10-19-2019, 06:52 PM
Fresh Coffee Kit for the Trail
Wanted to share a really cool everyday carry I put together for my 5th Gen: A road coffee kit.
Goal: Be able to pull over and make awesome pour-over coffee -- not B.S. instant coffee, but real coffee -- on the go, either for the trails or whenever I get sick of sitting in San Francisco Bay Area traffic and need a break.
What's in the Kit:
1) A hand-crank coffee grinder and a jar for beans. I went with this awesome little grinder:
2) A backpacking stove and fuel to heat up your water on the side of the road:
3) A light-weight pour-over cone, filters, and a pot to heat your water in. For the cone I went with this guy:
4) Finally, a mug, a can of condensed milk for creamer (if you're into that), a spoon to stir, and some baggies for your used coffee filter once you're done (unless you're planning to toss on the side of the road):
5) A bag to throw everything into. I used this really cool mil spec mesh bag from Raingler:
And here's the set up in action. Really fun excuse to pull off, take a break, and pop open the hatch for some fresh coffee:
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
10-20-2019, 01:06 AM
Very nice. I have a similar style grinder. As far as that style of pour over goes I found that I almost always had cold coffee. I went with one of these and have been very happy. Keep in mind I'm almost always in the mountains in Colorado so mornings are always chilly to cold. And I hate cold coffee too
https://www.target.com/p/bialetti-mo...r/-/A-14655160
10-20-2019, 01:52 AM
folgers in a pinch, but i use aero press for everything else.
10-20-2019, 03:10 AM
Yup that's like the futuristic french press. Cafe Du Monde style here, ca phe sau da
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
I also grind my coffee before hand and vacuum seal it before my trip... These are my leftovers for reference..
Sent from my iPhone using Tapatalk Pro
17 TRDOR | Metal Tech OPOR sliders | Summit Wheels | Wildpeak 285/70/17 | 5100's / C59-302 w 1/4" plate driver's side / C59-505 w/ 10mm packer | Prinsu full rack/GOBI ladder | C4FAB lo-pro bumper w/high clearance | Sprint Booster | RoofNest Falcon RTT | Ellis Precision knobs | BPF molle panel | Rago center console molle
10-20-2019, 03:23 AM
Dude that's a perfect morning kit right there, bacon, tooth brush, Hawaiian roles. To top it off, that wilco/detours could possibly double as a morning shit can if you position yourself accordingly.
10-20-2019, 03:30 AM
you forgot the SPAM next to the bacon
10-20-2019, 03:35 AM
I was too focused on the uncut game meat properly vac sealed.
10-20-2019, 03:41 AM
All of that is a party stacker for SURE
Go Stros!
10-20-2019, 06:57 AM
Ah yes the moka. I have the same one, bought in Italy when we lived there. Nice enough for two people, plenty for one, and makes a damn strong cup.
I used mine on a campfire griddle plate a few times but i really need a small propane heater.
2019 TRD Pro Voodoo Blue "Cobra Commander"
10-20-2019, 11:31 AM
Banned
Real Name: Mark
Banned
Real Name: Mark
Your pre-grind, pre-measure, vacuum seal method is a great idea. Hand grinding on the road is a slow process and a pain in the arm for two people at two cups each.
10-20-2019, 11:42 AM
Banned
Real Name: Mark
Banned
Real Name: Mark
mmmmm... fried Spam on Hawaiian rolls...
10-20-2019, 02:45 PM
I use a burr hand grinder https://www.amazon.com/JavaPresse-Gr.../dp/B013R3Q7B2 for all my grinds.
Pour over is my favorite
Aero press gets me up quick
French press for the the crew
I want to go camping now
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
