Old 11-18-2020, 09:50 AM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
Grayish rear diff fluid
Hello,
I replaced my rear diff fluid on my 2016 limited with 48k miles . Mine took about 3 quarts. Oil condition was absolutely terrible. It was grayish color. Never seen that before. Does that grayish color mean anything?
Thanks
amir_gh is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 10:34 AM #2
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
sounds like maybe some water got into the diff thru the breather? Either that or you are cooking fluid. are u running 6s down the 1/4?
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 10:38 AM #3
amir_gh's Avatar
amir_gh's Avatar
Got my truck used. Everything is stock. No modifications. Previews owner never replaced it
Old 11-18-2020, 10:42 AM #4
bak3rme's Avatar
bak3rme's Avatar
I'd say get underneath and look on top of the diff for the diff breather. is there fluid coming out from that area? My guess is that maybe water somehow went through there and mixed with diff fluid. Interested to hear what others have to say about this.
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 11-18-2020, 10:43 AM #5
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Sounds like water contamination. It wouldn't necessarily have to come in through the breather. If the rear was hot and took a trip through a nice cold stream, water can be pulled in by vacuum through the rear axle. This is why people install elevated rear breathers that stay open to atmosphere.
5thToy is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 11:19 AM #6
sawman1's Avatar
sawman1 sawman1 is offline
sawman1 is on a distinguished road
sawman1's Avatar
Almost guaranteed water intrusion. As noted above, check the breather for possible intrusion. If all appears OK, I would run it for a bit and service it again to be sure the fluid looks OK, or at minimum pull a sample to inspect. 20+ years in the business so I am going off some experience when I type this. Best to you.
sawman1 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 11:29 AM #7
amir_gh's Avatar
amir_gh's Avatar
Thanks. I will keep eye on it.
Old 11-18-2020, 11:40 AM #8
amir_gh's Avatar
amir_gh's Avatar
Any suggestions for Diff breather kit? Can I do this myself?
Thanks
Old 11-18-2020, 11:53 AM #9
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Originally Posted by amir_gh View Post
Hello,
Thanks
I did mine after ten years. Color was pitch black. Gray might indicate some moisture, might not mean anything.
Check it in three years again.
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:14 PM #10
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
Hmm... Truck might have been in a flood ? I'd check the other differential, trans, and transfer case.
Twilghtzone is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:29 PM #11
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Greyish diff fluid in a 4runner is hardly enough evidence to say it may be a flood vehicle.
As other mentioned, if you went through a water crossing or even big enough puddle on road water could have gotten in. I would change again in like 10k miles and check since it's easy enough to do.
I did the ARB diff breather kit just because it was already all pieced together but there's a few cheaper ways to get the breather and bung from Toyota and use fuel line to run up to engine bay or near gas filler.
Amazon.com: ARB Differential Breather Kit (170112): Automotive
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:31 PM #12
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Water intrusion during some type of water crossing IS the most likely culprit, doesn't have to be off road.
If there's water in one diff, as others said I'd check everything else, too.
PO wasn't from Houston, was he?
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:54 PM #13
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Hello,
Thanks
Was it more like graphite, or milky?
Graphite color is OK. Milky means water.
delloro is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 12:57 PM #14
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Yeah, after almost 90k on factory fluid I'd suspect a little bit of metal flakes in there, almost like the color of never seize. I wouldn't rule out water intrusion though either and I'd bet you're good for a while now that it's all cleaned up and fresh.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 01:14 PM #15
amir_gh's Avatar
amir_gh's Avatar
defiantly graphite
color , diff , fluid , grayish , replaced
rear diff fluid question Army97 3rd gen T4Rs 34 12-01-2022 03:22 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
QQ on rear diff fluid change on my LE bowhun2r 5th gen T4Rs 3 07-17-2016 06:03 PM
4th Gen rear diff fluid texasrock Maintenance/Detailing 12 09-29-2014 06:41 PM
Replaced rear diff w/ only 3 qts?? Caughron 4th Gen T4Rs 9 01-25-2011 06:57 PM
