View Poll Results: What’s your go to oil?
Toyota Synthetic
158 |
29.76% |
Toyota Synthetic
158 |
29.76% |
Mobile 1
247 |
46.52% |
Pennzoil
47 |
8.85% |
Quaker State
7 |
1.32% |
Valvoline
17 |
3.20% |
Supertech
11 |
2.07% |
Rotella
10 |
1.88% |
Amsoil
42 |
7.91% |
Redline
10 |
1.88% |
Royal Purple
14 |
2.64% |
Havoline
4 |
0.75% |
Schaeffer’s
4 |
0.75% |
Motul
13 |
2.45% |
Castrol
26 |
4.90% |
Lucas
6 |
1.13% |
10-13-2019, 12:26 PM
Real Name: Buck
Real Name: Buck
5th Gen Oil Recommendation? New Owner!
Hello everyone new 2019 TRD Owner; i’ve been surfing around the site the last few days but didn’t see a really good engine oil Thread. I’m new to Toyotas and know nothing about them other than being a reliable Rig. If you could tell me what oil you use, how many miles on your oil change, What oil weight you recommend and how you use your rig? In addition to the oil I’m interested in the oil filters options out there, i’ve never use an oil filter like this before but would like to use a full synthetic spun micro glass oil filter if possible. If you could share your experiences and recommendations I’d be grateful.
I’m really enjoying the site and really enjoying my new 4-Runner. Cheers
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
10-13-2019, 12:41 PM
That's because they are like unicorns.
You haven't looked good enough.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
10-13-2019, 01:02 PM
No need to research. Stick to Toyota oil and filter at the Toyota recommended weight, at the Toyota recommended interval. If you’re looking for advice from random people on a forum, make sure you get their qualifications and find out why they are more knowledgeable than Toyota engineers.
10-13-2019, 02:17 PM
There is a thread by Antman in the mods, writeups sticky that has all you need to know about changing oil including part #s of filter etc. Basically OW20 synthetic and OEM filter cartridge is recommended. Filter cartridges and the housing removal tool are available on Amazon. Interval is in the owners manual . Some members are using a shorter interval if they drive in harsh conditions.
Also, some members report broken skid plate bolts when oil change was done by the dealer. Solution is to remove plate ahead of time and using anti-seize on the bolts before installing. I'm using Mobile1 OW20 FWIW.
10-13-2019, 04:57 PM
You obviously spent little or no time looking.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
10-13-2019, 05:19 PM
can't go wrong with oem toyota and mobile 1
10-13-2019, 05:50 PM
Toyota engineers don't know what they're doing. I know what's best for my truck. Thicker is always better, so I use 90W gear lube in the engine, axle grease in the transfer case and diffs, and roofing tar in the slip yokes and U-joints. Booyah. /s
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
10-13-2019, 05:57 PM
Real Name: Chris
Real Name: Chris
Bought mine brand new. First oil change at 2K, 2nd oil change at 5k, every 5k after that. I have used Mobil 1, Valvoline, and Toyota 0-20 always using OEM filters. Engine runs smoothest and quietest with Toyota oil so that is what I will be sticking with.
Banned
Banned
It really does not matter, its a 4x4 minivan for men with a v6. Put whatever you like or whatever you can afford. Its not a high performance engine.
As long as there is oil in it, it will be fine.
10-13-2019, 06:16 PM
Originally Posted by Owner’s Manual
It’s almost like you didn’t bother to read me...
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
10-13-2019, 06:23 PM
Everyone knows that if you don't use certified toyota, certified oil, your truck will explode.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
10-13-2019, 06:47 PM
Oil attracts dirt.......you don't want dirt IN your engine. Water cleans dirt, and only comes in one Grade so you are good.
10-13-2019, 07:48 PM
Real Name: Buck
Real Name: Buck
Thanks for all the positive posts, I really appreciate it. Still learning how to use this forum. Coming from HD trucks the Toyota is all new to me, so Learning a new rig is exciting, but takes time.
10-13-2019, 07:53 PM
Real Name: Buck
Real Name: Buck
Is this the Toyota oil you use? Genuine Toyota Synthetic SAE 0W-20 API SN
If it is, it looks amazing on paper, look at that Moly. Check out molybdenum basics: Moly Basics
10-13-2019, 08:10 PM
Real Name: Chris
Real Name: Chris
Yes and that's why it runs so much quieter and smoother. These engines need the Moly for whatever reason. Compare Toyota oil to Mobil 1 or Valvoline, Toyota is far superior. Toyota oil is actually made by Mobil but to Toyota spec. Nothing off the shelf has the same packages as the Toyota oil does. IMO Mobil 1 is living off past reputation, kinda like Fram filters. It's not what it used to be.
