Old 10-14-2019, 10:37 PM #1
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
S mode...
2020 SR5 PREMIUM 4WD GRAY METALLIC YADA YADA WITH REVERSE.
SAFE for tranny TO SHIFT TO S mode when driving lets say like at 40 mph.
How about back into regular d when in 4th and rpms are climbing and you want 5th ok to do so in motion and with acceleretar pressed?
  Reply With QuoteReply With Quote
Old 10-14-2019, 10:56 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Yes. Also s5 is same as D
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 11:04 PM #3
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Didnt realize Reverse was an option. Wish my SR5 had that..
Yes it is safe. It is why the feature exists. In my experience Its seamless going back and forth. When moving and you switch to S it will usually default select one gear lower than it is currently in. Going back to Drive will not necessarily upshift but will turn control back to the computer.
Obviously be careful downshifting at high rpm. And when using 4L w/engine braking use EXTRA foot brake ahead of your downshift to save your neck and tranny.
El Dusty is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 11:36 PM #4
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Have you never had an automatic?
llDemonll is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 12:00 AM #5
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
My older daily driver ford ranger is stick.
My 2017 corolla SE CVT AUTO THAT had S and you moved up or down ACTUALLY shifted,
But on 4 runner at 1st i thought it shifted, but it does not. Now i know it simply is a digital
4
3
2
1
Position on an old school auto shifter.
Now I know after searching it sets the highest gear u want it to shift to. It can still shift up but only if computer thinks it should kinda like approaching red line.
Old 10-15-2019, 03:04 AM #6
fixer5000 fixer5000 is offline
Real Name: steve
fixer5000 is on a distinguished road
Real Name: steve
i always just put it in s mode and push the shifter up. this also makes that stupid eco bar go away lol
" GET THERE FAST BUT ARRIVE ALIVE "
fixer5000 is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 10:10 PM #7
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
If it's not safe (for the mechanical bits) the t4r will just beep at you and ignore your request.
You're on your own for the safeness of the driving conditions.
You can turn this off so you never see it.........
nglayton is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 12:14 AM #8
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I tend to keep it in S5 most of the time on trips to make it easier to shift into 4th for hills. Much easier on the cruise control IMO.
1000MPH is offline   Reply With QuoteReply With Quote
4th , mode , regular , rpms , yada
Switching from shift mode to drive mode Happy 1 5th gen T4Rs 31 05-12-2017 12:34 PM
2009 Limited V6 Multi Mode 4wd in 2wd mode JCSTEW 4th Gen T4Rs 2 09-11-2015 07:52 PM
Nav Day Mode Dozerdog 5th gen T4Rs 4 02-18-2012 10:36 AM
V6 - 2WD vs 4WD mode - mpg Gecko123 4th Gen T4Rs 4 11-05-2011 04:53 PM
V6 Gas Mileage: 2wd mode VS 4wd mode the_josh 4th Gen T4Rs 0 11-12-2004 01:33 PM
