View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 12-30-2019, 09:10 PM #181
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Originally Posted by 83Mule View Post
I have not seen a thermostat colder than 192 in an emissions controlled vehicle in 30 years!......and a 180 would certainly cost some mpg! Engine must get over 160 just to go into closed loop on the ECU! Maybe the slow rise to temp is part of the reason We all are disappointed in the MPG? It would be running very rich until it gets up to running temp and that needs to be around 200 for efficiency.
I own a 2011 Chevy HHR Flexfuel with a 2.2L Ecotech engine which came oem with a 180° tstat.
It has a digital display as well as a gauge. The digital reads between 180 and 185 with the a/c on in S Florida.
Sitting at a lite it will climb up to over 210 simply because GM in their infinite wisdom decided not to turn on the radiator fan until 217°.
I'm not complaining about the temp so much as the 30+ temp swing.
Once warmed up, an engine should remain pretty constant in temperature.
I thought everyone knew that.
seatia is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:19 PM #182
Originally Posted by MidniteTRD View Post
a follow up on this - just did a full oil change with QSUD 5W-30, then immediately drove 1400 miles up and down the east coast for Christmas vacation.
fully loaded with luggage and 4 passengers, AND a full Thule Sonic XL cargo box on the roof. still running the factory Dunlop AT20 highway tires. cruise set between 72-75 most of the trip. temps bounced between 65 and 35.
19.5 MPG average according to the trip computer. if we didn't have the cargo box on the roof i'm 100% sure we could have matched or bettered the 20 MPG highway rating. i'm not as concerned about city ratings since that can vary so much based on traffic and driving habits whereas highway driving is more steady state.
i know its not a direct comparison to running 20wt in the sump on the same route, but i think its fair to say you can get so close to (or in some cases, as good as) factory highway ratings running a 30 weight, that it hardly matters.
It is my understanding that a primary reason for the 20weight is for the vvt system to work properly.
I use Mobil 1 0w40 in all my vehicles, but since Toyota specced this 0w20, I was leary of using the 0w40 for that reason alone. It's what came factory for Porsche, Mercedes and Corvette, pretty decent oil with a better add package.
Old 12-30-2019, 09:32 PM #183
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Mobile 1 0w40 is the old school Super Oil; still one of the best. I really like 40 weight oils, they are less regulated and typically have a robust add pack.
Just as an FYI my manual says you can run a thicker oil if you operate the vehicle at high speed. Not sure what Toyotas definition of high-speed is but I think 30 weigh oil will be fine. If you do run the 40 please let us know how it goes; the manual also recommends 40 weight oil for Central America region.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:37 PM #184
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I wonder what would work well here in Arizona. The part I live in sees over 120° for months at a time.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:48 PM #185
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I’m a big fan of using 40 weight oils but I like the service range of 30 weight in the Toyota 4.0....
Old 12-30-2019, 10:15 PM #186
If it were staying here in hot S Florida yes, but unfortunately it will be going to northern Michigan this coming Sunday with my 20 year old daughter to college. She needs a 4x4 and that HHR didn't cut it with only about 4" ground clearance.
I just bought this 4Runner a week ago so I have a lot to learn.
I had her buy the 0w40 last year for an oil change and the mechanics up there threw a fit since GM specced 5w30
The only thing that really concerns me is the operation of the VVT system and what weight oil it could handle. I'm about the same weather wise as Central America here, but Michigan.........
Old 12-31-2019, 01:13 AM #187
josephp732 josephp732 is offline
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
I am pretty active on BITOG and I posted the VOA on the new Toyota 0W-20 SN Plus blend - my sample was taken from a bottle with a blend date code of Oct 2019 - VOA below.
I also like Eneos Racing Street 0W-20 SN oil. This oil is not any cheaper but it's another option. It has higher moly and zinc than the Toyota oil. VOA below.
Idemitsu Eco Medalist Advanced Moly 0W-20 Engine Oil is also high in moly and zinc. VOA below. Amazon has a good price on this oil at $37.00 for 5 quarts - Amazon.com: ZEPRO 30010095-95300C020 Eco Medalist Advanced Moly 0W-20 Engine Oil (5 Quart), 160. Fluid_Ounces: Automotive
All three also have healthy doses of Boron:
Moly Content
Toyota - 656ppm
Eneos - 835ppm
Idemitsu - 668ppm
Zinc Content
Toyota - 753ppm
Eneos - 811ppm
Idemitsu - 804ppm
Boron Content
Toyota - 173ppm
Eneos - 358ppm
Idemitsu - 264ppm
I run 5k OCI, use Amsoil or Toyota TRD oil filters (they are the same), switched all my 4Runners to the aluminium filter housings and replaced the factory drain plug with Gold Plug magnetic plugs.
