View Poll Results: What’s your go to oil?
Toyota Synthetic
158 |
29.76% |
Toyota Synthetic
158 |
29.76% |
Mobile 1
247 |
46.52% |
Pennzoil
47 |
8.85% |
Quaker State
7 |
1.32% |
Valvoline
17 |
3.20% |
Supertech
11 |
2.07% |
Rotella
10 |
1.88% |
Amsoil
42 |
7.91% |
Redline
10 |
1.88% |
Royal Purple
14 |
2.64% |
Havoline
4 |
0.75% |
Schaeffer’s
4 |
0.75% |
Motul
13 |
2.45% |
Castrol
26 |
4.90% |
Lucas
6 |
1.13% |
04-09-2020, 07:25 PM
#256
Originally Posted by 2016 4Runner SR5
So far I am sold on this oil over M1 which was horrible, Valvoline which was just as bad.
Please elaborate.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
04-09-2020, 09:04 PM
#257
Oil analysis has shown all the synths can go 10K and be fine.....I change at 7500 so I don't worry much about ''wearing out the oil''......I run M1, Valvoline and the Kirkland in 5/20W and 0/20W. Kirkland was $24 for 10 quarts on sale!
04-09-2020, 09:09 PM
#258
Real Name: Chris
Real Name: Chris
Originally Posted by Lester Lugnut
Please elaborate.
On why they were horrible? The extremely low additive packages in both which make the 4.0 chatter even more than it does normally. Engine was noisier and less smooth with both M1 and Valvoline than it was when using Toyota oil. The 4.0 loves very high amounts of moly. Toyota 0W20 has 789 PPM, M1 has 79 PPM which is why the engine does not run as quiet with the M1 vs the Toyota oil. Valvoline was even lower if I remember correctly. The QSUD is something like 558 PPM so we'll see how the 4.0 likes that when the next oil change rolls around.
04-10-2020, 11:23 AM
#259
No chatter in my '14 4R SR5 - whisper quiet motor. I guess Mobil-1 is providing > PPM in my area.
04-10-2020, 01:33 PM
#260
Whatever has the appropriate rating, weight, and viscocity and most importantly, on sale.
04-13-2020, 02:27 AM
#261
My personal oil guide
here's what I use and keep with me anytime i change my oil...
4Runner_Oil_Change.pdf - Google Drive
04-13-2020, 04:08 AM
#262
Banned
Real Name: Mark
Banned
Real Name: Mark
Originally Posted by DougEFresh2
Your directions have you filling the oil filter canister with new oil before installing it. Then you add an additional 6.6 Qts of new oil. By doing this you risk adding too much oil. The 5th Gens are notorious for being hard to get a good reading from the dipstick. Especially with new light colored synthetic oil. What works for me is not filling the filter before installation, but adding 6.0 Qts, run the engine for a while to distribute the oil and warm it up, let it sit for a few minutes for the oil to settle, then take multiple dipstick readings to “calibrate” your eyes as to where the oil level shows up on the dipstick. Then add a few ounces at a time and take dipstick readings until you reach the full line. It should be close to 6.6 Qts. BTW the 6.6 Qts is not absolute, and is stated to that effect in the manual.
04-13-2020, 06:43 PM
#263
Laugh if you want but I hit the end of the stick with white spray paint so I could see the oil level...........
04-13-2020, 07:36 PM
#264
You can also rough it up with some sandpaper instead of going the paint route. It should help a bunch.
04-14-2020, 12:34 AM
#265
Banned
Real Name: Mark
Banned
Real Name: Mark
I roughed mine up a lot but I still have to angle it just right in the light to see the thin shiny oil on the slightly less shiny stick.
04-14-2020, 07:10 PM
#266
thank you! i appreciate your feedback. I'll probably do a little reworking of this guide to address this oversight. i'm eventually going to use this in my first post, but not yet. there's apparently still some quirks that need ironed out first.
04-14-2020, 10:59 PM
#267
dowutnow?
5th gen 4runner motors sound like diesel engines that knock and tick like crazy. Every single one I've ever heard run.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
04-15-2020, 08:23 AM
#268
Real Name: Chris
Real Name: Chris
Originally Posted by pDubs
dowutnow?
Yep, just the nature of them. The tick is the injectors, I have never heard injectors this loud in my life. I read something where guys were adding 2 cycle oil to the gas and it eliminated 90% of the injector noise. I bought the oil but haven't been brave enough to try it yet lol
04-15-2020, 09:31 AM
#269
Been using Mobil 1 Advanced Fuel Economy since my first oil change. Purchased oil by Walmart and its inexpensive. Owned vehicle since 11 miles and now have almost 55,000. No issues at all.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
04-15-2020, 04:17 PM
#270
Mine takes 6-1/2 quarts. That puts it 2/3 of the way up to the full mark and doesn't use any during a normal interval. I figure another 3.2oz of oil won't make a measurable difference. YMMV.
Between outfits.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
