View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 01-01-2020, 01:27 PM #196
JayceeP's Avatar
JayceeP JayceeP is offline
JayceeP is on a distinguished road
JayceeP's Avatar
Bought a Toyota for its quality and reliability.... why would you go with anything other than OEM?
2012 Shoreline Blue LE 4WD w/ 3rd Row.
JayceeP is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 01:36 PM #197
sdkosu's Avatar
sdkosu sdkosu is offline
sdkosu is on a distinguished road
sdkosu's Avatar
Originally Posted by josephp732 View Post
I changed out the oil housing to the aluminum version on all three of my 4Runners and I have had the same experience that you described. I was able to easily spin the metal housing all the way up to the mounting base. I have not experienced any leaking to date.
Thanks for the feedback! I'm hoping the new housing works as yours have; it looks better if nothing else (until the unruly skid plate covers it up).
2016 4Runner Limited: Blizzard Pearl/Redwood
XenonDepot 4300k HID - WeatherTech - StopTech Brakes - AVS Bugflector - WizGear Magnetic Phone Mount - Fumoto Drain - Toyota Molded Mudflaps - Carista
sdkosu is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 02:26 PM #198
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by 83Mule View Post
Ambient air temp is not the issue
you're gonna want to fill in Toyota's engineers on that then (ambient temp/viscosity chart on page 337). this is for the FJ sold down under between Feb 2011-Aug 2016.
every car i've owned shows a similar chart in the owners manual. sure, oil temps settle close to water temps just putzing around town but they'll rise independently if you run the engine hard, regardless of water temp. the hotter the ambient temps, the harder it is the for the oil circuit to shed the heat and come back down to normal temps unless you take the load/RPMs off the engine or add a cooler. a good example would be towing a heavy trailer up a long grade in desert heat...extended high RPMs and constant high load.
a Synth is stable to around 425.
i could be wrong but this sounds like you're talking flashpoint, not viscosity. the flashpoint of most synths is between 400-430F. that's where the oil gets so hot that the vapor around it will literally catch on fire if exposed to an ignition source. you're absolutely right though, by that temp you've turned your engine into slag anyway.
oil at 220 is ideal. at 250 degrees the viscosity of an oil will start to dive. by 280F a 20wt is at about half its designated viscosity (using this approximate calculator and this report on TGMO's 40/100C values...start the chart at 100c). bad news for oil pressure.
an extreme example for sure but shows how viscosity dips at higher oil temps in hotter climates.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 02:36 PM #199
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Originally Posted by sdkosu View Post
I just changed my oil & filter, giving the Toyota oil a shot to see if it's worth the extra change and I picked up an aluminum housing as well. Noticed that it spun on much easier than stock plastic and I was actually able to fully seat the housing metal to metal. Same with the drain plug. I double checked the new o-rings and all. I ran the truck to see if any leaks appeared and it looked OK after a few minutes of idle. Did you have the same experience with the new housing or did it fit very snug like the stock plastic?
Metal housing is much smoother. Spins all the way down until the o ring seats and then I snug it. Much nicer install than the plastic housing.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 09:51 PM #200
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
All technically true, but in practice, if you have a functional cooling system you will overheat that before your oil temp ever gets to a damaging temp. I agree that oil temps will fluctuate independently for brief periods, but in normal driving I find that the coolant will keep that range within tolerance for any modern oil. All this being dependent on a cooling system with enough reserve to cover the range......4Runner seems to do that nicely as I live in one of the hottest places cars are used and can't raise the temp more than a tick over the middle of the gauge in 120+ here. Yes, air temp adds a increased load to the system, but it is sized appropriately and can shed the extra heat effectively from my experience.
83Mule is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 08:41 PM #201
MidniteTRD's Avatar
MidniteTRD's Avatar
fair points
i think going by Toyota's 5k mile oil change regimen in those situations doesn't hurt either.
Old 01-03-2020, 02:57 PM #202
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
I need a rear diff breather for my new rig but paying for the ARB is ridiculous. I just need a basic two way valve that will fit, then I can run some basic hose. Do you guys know of anything or the thread dimensions?
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 06:41 PM #203
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Did you mean to post in an engine oil thread?
Anyways, the 3 parts you will need.
Union, part# 90404-51319
Breather, part# 90930-03136
10' or so of 5/16" fuel line
4Runner Rear Diff Breather Extension - Toyota 120 Platforms Forum
or follow any of the ARB instructions, as it's basically same thing.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 06:53 PM #204
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Thank you Sir
Old 01-19-2020, 06:26 PM #205
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
QSUD 5w30 just took 4th Place out of 228 oils tested. Wow!!! See the results for yourself.
MOTOR OIL ENGINEERING TEST DATA | 540 RAT - Tech Facts, NOT Myths
Old 01-19-2020, 07:15 PM #206
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
In the spring of 2016 eight 0W-20 motors oils were tested with these rankings:
“ 1. 0W20 Quaker State Ultimate Durability, API SN, synthetic (gold bottle) = 124,393 psi
Its onset of Thermal Breakdown = 270*F
2. 0W20 Toyota Motor Oil, API SN, synthetic = 101,460 psi
Its onset of Thermal Breakdown = 255*F
3. 0W20 Mobil 1 Extended Performance, API SN, dexos 1 approved, synthetic = 100,229 psi
Its onset of Thermal Breakdown = 265*F
4. 0W20 Pennzoil Platinum, Pure Plus Technology, made from Natural Gas, API SN, synthetic
(silver bottle with blue vertical stripe on the label) = 92,504 psi
It’s onset of Thermal Breakdown = 275*F
5. 0W20 Castrol Edge, Fluid Titanium Technology, API SN, dexos 1 approved, synthetic
(black bottle) = 90,745 psi
It’s onset of Thermal Breakdown = 270*F
6. 0W20 Valvoline SynPower, API SN, synthetic = 89,556 psi
7. 0W20 Mobil 1 Advance Fuel Economy, API SN, dexos 1 approved, synthetic = 79,612 psi
8. 0W20 Kendall GT-1, with liquid Titanium, API SN, synthetic = 71,385 psi
It’s onset of Thermal Breakdown = 260*F .”
Old 01-19-2020, 07:56 PM #207
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Yep, QSUD has been one of the most consistent oils being made, despite the move to SN Plus. Qudos to QS for being so consistent! Add the Walmart price and its hard to beat.
20 weight oils definitely have their place, guys up in Canada are eliminating piston slap in the 5.7 Hemi with 0w20’s in the freezing cold. The move to 20 weight oil is a double edged sword imo. It has forced oil manufacturers to develop better oils but the service range is limited.
Old 01-20-2020, 08:34 AM #208
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
FYI, you can get the Rotella Gas Truck oil for $8/5qts from TSC store with the $10 rebate.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 09:15 AM #209
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Originally Posted by 2016 4Runner SR5 View Post
Yes and that's why it runs so much quieter and smoother. These engines need the Moly for whatever reason. Compare Toyota oil to Mobil 1 or Valvoline, Toyota is far superior. Toyota oil is actually made by Mobil but to Toyota spec. Nothing off the shelf has the same packages as the Toyota oil does. IMO Mobil 1 is living off past reputation, kinda like Fram filters. It's not what it used to be.
Good information
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 09:16 AM #210
Is this the Toyota oil you use? Genuine Toyota Synthetic SAE 0W-20 API SN
If it is, it looks amazing on paper, look at that Moly. Check out molybdenum basics: Moly Basics
Interesting links
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