Most Japaneses auto manufacturers use high moly, high zinc oils - Toyota, Mazda and Subaru.
5th Gen Oil Recommendation? New Owner!-annotation-2019-12-31-001740-jpg  5th Gen Oil Recommendation? New Owner!-annotation-2019-12-31-001851-jpg  5th Gen Oil Recommendation? New Owner!-full-82059-25909-voa_idemitsu_zepro_em_advmoly-jpg
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 08:49 AM #188
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Climate is something I always consider when choosing oil viscosity. Norther Michigan I would be running a 0w20 or a 0w30 at the most during the winter.
Old 12-31-2019, 08:55 AM #189
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Moly Content
Toyota - 656ppm
Eneos - 835ppm
Idemitsu - 668ppm
Zinc Content
Toyota - 753ppm
Eneos - 811ppm
Idemitsu - 804ppm
Boron Content
Toyota - 173ppm
Eneos - 358ppm
Idemitsu - 264ppm
Wow those 0w20’s are loaded with additives! Do you know anything about the base oil used in those?
Old 12-31-2019, 10:41 AM #190
Real Name: Joe
Real Name: Joe
Yes all have big additive packages. Plus a lot of calcium in the ENEOS and Idemitsu oils as well. All are Group 3+ base oils.
The anti-wear package in the ENEOS oil is the highest Moly & Zinc package I have seen in an API spec oil. When I use this oil I do get slightly better MPG's. It's an interesting oil.
ENEOS is manufactured and sold by JX Nippon Oil & Energy Corp., the largest oil company in Japan. They manufactures/blend for the US market in Schaumburg, IL
Idemitsu oil is the factory fill in Mazda's. Idemitsu manufactures/blend for the US market in Jeffersonville, Indiana. They are the eighth largest lubricant manufacturer globally.
As noted in the United States - Toyota's oil is a special blend done by ExxonMobil. It's a good stout oil - at ~$6.50 a quart it's very reasonably priced for the additive package.
The 4Runner's 1GR-FE 4.0L engine is "fairly" easy on oil, no real known issues with the "possible" exception of higher mileage engines having timing chain stretch, code P0016. The anti-wear packages in all these oils will certainly help with any possible timing chain stretch over the life of the engine. This one of the the reasons the Toyota factory oil has such high moly and zinc.
Since the engine is still port injected there are none of the GDI carbon build-up problems. I don't over read into the NOACK percentages. They are very important for GDI's but much less important for port injected vehicles, especially with 5k OCI's.
File Type: pdf ENEOS-RACING-STREET-0W-20-Product-Data-Sheet_0418b.pdf (83.0 KB, 340 views)
Old 12-31-2019, 04:23 PM #191
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
How did you like the 5w30 overall? Gas mileage looks like minimal differences between the 30 and 20 weight oils. How was the cold starts? Any sluggishness?
thanks, and no, no discernable difference at all. on the coldest morning while we were in MD, i saw 26 degrees on the dash when getting the engine started. cranked up with the flick of the key and i noticed no unusual noises. i drive all cold engines pretty gingerly for the first 10-15 mins until the oil comes up to temp, but in that time i didn't notice any hesitation or sluggishness.
i will absolutely do a UOA once this oil is changed out. take it with a grain of salt though, as the engine only has 6k miles on it right now and it'll still show higher than normal wear metals as it continues to break in. but...it'll at least make a good baseline for future comparison.
not directed at you personally but i generally disagree with the assertion its required for correct VVT operation - if that was the case they would not allow higher viscosities for high speed/severe use as stated in the manual, or the higher viscosities that Toyota specifically calls for in markets outside the US in other 1GR equipped models. just my opinion anyway.
interesting you bring up M1 0W-40...one of my favorite oils! cheap, easy to find, good shear stability, and the add pack. i've actually been running this oil in my old civic Si, a car specced for a 30 weight domestically but calls for up to a 40 weight in other markets. so far i have 2 blackstone oil analysis on it (6600 and 8200 mile runs) using the 0W-40 and the results have been outstanding. that's on a 100k mile engine that regularly sees its 8000 RPM redline btw. i think a 40 weight is likely overkill for the 1GR so i don't intend to use it in our engine though, but my point is that it pays to look at what oil's specced for other markets and that will help to discern just how much our CAFE compliance dictates oil viscosities for JUST our market while the rest of the globe uses something else.
