View Poll Results: Whatís your go to oil?
Toyota Synthetic 104 31.04%
Toyota Synthetic
104 31.04%
Mobile 1 150 44.78%
Mobile 1
150 44.78%
Pennzoil 36 10.75%
Pennzoil
36 10.75%
Quaker State 4 1.19%
Quaker State
4 1.19%
Valvoline 10 2.99%
Valvoline
10 2.99%
Supertech 6 1.79%
Supertech
6 1.79%
Rotella 7 2.09%
Rotella
7 2.09%
Amsoil 32 9.55%
Amsoil
32 9.55%
Redline 4 1.19%
Redline
4 1.19%
Royal Purple 6 1.79%
Royal Purple
6 1.79%
Havoline 3 0.90%
Havoline
3 0.90%
Schaefferís 3 0.90%
Schaefferís
3 0.90%
Motul 8 2.39%
Motul
8 2.39%
Castrol 20 5.97%
Castrol
20 5.97%
Lucas 3 0.90%
Lucas
3 0.90%
Multiple Choice Poll. Voters: 335. You may not vote on this poll
Old 05-21-2020, 08:00 PM #286
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 will become famous soon enough
Hammer0313's Avatar
Real Name: Buck
Originally Posted by MidniteTRD View Post
roger that, fair enough. UOA looks great, thanks for sharing! super low iron, if you're under 1ppm per 1000 miles that's impressive. most 4Runner UOA's show 2-3 ppm per 1000. iron is your valvetrain, timing chain...anything steel. given you probably had to drop an extra gear and climb the RPM's up at altitude that's great wear.
your copper and aluminum will keep dropping and level out at around 30-40k miles. that seems to be where most 4Runner UOA's show those values stabilizing and indicating its actually broken in.
i think you found your blend! i'd go ahead and run that 8-10k with confidence from here on out i might even pick some up for myself sometime...
Yes sir, I was in 2nd gear and 4Hi all the way through the San Juan mountain range. Loaded down the engine was working hard.
5th Gen Oil Recommendation? New Owner!-088d7429-0039-4b29-b0fb-36e7d185dd6a-jpg
2019 TRD Bone Stock
Summer: Amsoil 0w30 - QSUD 5w30
Winter: Amsoil 0w20 - QSUD 0w20 - Toyota 0w20
Diffs: Amsoil Severe Gear
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 08:04 PM #287
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Originally Posted by ElectroBoy View Post
So youíre getting a UOA for every oil change? I can see maybe getting a baseline for the fun of it. Or monitoring an old engine for wear problems. But youíre adding about $30 to each oil change for a new engine.
Not every oil change, I wanted to see how the engine liked the 30 weight oils. Ran two 0w30ís back to back and currently running the Amsoil 5w30 and the engine Loves it, UOAís look good.
2019 TRD Bone Stock
Old 05-22-2020, 08:44 AM #288
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is online now
Real Name: Chris
2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all
Real Name: Chris
I assume the engine is quieter with the 5W30? What climate are you running the 5W30 in currently? Not sure I would want to run that in the winter months but in the summer I don't see it being a problem.
2016 4RUNNER SR5 PURCHASED NEW JANUARY 29TH 2017 - OEM FJ TRD PRO SUSPENSION WITH 3/8 CORNFED TOP HAT SPACERS & 1" PRELOAD SPACER FOR A TOTAL OF 2.5" FRONT LIFT, 2" CORNFED SPACERS IN THE BACK, FX PRO WHEELS, 295/70/17 MICKEY THOMPSON ATZ P3, WEATHER PACKAGE, NAVIGATION, LED INTERIOR LIGHTS, AFE PRO DRY AIR FILTER, BORLA MUFFLER, TYGER SLIDER STEPS, BLACKOUT EMBLEM KIT, TRD PRO GRILL, POLY FRONT AND REAR SWAY BAR BUSHINGS, OEM 3RD GEN REAR SWAY BAR LINKS, REAR DIFF BREATHER MOD, OEM ALUMINUM OIL FILTER HOUSING UPGRADE, OIL CATCH CAN.
2016 4Runner SR5 is online now   Reply With QuoteReply With Quote
Old 05-22-2020, 09:55 AM #289
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
When I can really hear and feel the difference is under throttle getting onto the interstate or passing. The 5w30 really smoothed out the engine overall. Iím in the Georgia/Florida region.
