Old 10-22-2022, 01:03 PM #46
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
It’s not that wild - I run 40-45 PSI in all my tires, including BFG’s, and get 60k miles out of them because they wear slowly and evenly.
The pictures of tires worn on the edges (underinflation) and centers (overinflation) are examples of EXTREME cases of each. Tire shops love to display these.
But they won’t tell you that in order to produce those exaggerated examples, you need about 20 PSI under or over the recommended pressures, not just 10.
You are free to follow your door jamb sticker from the factory (generally lower) or your tire company’s info (generally higher) but I have run each set of tires in all of the vehicles I’ve owed, collectively at least 10 sets, and have ALWAYS exceeded the mileage rated by 10-20k miles before the tread depth indicated replacement was due.
I’ve never let a set run bald just to squeeze more mileage out of them. This is legal mileage I’ve achieved with an SUV’s weight, 4500-5500 pounds, spread over four 40-45 PSI tires.
You WILL notice a rolling resistance difference between 35 PSI and 45 PSI, but your tires with wear deceptively evenly under both. 45 PSI they just last a little longer.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 10-22-2022, 05:49 PM #47
Gstick Gstick is offline
Gstick will become famous soon enough
I guess that you could call me a BFG KO2 "fanboy" since I have been using them for over 35 years on various 4x4 vehicles. (1/2 ton Chevys/GMC & now exclusively 4R's) On my 4R's, I have had the best wear mileage running between 38-41 PSI. But I'm not saying that you are wrong running 45 PSI. Rarely do I have more than 1 passenger or heavy gear in the back. If my 4R was loaded down more often than not, I would probably up the pressure to 45.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 10-22-2022, 07:10 PM #48
I really wish they would go back to the old design. The KO2 revision with the “flame sidewalls” looks gimmicky and now looks like everyone else.
I forgot when they changed, 2013 or whatnot. They’re the first tire I search for when it’s time for a new set.
Old 10-22-2022, 07:55 PM #49
Captain Spalding's Avatar
Captain Spalding Captain Spalding is offline
Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about
I’ve had KO’s on multiple vehicles too. They were solid performers. Oddly, BF Goodrich does not recommend them for the 2022 4Runner. When I saw that on their site I emailed to double check, and sure enough their representative confirmed it. I’m still on the stock Dunlops and researching AT tires.
Yes I agree. The sculpted sidewalls are kid stuff.
Captain Spalding is offline   Reply With QuoteReply With Quote
Old 10-22-2022, 10:17 PM #50
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
44psi is because they are an LT tire and not a P tire. The higher inflation acieves the same weight rating as the stock P tire listed on the door jam.
Ive been running the 44 with no issues, just a rougher ride than 32 on the P. If they made a KO2 in P id be all over it for the lower pressure and better ride. Less jarring on the suspension, etc.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-22-2022, 10:27 PM #51
And perhaps the most ironic is an E rated BFG KO2 (265/70R17 specifically) ride softest with a 5000 lb vehicle at 45 PSI. Anything less, you lose steering feedback, anything more will firm up the ride significantly.
Old 10-24-2022, 10:25 AM #52
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
How are you determining the proper PSI? Does BFG have a chart or is there some online calculator for this? I just always assumed you went by the PSI on the side of the door? Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 01:58 PM #53
Jivewalker's Avatar
Jivewalker's Avatar
Load inflation tables. When change from stock rated tires, say Pmetric to LT, you have to recalculate the PSI. Link below describes the process and math.
https://www.toyotires.com/media/pxcj...s_20200723.pdf
I am fragile.
Not like a flower.
But like a bomb.
Old 10-24-2022, 04:09 PM #54
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Are you running E-Load at that pressure like the ones he showed in the pic? Curious how firm an E-Load KO2 rides at that pressure. My 265/70r17 KO2s I had were the C-load and were noticeably firmer than stock even at 32PSI.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 10-31-2022, 09:15 PM #55
Lexington's Avatar
Lexington's Avatar
Originally Posted by AK Mule View Post
The "P" to "LT" is correct, and a bigger tire will hold more air. More air (volume) is not more pressure, though. Actually, a bigger tire can have a larger load rating at the same pressure. It has more air (volume) to hold up the weight, and doesn't always need more pressure, if they are both "P" or both "LT". In this case, switching from "P" to "LT" is the reason for the pressure increase.
If you went from one size "LT" tire to a larger "LT" tire, you could decrease the pressure and have the same load rating because you have more volume. Volume is constrained by the size of the tire, pressure is not. Volume holds up the truck, not just pressure.
AK Mule. When you talk about “P” and “LT” tires. Are these letters in front of the tire size? Example,
LT265/70R17 or P265/70R17
Old 10-31-2022, 11:16 PM #56
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
LT tires need more air pressure.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 11-01-2022, 03:11 AM #57
Lexington's Avatar
Lexington's Avatar
Originally Posted by Bmnorm2 View Post
Yes I’m aware of this. My question was about identifying which tires you have.
Old 11-01-2022, 07:22 AM #58
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Yes you are correct. it would say LT or P. and at the end it would say the load rating(C, D, E etc).
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 11-01-2022, 03:38 PM #59
Lexington's Avatar
Lexington's Avatar
Thanks!
Until I read this post I was never aware that LT tires should run at higher PSI. I always went by what was on my door +5 PSI to improve gas mileage. Even my tire shop said they just go by the PSI listed on the door. I did call BFG and they told me they recommended 44 PSI for LT tires on the 5th Gen 4Runner. I did read that many people here prefer to run them at 40 PSI.
Curiosity question. If you run LT tires at 32 PSI listed on the door, can that cause any safety issues or does it just only means you will have less fuel efficiency and uneven wear?
Thanks again.
Old 11-01-2022, 04:08 PM #60
mainerunr mainerunr is offline
mainerunr is on a distinguished road
Thanks!
Thanks again.
I actually had a tire tech argue with me about tire pressure until his boss came over and asked what pressure I wanted in the tires and told his guy to do that. I did at one point mention that I shouldn't know more about tires than he does.
I will say, I am impressed by this site so far, I'm used to people saying they run max PSI because that's what it says on the sidewall...or they run what's on the door sticker but very few in between.
mainerunr is offline   Reply With QuoteReply With Quote
inflation , pressure , raise , site , tire
Mildly interesting: This site has more trackers than any site I've ever seen rob_dixon Off Topic 3 08-31-2019 03:31 AM
Interesting Used Parts site. SilverRidgeRunner1 3rd gen T4Rs 12 01-08-2016 10:51 PM
Interesting site on oil quality... jwyshrek Off Topic 0 01-20-2014 12:24 PM
Tire Pressure Sensor - Spare tire Tdub 4th Gen T4Rs 3 09-01-2008 10:49 AM
Tire Pressure & Max Rated Tire Pressure Phil 4th Gen T4Rs 7 03-10-2004 10:49 PM