my take on it is that its Toyota legal-speak for "if you're going to run the engine under heavy load, and get it real hot, it needs a thicker viscosity". i think comparable use would be hard crawling, towing, extended grade climbing and use in high temps. seems to me they have to dance around the issue with vague descriptions to ensure customers feel compelled to stick with the thinner 20 weight so as to keep Toyota's fleet MPG high enough to maintain their CAFE compliance. again, could be wrong on that, but it makes sense to me.
personally, i would definitely use something thicker than a 20wt for your area...maybe not a 40, but a good 30 weight. in the manual it calls out thicker viscosities for Puerto Rico, up to a 15W-40 in fact - but as far as i can tell, no part of PR gets hotter than AZ! i think its another example of Toyota's legal team having to step around the "mainland US" viscosity to give a hint at what they really want you to use for use in high temps. i mean think about it - its not like PR gets so much hotter, or is vastly more extreme terrain than many places we all venture here in the US, and they can clearly get 20wt oil out there if they want it. i'd go so far as to say most of the western US is a more extreme terrain than PR.
absolutely. here in GA we saw a 100 degree day in early October this year! it gets sweltering in the summer, and stays that way 24hrs a day. that's part of the reason i stepped up to a 30 from a 20. equip your car for your conditions and patterns of use.
outstanding info and lots of good details there to mull over. thanks for that.
i've noticed the 1GR seems, at least to me, to shed more FE than the typical 1PPM per 1000 miles average you see on most engines. i always wondered if that was maybe due to timing chain wear.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 04:58 PM #192
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I need to correct the Central America comment. Manual States Puerto Rico not Panama. I do apologize for my confusion.
Interesting enough the following oils are approved for Puerto Rico:
0w20
5w20
5w30
10w30
15w40
SEE PIC!
5th Gen Oil Recommendation? New Owner!-d8490349-0be1-414b-8390-c7c85a1dbd27-jpg
Old 12-31-2019, 08:50 PM #193
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Ambient air temp is not the issue, it's the water temp that dictates the engine's temp in the end. The engine oil isn't going to care if its 120 out so much as what the coolant temp is. If the temp is 200 degrees on the dash it can be 60 or 120 out, oil doesn't care. Engine temp runs between 180 and 220 roughly, and that is no problem for even a 20W as a Synth is stable to around 425. Engine oil will never see 400+ as the engine will have blown before it gets there.
83Mule is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 12:04 PM #194
sdkosu's Avatar
sdkosu sdkosu is offline
sdkosu is on a distinguished road
sdkosu's Avatar
Originally Posted by 2016 4Runner SR5 View Post
You're the only one I have seen with fitment issues using the OEM aluminum housing. I put one on my 2016 4Runner, 2019 Highlander, and I bought one for my Dad for his 2019 4Runner. All of them fit like a glove with zero issues. Not sure what's going on with yours but there is more to the story. As for the gear oil, good call. I swapped mine front and rear at 11K and there was A LOT of speckle in the rear diff fluid. Front looked brand new but I was still happy to get it out of there. Engine oil every 5k, gear oil every 30k, transmission and transfer case every 50k Absolutely no one will convince me otherwise either. It is literally impossible to over maintain a vehicle. I challenge the people that say "you're overthinking it" to prove me wrong.
I just changed my oil & filter, giving the Toyota oil a shot to see if it's worth the extra change and I picked up an aluminum housing as well. Noticed that it spun on much easier than stock plastic and I was actually able to fully seat the housing metal to metal. Same with the drain plug. I double checked the new o-rings and all. I ran the truck to see if any leaks appeared and it looked OK after a few minutes of idle. Did you have the same experience with the new housing or did it fit very snug like the stock plastic?
2016 4Runner Limited: Blizzard Pearl/Redwood
XenonDepot 4300k HID - WeatherTech - StopTech Brakes - AVS Bugflector - WizGear Magnetic Phone Mount - Fumoto Drain - Toyota Molded Mudflaps - Carista
sdkosu is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 01:27 PM #195
Real Name: Joe
Real Name: Joe
I changed out the oil housing to the aluminum version on all three of my 4Runners and I have had the same experience that you described. I was able to easily spin the metal housing all the way up to the mounting base. I have not experienced any leaking to date.
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