2019 TRD Bone Stock
Old 05-22-2020, 09:59 AM #290
Real Name: Chris
Real Name: Chris
MD until June 11th and then NC for good so we do see cold weather. Not sure I'll try it but I like the idea either way.
Old 05-24-2020, 03:29 PM #291
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH has a spectacular aura about 1000MPH has a spectacular aura about
1000MPH's Avatar
I’m making the switch! Purchased 5W-30 M1 EP for my next oil change.
2010 Trail - 110k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Bridgestone - Dueler A/T REVO 2 (eco) Michelin Defender LXT M/S 36psi - Oil: TGMO 0w-20 M1 EP High Mileage 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 07:51 AM #292
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Originally Posted by 1000MPH View Post
Iím making the switch! Purchased 5W-30 M1 EP for my next oil change.
Your engine is going to Love the 5w30; please let us know how you like it.
2019 TRD Bone Stock
Old 05-26-2020, 08:27 PM #293
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. will become famous soon enough
Tuco S.'s Avatar
a follow up on this - just did a full oil change with QSUD 5W-30, then immediately drove 1400 miles up and down the east coast for Christmas vacation.
fully loaded with luggage and 4 passengers, AND a full Thule Sonic XL cargo box on the roof. still running the factory Dunlop AT20 highway tires. cruise set between 72-75 most of the trip. temps bounced between 65 and 35.
19.5 MPG average according to the trip computer. if we didn't have the cargo box on the roof i'm 100% sure we could have matched or bettered the 20 MPG highway rating. i'm not as concerned about city ratings since that can vary so much based on traffic and driving habits whereas highway driving is more steady state.
i know its not a direct comparison to running 20wt in the sump on the same route, but i think its fair to say you can get so close to (or in some cases, as good as) factory highway ratings running a 30 weight, that it hardly matters.
Thanks for the update!
Glad to see the 5W-30 did very well for you. I agree a small change in oil viscosity barely makes any difference with the 4.0L as far as fuel economy is concerned. Aerodynamics, and specifically air density (cold weather) is what will knock it down 2-4 mpg, depending on how cold it gets where you live.
2019 4Runner TRD Off-Road with KDSS in silver. Adds: Shrockworks sliders and oem led fog lights.
Hood swap?
https://www.toyota-4runner.org/want-...-vegas-nv.html
Tuco S. is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 05:14 PM #294
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Check out the pic of my gauges!!!
Not sure how much fuel loss Iím getting with the 5w30, but Iíll take 21.6 MPGís cruzing at 75 MPH LOL
This was today from Georgia to Florida about 500 miles. ENGINE is Butter Smooth.
5th Gen Oil Recommendation? New Owner!-7a433348-2f43-4a03-a576-1da3a012f91c-jpg
2019 TRD Bone Stock
Old 06-01-2020, 11:15 AM #295
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD is on a distinguished road
MidniteTRD's Avatar
thanks - and agreed. short tripping, aggressive throttle, bad aero, rolling resistance and cold temps as you said have far more effect. not that i'm sweating it too much with a heavy SUV in the first place.
at 75mph, i'd take that number all day and twice on Sunday
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 12:14 PM #296
DEF4Runner's Avatar
DEF4Runner DEF4Runner is online now
DEF4Runner is on a distinguished road
DEF4Runner's Avatar
What app are you using for those numbers?
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is online now   Reply With QuoteReply With Quote
Old 06-01-2020, 04:31 PM #297
JLTD JLTD is offline
JLTD will become famous soon enough
Nice! These engines are specified for thicker oils overseas, not surprised it is doing well for you.
2015 SR5, 65,000 miles
"Works good, lasts long time."
JLTD is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 06:23 PM #298
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I snapped a pic for ya. I got it to monitor my engine oil temperature, transmission temperature, coolant temperature, air intake temperature and battery voltage. But it has Hundreds of options for monitoring so itís very versatile. And it can read/clear trouble codes.
5th Gen Oil Recommendation? New Owner!-baaab81e-ae33-42ce-851e-89767f5d4877-jpg
2019 TRD Bone Stock
Old 07-29-2020, 07:01 PM #299
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Another Amsoil SS UOA, this was 5w30.
5th Gen Oil Recommendation? New Owner!-da86a8ed-b7ed-4e00-aaa8-d267be7067ce-jpg
2019 TRD Bone Stock
Old 07-29-2020, 07:19 PM #300
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all
Damn that copper ppm is definitely higher than mine! (6ppm at 25k). Sure is taking its sweet time to clear out!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
filter , iím , iíve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
