View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 10-16-2019, 07:27 PM #61
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Originally Posted by Whippersnapper02 View Post
Apparently you had more time for me to waste. Maybe like having an excess of P and Zn
Today is a new day! You sadly have learned nothing though.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 08:39 PM #62
Whippersnapper02's Avatar
Drink a quart of Z rod Amsoil and call me in the morning.
Old 10-16-2019, 08:42 PM #63
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Many oils use Moly as the heavy lifter for wear, while others prefer to use P and Z to achieve it. There is no one way to get to a reasonable Add Package. And You can have too much of an ingredient.....P and Z will foul the plug electrode at high levels even though those levels are best for the valvetrain. Just keep in mind that MORE of something isn't an indicator of better, there is a lot at play.
83Mule is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 08:52 PM #64
Real Name: Chris
Real Name: Chris
I agree with you on that. You really shouldn't be consuming any oil let alone enough to foul plugs but there is always a little vapor in the system. A cheap and easy way to help limit that is by installing a catch can. Mine catches mostly water but there is definitely oil mixed in there between oil changes.
Old 10-17-2019, 12:37 AM #65
Having a lot of a chemical causing issues was my thinking as well but I'm no chemist.
Old 10-17-2019, 07:49 AM #66
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Here are my two favorite places to look at oils.
If you want to see element analysis, NOACK, cold cranking viscosity, ect. Use this link: http://pqiamerica.com/PCMO_Sample_Su...2_15_2016.html
If you want to see how the oil performs use this link: 540 RAT - Tech Facts, NOT Myths
The Rat oil test site also has a Questions & Answers section were you can ask the guy specific questions and get a answer. He's a Mechanical Engineer by trade. Link is here: Q and A | 540 RAT - Tech Facts, NOT Myths
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 06:39 PM #67
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Got home from work and Amazon had a nice little package waiting for me, got my OEM aluminum oil filter housing in and it looks to be a very good part. I think this is a nice addition. Can anyone tell me about the center tube? Is the one on the aluminum housing the same as the one in our plastic housing?
5th Gen Oil Recommendation? New Owner!-3e8ac5b2-3ad5-49f9-8922-539828834984-jpg  5th Gen Oil Recommendation? New Owner!-7ae79805-02cc-4f5a-b4df-0a60246054ac-jpg  5th Gen Oil Recommendation? New Owner!-1836aff9-bcf6-48e2-b543-56ca1f98d8f0-jpg
Old 10-17-2019, 06:46 PM #68
Real Name: Chris
Real Name: Chris
You'll have to swap the center tube over from your OEM plastic one. They pop right out, no effort at all. I ordered one for my 2019 Highlander since I am getting close to 2K miles so the first oil change will be done in the next couple weeks. Curious to see what center tube is used on that housing.
Old 10-17-2019, 06:59 PM #69
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Thanks man I appreciate the information, I can’t wait to do my first oil change just rolled over 1000 miles LOL.. The center tube looks to be good quality on the aluminum housing but I have nothing to compare it to. It looks to be made of aluminum.
Old 10-17-2019, 07:23 PM #70
Real Name: Chris
Real Name: Chris
Your OEM tube in the plastic housing looks identical but maybe an inch longer? I don't honestly remember, it's been 2.5 years since I swapped mine over.
Old 10-17-2019, 09:01 PM #71
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I extracted a summary of RAT's oil testing from his lengthy and verbose report. He measured wear protection in psi, however he didn't measure Moly, Mag, Zinc and Phos content, so I included Moly and Mag content from PQIA. Higher psi values equate to better wear protection. Over 120,000 psi is fantastic wear protection. 105,000 to 120,000 psi is incredible wear protection. 90,000 to 105,000 psi is outstanding. One may argue that laboratory measurement of wear protection does not simulate how an actual engine wears.
RAT tested Amsoil oils Fall, 2017.
0W20 Amsoil Signature Series, no API designation, synthetic 134,860 psi at 230F. Onset of Thermal Breakdown not specified. Moly and Mag not measured for 0W20. Values for 5W30 are Moly 153 ppm and Mag 19 ppm.
RAT tested the following oils Spring, 2016. These are listed from highest to lowest wear protection (psi).
1. 0W20 Quaker State Ultimate Durability, API SN, synthetic (gold bottle) 124,393 psi at 230F (106,163 psi at 275F). Onset of Thermal Breakdown 270F. Moly 249 ppm. Mag 9 ppm.
2. 0W20 Toyota Motor Oil, API SN, synthetic 101,460 psi at 230F. Onset of Thermal Breakdown 255F. Moly 787 ppm. Mag 674 ppm.
3. 0W20 Mobil 1 Extended Performance, API SN, dexos 1 approved, synthetic 100,229 psi at 230F. Onset of Thermal Breakdown 265F. Moly 85 ppm. Mag 777 ppm.
4. 0W20 Pennzoil Platinum, Pure Plus Technology, made from Natural Gas, API SN, synthetic (silver bottle with blue vertical stripe on the label) 92,504 psi at 230F. Onset of Thermal Breakdown 275F. Moly 57 ppm. Mag 8 ppm.
Toyota Motor Oil has the highest combined Moly and Mag content and the lowest temperature at the onset of thermal breakdown.
DougR is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:45 PM #72
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
That’s a nice sum up of the top five 0w20 oils, interestingly the top 3 are my favorite choices for the Toyota 4.0. Amsoil, QSUD and Toyota all look fantastic to me.
What oil are you running in your rig?
Old 10-18-2019, 05:58 PM #73
DougR's Avatar
DougR's Avatar
That’s a nice sum up of the top five 0w20 oils, interestingly the top 3 are my favorite choices for the Toyota 4.0. Amsoil, QSUD and Toyota all look fantastic to me. What oil are you running in your rig?
Quaker State Ultimate Durability 0W20
Old 10-18-2019, 06:51 PM #74
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
You could take 2 brand new 4Rs and run Walmart Super Tech 0W-20 in one and the most elegant boutique 0W-20 out there in the other and 15-20 years later, both would most likely still be running and performing about the same, moly/mag or no moly/mag.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 07:29 PM #75
83Mule's Avatar
83Mule's Avatar
Yes, Moly content levels are no indicator of the oil's quality or wear results as none of these additives should be in play until metal to metal contact happens through heavy lugging or rod stretching RPMs! Long term tests where engines were run on a dyno for thousands of hours to compare synth and dino in the same grade showed little to no advantage to the synth and in some cases a dino actually had less wear! If you don't exceed the normal parameters of an engine's operation you aren't going to exceed even the most basic approved oil's ability to work well.....changing it on a proper schedule is the bigger factor in longevity of the engine.
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
