View Poll Results: What’s your go to oil?
Toyota Synthetic
158 |
29.76% |
Toyota Synthetic
158 |
29.76% |
Mobile 1
247 |
46.52% |
Pennzoil
47 |
8.85% |
Quaker State
7 |
1.32% |
Valvoline
17 |
3.20% |
Supertech
11 |
2.07% |
Rotella
10 |
1.88% |
Amsoil
42 |
7.91% |
Redline
10 |
1.88% |
Royal Purple
14 |
2.64% |
Havoline
4 |
0.75% |
Schaeffer’s
4 |
0.75% |
Motul
13 |
2.45% |
Castrol
26 |
4.90% |
Lucas
6 |
1.13% |
05-21-2020, 08:00 PM
#286
Real Name: Buck
Real Name: Buck
Originally Posted by MidniteTRD
roger that, fair enough. UOA looks great, thanks for sharing! super low iron, if you're under 1ppm per 1000 miles that's impressive. most 4Runner UOA's show 2-3 ppm per 1000. iron is your valvetrain, timing chain...anything steel. given you probably had to drop an extra gear and climb the RPM's up at altitude that's great wear.
your copper and aluminum will keep dropping and level out at around 30-40k miles. that seems to be where most 4Runner UOA's show those values stabilizing and indicating its actually broken in.
i think you found your blend! i'd go ahead and run that 8-10k with confidence from here on out i might even pick some up for myself sometime...
Yes sir, I was in 2nd gear and 4Hi all the way through the San Juan mountain range. Loaded down the engine was working hard.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
05-21-2020, 08:04 PM
#287
Real Name: Buck
Real Name: Buck
Originally Posted by ElectroBoy
So you’re getting a UOA for every oil change? I can see maybe getting a baseline for the fun of it. Or monitoring an old engine for wear problems. But you’re adding about $30 to each oil change for a new engine.
Not every oil change, I wanted to see how the engine liked the 30 weight oils. Ran two 0w30’s back to back and currently running the Amsoil 5w30 and the engine Loves it, UOA’s look good.
05-22-2020, 08:44 AM
#288
Real Name: Chris
Real Name: Chris
I assume the engine is quieter with the 5W30? What climate are you running the 5W30 in currently? Not sure I would want to run that in the winter months but in the summer I don't see it being a problem.
05-22-2020, 09:55 AM
#289
Real Name: Buck
Real Name: Buck
When I can really hear and feel the difference is under throttle getting onto the interstate or passing. The 5w30 really smoothed out the engine overall. I’m in the Georgia/Florida region.
05-22-2020, 09:59 AM
#290
Real Name: Chris
Real Name: Chris
MD until June 11th and then NC for good so we do see cold weather. Not sure I'll try it but I like the idea either way.
05-24-2020, 03:29 PM
#291
I’m making the switch! Purchased 5W-30 M1 EP for my next oil change.
05-25-2020, 07:51 AM
#292
Real Name: Buck
Real Name: Buck
Your engine is going to Love the 5w30; please let us know how you like it.
05-26-2020, 08:27 PM
#293
a follow up on this - just did a full oil change with QSUD 5W-30, then immediately drove 1400 miles up and down the east coast for Christmas vacation.
fully loaded with luggage and 4 passengers, AND a full Thule Sonic XL cargo box on the roof. still running the factory Dunlop AT20 highway tires. cruise set between 72-75 most of the trip. temps bounced between 65 and 35.
19.5 MPG average according to the trip computer. if we didn't have the cargo box on the roof i'm 100% sure we could have matched or bettered the 20 MPG highway rating. i'm not as concerned about city ratings since that can vary so much based on traffic and driving habits whereas highway driving is more steady state.
i know its not a direct comparison to running 20wt in the sump on the same route, but i think its fair to say you can get so close to (or in some cases, as good as) factory highway ratings running a 30 weight, that it hardly matters.
Thanks for the update!
Glad to see the 5W-30 did very well for you. I agree a small change in oil viscosity barely makes any difference with the 4.0L as far as fuel economy is concerned. Aerodynamics, and specifically air density (cold weather) is what will knock it down 2-4 mpg, depending on how cold it gets where you live.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
05-30-2020, 05:14 PM
#294
Real Name: Buck
Real Name: Buck
Check out the pic of my gauges!!!
Not sure how much fuel loss I’m getting with the 5w30, but I’ll take 21.6 MPG’s cruzing at 75 MPH LOL
This was today from Georgia to Florida about 500 miles. ENGINE is Butter Smooth.
06-01-2020, 11:15 AM
#295
thanks - and agreed. short tripping, aggressive throttle, bad aero, rolling resistance and cold temps as you said have far more effect. not that i'm sweating it too much with a heavy SUV in the first place.
at 75mph, i'd take that number all day and twice on Sunday
'19 T4R TRD Off-Road | @go_scott_go
06-01-2020, 12:14 PM
#296
What app are you using for those numbers?
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
06-01-2020, 04:31 PM
#297
Nice! These engines are specified for thicker oils overseas, not surprised it is doing well for you.
Between outfits.
06-01-2020, 06:23 PM
#298
Real Name: Buck
Real Name: Buck
I snapped a pic for ya. I got it to monitor my engine oil temperature, transmission temperature, coolant temperature, air intake temperature and battery voltage. But it has Hundreds of options for monitoring so it’s very versatile. And it can read/clear trouble codes.
07-29-2020, 07:01 PM
#299
Real Name: Buck
Real Name: Buck
Another Amsoil SS UOA, this was 5w30.
07-29-2020, 07:19 PM
#300
Damn that copper ppm is definitely higher than mine! (6ppm at 25k). Sure is taking its sweet time to clear out!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
