Old 12-09-2019, 05:56 PM #177
my 2016 runner engine temp rises pretty quick in normal air temps 50-80F.. if its 20F out and I have the heater blowing on the max YA it does take a bit longer.
I put a plastic shield in front of the ac condenser in the cold weather below 30F 50% covered.. reason I do it , I want my toes to get nice and warm quickly ..
engine temps 180-185F range very stable because it has a manual fan not electric ..
electric fans do work well when cold temps hit .. heat rises quicker than mechanical fan..
in hot weather the electric fans do cause temps to rise in the 225F range with the ac off when in traffic ..
I have 4 vehicles all with different coolant systems .. toyota system I like .. works very well compared to the GM vehicles.
Old 12-10-2019, 06:24 AM #178
northcoast's Avatar
northcoast northcoast is offline
northcoast will become famous soon enough
northcoast's Avatar
Great UOA! And more proof that 10k miles OCI is fine and dandy. 3.6 on the TBN at almost 12k miles is pretty damn good!
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
northcoast is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 08:02 PM #179
MidniteTRD's Avatar
MidniteTRD's Avatar
Originally Posted by Tuco S. View Post
Do us a favor and track your mileage on fuelly.com, and then report back on any differences between the 5W-30 and 0W-20. I would be interested to know if your fuel economy takes a hit.
a follow up on this - just did a full oil change with QSUD 5W-30, then immediately drove 1400 miles up and down the east coast for Christmas vacation.
fully loaded with luggage and 4 passengers, AND a full Thule Sonic XL cargo box on the roof. still running the factory Dunlop AT20 highway tires. cruise set between 72-75 most of the trip. temps bounced between 65 and 35.
19.5 MPG average according to the trip computer. if we didn't have the cargo box on the roof i'm 100% sure we could have matched or bettered the 20 MPG highway rating. i'm not as concerned about city ratings since that can vary so much based on traffic and driving habits whereas highway driving is more steady state.
i know its not a direct comparison to running 20wt in the sump on the same route, but i think its fair to say you can get so close to (or in some cases, as good as) factory highway ratings running a 30 weight, that it hardly matters.
Old 12-30-2019, 08:47 PM #180
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
^^^^^Great Field Test^^^^^^
How did you like the 5w30 overall? Gas mileage looks like minimal differences between the 30 and 20 weight oils. How was the cold starts? Any sluggishness?
The QSUD is by far my favorite off the self oil! If you do a UOA please post in this thread for me, would love to see that.
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
