View Poll Results: What’s your go to oil?
Toyota Synthetic
158 |
29.76% |
Toyota Synthetic
158 |
29.76% |
Mobile 1
247 |
46.52% |
Pennzoil
47 |
8.85% |
Quaker State
7 |
1.32% |
Valvoline
17 |
3.20% |
Supertech
11 |
2.07% |
Rotella
10 |
1.88% |
Amsoil
42 |
7.91% |
Redline
10 |
1.88% |
Royal Purple
14 |
2.64% |
Havoline
4 |
0.75% |
Schaeffer’s
4 |
0.75% |
Motul
13 |
2.45% |
Castrol
26 |
4.90% |
Lucas
6 |
1.13% |
01-08-2022, 03:24 PM
#391
Banned
Real Name: Mark
Banned
Real Name: Mark
Originally Posted by RedZnRunner
Have used mostly 5W-30 Royal Purple in my Nissans. However reading this forum has made me want to go to Toyota brand 0W-20 synthetic changed at 8K km intervals. Toyota adds some additional additives to their oil that changes the content slightly from Mobil 1 EP. Am I wrong or is it just marketing ? Worth note our Runners have the severe side of the service. Winters here range from below 30 F to below -16 F in places like Thunder Bay and Northern Ontario. to above 90 F in summer
You can open up a firehouse of info and opinions when asking about motor oil. I haven’t seen any official confirmation but the popular consensus is that Mobil makes Toyota oil to Toyota’s specs. People have done virgin oil analysis on each and there are differences, one being the Toyota oil has a lot more molybdenum.
01-08-2022, 05:28 PM
#392
I ended up going to a shorter interval with the more available Mobil 1. I’m using the EP (Extension Protection) because it’s about the same price as the AFE when on sale. The shorter interval is because most of my usage is short trips, I only did 6k miles last year. If I end up doing 1000-1200/mo again I’ll adjust my interval accordingly. I also switched to a 5W/30 because it makes me feel better.
01-09-2022, 01:52 PM
#393
Originally Posted by Lexington
I always wonder why dealers and oil change places recommended changing the oil on the 4Runner every 5~6,000 miles instead of 10,000.
i mean, Toyota makes it really clear in their manual just how many use cases kick you down to a 5,000 mile oil change interval, and i think they're overlooked constantly. its pretty clear that unless you're running mostly highway miles unloaded you shouldn't shoot for 10k. towing, running a roof-mounted cargo carrier, heavy loads, extensive idling (how many of us sit in traffic twice a day), repeated sub 5-mile trips in below-freezing weather.....all put you on a 5,000 mile or 6 month interval.
all that stuff is taken directly from the Warranty & Maintenance Guide chart on page 38.
'19 T4R TRD Off-Road | @go_scott_go
01-09-2022, 08:52 PM
#394
Real Name: Chris
Real Name: Chris
Toyota branded oil has significant additives over M1 oil. To be honest, after reading more oil data sheets than I care to remember, M1 really doesn't impress me. I personally no longer run it or believe it's anything special anymore.
01-11-2022, 10:23 AM
#395
Toyota 0W20
Looks like a Toyota 0W20 shortage in CA.
No local dealers have a line of sight on delivery.
Supply chain.
2019 ORP with KDSS on 265/70/17 Goodyear Duratracs
01-13-2022, 08:58 PM
#396
Real Name: Chris
Real Name: Chris
There is a supply issue with all weights and brands. We use 5-40 and 15-40 at work every day and it's been tough getting it. It's apparently a shortage of one of the chemicals used to make synthetic oils that is causing the shortage and most companies use the same chemical so it's across the board.
01-14-2022, 01:42 PM
#397
the toyota oil has a lot of metal protections
01-14-2022, 08:40 PM
#398
Real Name: Chris
Real Name: Chris
I agree completely. It's far superior to M1 as most oils actually are. M1 is nothing special at all IMO Believe it or not, Amazon branded oil and Walmart SuperTech oil both have superior additive packages to M1 oil.
01-15-2022, 05:16 PM
#399
Banned
Real Name: Mark
Banned
Real Name: Mark
So many people have done VOA of Toyota 0W-20. That’s probably why the average column values look that way. Most other brand’s moly number is way below Toyota’s.
01-16-2022, 12:27 AM
#400
I just use EVOO and all is well.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
02-14-2022, 12:00 PM
#401
I have lately been watching video's of car care nut who is a Toyota Technician and a purist for using genuine Toyota oils. His recommendation of oil change intervals are 5k! Never more than that, no matter what the manual or the oil marketing ads say.
https://www.youtube.com/watch?v=xdNCnYHhEm8
02-22-2022, 07:49 PM
#402
Real Name: Buck
Real Name: Buck
The car care nut guy seems to be on point. I like his maintenance interval recommendations.
Another great video:
How to make your Toyota Last Over 300k Miles without Major Repairs - YouTube
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
02-22-2022, 08:22 PM
#403
Originally Posted by krravi
That's the same advice I give my customers.
Sent from my Pixel 3 using Tapatalk
02-22-2022, 08:31 PM
#404
Real Name: Buck
Real Name: Buck
Has anyone tried this Fram full synthetic wire back oil filter? Construction seems solid.
02-24-2022, 12:31 AM
#405
Real Name: Chris
Real Name: Chris
Fram is for people that don't care about their vehicles. Stay away from that junk.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
