View Poll Results: What’s your go to oil?
Toyota Synthetic 117 30.79%
Toyota Synthetic
117 30.79%
Mobile 1 175 46.05%
Mobile 1
175 46.05%
Pennzoil 37 9.74%
Pennzoil
37 9.74%
Quaker State 5 1.32%
Quaker State
5 1.32%
Valvoline 12 3.16%
Valvoline
12 3.16%
Supertech 9 2.37%
Supertech
9 2.37%
Rotella 8 2.11%
Rotella
8 2.11%
Amsoil 36 9.47%
Amsoil
36 9.47%
Redline 7 1.84%
Redline
7 1.84%
Royal Purple 8 2.11%
Royal Purple
8 2.11%
Havoline 4 1.05%
Havoline
4 1.05%
Schaeffer’s 4 1.05%
Schaeffer’s
4 1.05%
Motul 9 2.37%
Motul
9 2.37%
Castrol 21 5.53%
Castrol
21 5.53%
Lucas 4 1.05%
Lucas
4 1.05%
Multiple Choice Poll. Voters: 380. You may not vote on this poll
Old 07-30-2020, 12:59 AM #301
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH has a spectacular aura about 1000MPH has a spectacular aura about 1000MPH has a spectacular aura about
1000MPH's Avatar
Originally Posted by Hammer0313 View Post
Your engine is going to Love the 5w30; please let us know how you like it.
I made the switch last month before I took a 1200 mile road trip. I did the same trip last year and comparing MPGs does not show any hit with the change in oil viscosity.
Engine seems to love it. Maybe it really does seem quieter.
2010 Trail - 114k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Bridgestone - Dueler A/T REVO 2 (eco) Michelin Defender LXT M/S 36psi - Oil: TGMO 0w-20 M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 04:50 PM #302
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD is on a distinguished road
MidniteTRD's Avatar
Another Amsoil SS UOA, this was 5w30.
solid report. really low AL and iron and the flashpoint is really really high which is great.
i wouldn't sweat the copper one bit. on a lot of the UOA's i've seen for these trucks it doesn't truly level out into the single digits until around 35-40k miles sometimes. its on a downward trend and that's all that matters.
stayed in grade fairly well too. i'd just keep doing what you're doing, all your reports are showing great numbers.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 09:15 PM #303
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna will become famous soon enough
jawkdna's Avatar
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 08:41 PM #304
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
You want the lightest oil that will provide enough film strength to not allow metal to metal contact in the bearing on the rod. More viscosity than that is just heat, less oil pressure and loss of efficiency. Toyota specs the oil with CAFE and warranty on their mind. It does not mean they spec the perfect viscosity for all conditions. That is why they spec a heavier oil in other markets. It is 121 degrees right now at my house which is a hell of alot hotter than Puerto Rico.......
83Mule is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 09:55 AM #305
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 will become famous soon enough
Hammer0313's Avatar
Real Name: Buck
Here is the latest oil report using a 30 weight oil; all is good. Acceleration is smooth and overall really happy with my decision to move up in oil weight.
5th Gen Oil Recommendation? New Owner!-oil-report-jpg
2019 TRD Bone Stock - Engine 5w30/0w30 - Diffs Amsoil Severe Gear - BFG K02
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 11:17 AM #306
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Is your engine running quieter with the 5W30 vs the 0W30 or 0W20? Any difference in performance, MPG, anything like that? I hate the way the 4.0 sounds, I know it's normal, but I still don't like it. Curious if a heavier oil might quiet it up some.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 01:54 PM #307
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
The 5w30 and 0w30 are about the same, cant tell a difference between the two. Both sound much better over the 20 weight oil, MPG's are about the same, as for performance you can tell the engine is moving thicker oil but not a big deal to me. But when you get on the peddle the 30 weight oils really smoothed out the engine through the entire power-ban.
Old 01-08-2021, 10:57 PM #308
1000MPH's Avatar
1000MPH's Avatar
I’ve already commented that I can’t hear a difference on 5w-30.
I also haven’t seen a measurable difference in mileage in town or on road trips.
I’ve been parking outside this winter and startup has sounded no different at 15° F.
Old 01-08-2021, 11:06 PM #309
1000MPH's Avatar
1000MPH's Avatar
This motor reminds me of a 90’s Buick V6 IMSA car with a broken header.
Old 01-08-2021, 11:17 PM #310
Real Name: Chris
Real Name: Chris
It’s about the only thing I don’t like about the 4Runner
Old 01-12-2021, 12:42 PM #311
MidniteTRD's Avatar
MidniteTRD's Avatar
nice report. copper's coming down just like it should with more break-in miles, should be gone by 40k judging by other reports i've seen. if you're keeping these engines at or under 1ppm iron per 1000 miles i'd say the oil's doing an excellent job particularly on an engine with a big steel timing chain like ours. great looking flashpoint too.
no idea what your usage case looks like but my only nitpick is you're draining that pricey Amsoil at half its useful lifespan! its a very thin 30 weight judging by the 100cSt but it seems to be doing the job well.
Old 01-12-2021, 06:37 PM #312
Stabbi Stabbi is offline
Stabbi is on a distinguished road
I did the same thing as you posted earlier, changed oil to 5w30w Amsoil signature, before I made a road trip from Indiana to Arizona and back this past summer. MPG no change, sound-maybe a little more quiet...
Back to 0w-20w Mobile 1 now for winter, temps in teens to 30s mostly. No change in MPG, engine seems a bit louder early on, but quiets down.
now it is probably due to Road Trip v. Around town, but I can tell you my Morimoto oil catch can (5w30w) had a lot less in it than what I have seen in the same miles with 0w20w. Engine temp would have a lot to do with that, but as someone else mentioned on here, thinner oil might burn off more??
anyway, significant difference in the amount of fluids (black smelly stuff) in the can between 5w30 and 0w20. Right now I am blaming the difference on engine run time/temp, but will be moving back to 5w30 in early spring ASAP
Stabbi is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 01:08 PM #313
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Thank you sir, things are coming along nicely. Definitely on the thin side for a 30 weight. I know the oil can run longer but i cant get comfortable with the 10k interval.
Old 01-21-2021, 04:39 PM #314
Irish Mike Irish Mike is offline
Irish Mike is on a distinguished road
Not sure what they use with toyotacare, I have never used that service for reasons just like you posted. Not worth the free oil changes to me, I'll do it myself and know it was done right. The 75LF transfer case fluid isn't cheap but it's cheaper than taking a chance with other fluids and possibly causing damage to your transfer case. Plus I plan on changing it every 50K along with transmission fluid which for me is every 7 years.
We are required to use Genuine Toyota oil in all of the complimentary services. I highly recommend sticking with it.
Irish Mike is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 05:21 PM #315
Real Name: Chris
Real Name: Chris
That's funny because Toyota doesn't make oil. "Toyota" oil is rebranded low end Mobil oil. While the additive package in the "Toyota" oil is very nice, better than quite a few other oils on the market, there are superior oils out there. As for using Toyota Care, never going to happen. Dealer oil change monkeys are clueless and will never touch either of my vehicles.
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
