View Poll Results: What’s your go to oil?
Toyota Synthetic 158 29.76%
Toyota Synthetic
158 29.76%
Mobile 1 247 46.52%
Mobile 1
247 46.52%
Pennzoil 47 8.85%
Pennzoil
47 8.85%
Quaker State 7 1.32%
Quaker State
7 1.32%
Valvoline 17 3.20%
Valvoline
17 3.20%
Supertech 11 2.07%
Supertech
11 2.07%
Rotella 10 1.88%
Rotella
10 1.88%
Amsoil 42 7.91%
Amsoil
42 7.91%
Redline 10 1.88%
Redline
10 1.88%
Royal Purple 14 2.64%
Royal Purple
14 2.64%
Havoline 4 0.75%
Havoline
4 0.75%
Schaeffer’s 4 0.75%
Schaeffer’s
4 0.75%
Motul 13 2.45%
Motul
13 2.45%
Castrol 26 4.90%
Castrol
26 4.90%
Lucas 6 1.13%
Lucas
6 1.13%
Multiple Choice Poll. Voters: 531. You may not vote on this poll
Old 02-07-2020, 12:38 PM #241
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Redline 0w20 added to the rankings; if anyone wants something added please let me know and ill get it out as soon as i can.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 03:33 PM #242
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Here’s a pic of the cSt rankings, this might be easier to see on a mobile device.
5th Gen Oil Recommendation? New Owner!-fe45b37c-d12a-4a7a-946b-7c5d2702886c-jpg
Old 02-07-2020, 06:23 PM #243
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Originally Posted by Hammer0313 View Post
The service range of the Toyota 0w20 is far superior to the other 0w20 oils i looked at; take a look at the attachment. At -20 degrees Fahrenheit the Toyota oil is shockingly far better, and on the top end at 250 degree Fahrenheit its right there with the rest. Fantastic service range!
Ah I agree, the Toyota oil is a superior oil to all others. It's all I run in my 4Runner after trying Mobil 1 and Valvoline and there was significantly more valvetrain noise with both. Toyota doesn't make oil though, it's actually made by Mobil oil company. It's just made to Toyota spec with nothing else comes close to matching.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 03:45 PM #244
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Changing Rear Diff Fluid Every 30k?
This is a good example of what happens to your rear differential fluid; in the video they only go up to 30 mph but imagine zipping up and down the highway at 80 miles an hour what that fluid action would look like? Rear differential fluid gets beat in this extreme environment, add heat and aeration and you can understand why this fluid needs to be on a good maintenance schedule.
My Dad taught me back in the early 90’s that you need to change the rear diff fluid every 30k miles; I know lubrication has evolved since then but it really is good advice.
YouTube
Old 02-10-2020, 05:27 AM #245
MartyGrant MartyGrant is offline
MartyGrant is on a distinguished road
Well Hammer0313, my go to oil is PP which is a ChinaMart bargin.
Redline, Amsoil are overpriced and/or a hassle to get...Mob1 is Very Good stuff and if 3 bucks cheaper at ChinaMArt I'd abandon PP. Toyota would be my last choice. Thank you for asking what my go to oil is. Happy Trails.
MartyGrant is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 06:47 PM #246
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Amsoil 0w30 UOA
5th Gen Oil Recommendation? New Owner!-882ab76f-a04b-41cf-a757-bcd9635e57d5-jpg
Old 03-30-2020, 07:23 PM #247
Maka15's Avatar
Maka15 Maka15 is offline
Maka15 will become famous soon enough
Maka15's Avatar
I went with Mobil1 and standard Toyota filter.
Maka15 is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 02:42 PM #248
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Amsoil 0w30 UOA
nice report but only 4300 miles on Signature Series stuff....you drained it way early! any particular reason for doing so or were you concerned you'd still be seeing a lot of break-in material? you could more than double that run, between the high TBN and stable viscosity that blend is known for.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 03:31 PM #249
Real Name: Chris
Real Name: Chris
A couple weeks ago I did the 2nd oil change on my 2019 Highlander with the 3.5L V6 First was done at 2000 miles, 2nd at 5000 miles, and I will change the oil every 5000 miles going forward. I follow this schedule with my 2016 4Runner as well. Anyway, I used the Quaker State Ultimate Durability 0W20 since it was so cheap and easy to get and I used an OEM filter as I always do. I have to say, I'm impressed. The 3.5 runs smoother and quieter with the QS over even the Toyota oil. I will be using the QSUD in my 2016 4Runner when it's due for it's next service and I will of course post results on that as well. So far I am sold on this oil over M1 which was horrible, Valvoline which was just as bad, and Toyota oil which I was happy with but it's twice the price and I have to go to the dealer or order online to get it.
Old 04-08-2020, 07:47 PM #250
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Costco Kirkland 0-20w looks like a great deal. Warren Oil makes it and the price is great for a full Synth.
83Mule is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 11:24 PM #251
Real Name: Chris
Real Name: Chris
Same as Amazon brand oil and Walmart brand oil. All made by Warren.
Old 04-08-2020, 11:47 PM #252
jmasse jmasse is offline
jmasse is on a distinguished road
Interesting reading here. These motors are not high performance or anything new for that matter. Change the oil every 5K or so and don't overthink it.
jmasse is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 12:12 AM #253
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Thats how I see it. As long as you have the API seal on the oil bottle, I believe you should be fine with normal driving that 99% of the people mostly do. I use the cheapest full synthetic and its usually Super Tech which has good test results on Project Farms YT videos.
mcat707 is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 10:45 AM #254
Real Name: Chris
Real Name: Chris
I’ve used that before also but not in my 4Runner. Project Farm does have some awesome videos. Amazon oil actually beat M1 but not really surprised. I’m really not impressed with M1 engine oil at all.
Old 04-09-2020, 01:44 PM #255
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
According to Project Farm Amsoil won followed very closely by Pennzoil. Pennzoil is cheaper than Amsoil and easier to find around here so I went with it for my first and so far only oil change. Engine runs quietly and it hasn't used any oil at all. I don't drive much these days so since the oil change late last summer I've only put on about 1,500 miles. I'll be doing another change at about 2,000 due to time instead of my usual 5,000 miles. Probably over kill but it'll make me feel better.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
filter , i’m , i’ve , oil , rig
New T4R Owner Long Time Toyota Owner GD2013 New Members 7 07-31-2019 08:28 PM
Oil recommendation? JeffMerr 4th Gen T4Rs 46 06-06-2018 10:05 AM
Come along recommendation PROFILER General Discussions 18 01-17-2015 02:32 AM
DMM recommendation? SUBTEGRAL Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-21-2012 06:55 PM
Recommendation on oil changes. RJS-T4R 5th gen T4Rs 184 03-26-2012 10:32 AM
