Old 10-21-2019, 04:17 PM #1
KYTRDPRO KYTRDPRO is offline
KYTRDPRO is on a distinguished road
5th Gen Reverse Aux Lights
Hey all:
I've searched a good amount but I am also a electrical novice, so maybe the information I'm seeing I am simply unable to digest.
I currently have a relay/wiring harness ran from the battery to the rear of the vehicle to power two reverse-facing auxilary lights.
I purchased the wiring harness with a wireless remote. They work totally fine and are able to strobe, etc. but I want one more component for them: I would like for these to automatically come on when the vehicle is in Reverse.
Can someone please help me? I do apologize for asking the question in a different way but the diagrams I have seen are on Photobucket and they are blurry in all of the threads.
Thanks so much for the help.
Christian
KYTRDPRO is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 04:22 PM #2
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
can you turn them on and off with a physical switch, or do you have to use the wireless remote?
you can trigger a relay with the existing reverse lights, but that only works if you can turn them on and off without using the wireless remote
jhguth is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 06:40 PM #3
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
You've already got a power source run from the battery, and it sounds like the lights are controlled through a module (and wireless remote). Before you do this ensure the power module is supplying a 12v current to the lights.
I'd splice into the Batt+ somewhere before the control module, and wire it through a relay to the +Feed PAST the control module directly into the lights. To control the relay can splice into the reverse light wire, or the reverse switch in the center console shifter. This will retain the wireless control module & add another power source around the power module which will let you use the remote and automatically activate when you shift to reverse.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 10:08 PM #4
I appreciate you taking the time to reply!
I do have the option to turn it on and off with a physical switch, yes.
So both options: wireless and switched.
Here is a link to the harness if it helps at all:
Northpole Light Remote Control Wiring Harness for LED Light Bar, 40A Fuse Remote On Off Switch Relay Wiring Harness for LED Work Lights Driving fog lights https://www.amazon.com/dp/B01M02ZFT8..._OiMRDb8WR29VV
Old 10-21-2019, 10:09 PM #5
I appreciate the reply!
So just so I’m understanding,
Do I use the current relay that is already installed? Or do I need to have another relay and add wiring?
Sorry if that’s a stupid question.
Old 10-21-2019, 11:41 PM #6
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
I tapped the trailer hitch wires, has 12 vt source, reverse trigger and bam, run couple wires up into taillight section, put in 2 relays, run to 2 dash switches, one is on with reverse or just off, other is 12vt hot to repel tailgaters. Meso is supposed to release an on/off/ auto switch that would allow use of one switch, till then I made do
edit, should have read whole op post, didn't see you ran the harness already - opps
ForRun is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 12:15 AM #7
Real Name: Luke
Real Name: Luke
You'd want to splice into the existing harness before the relay and control box, then splice back into it again just before the lights, adding both wiring and a relay. The additional relay is the one you'd want to use the reverse light circuit or reverse switch on the shifter to toggle. This will circumvent (but not disable) the wireless remote and on/off toggle of the existing harness.
Looks like that's for 12v so should be putting out 12v power to the lights.
Old 10-22-2019, 12:57 AM #8
mlnhtrang's Avatar
mlnhtrang mlnhtrang is offline
mlnhtrang is on a distinguished road
mlnhtrang's Avatar
youtube "How to Install Auxiliary Reverse Lights"
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
mlnhtrang is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 09:08 PM #9
Awesome I’ve got it now. Thanks so much.
Old 10-23-2019, 04:43 AM #10
Krej Krej is offline
Krej is on a distinguished road
Just as a side note. Take the time to make sure you want them on when in reverse.
I have 2 Extreme LED floods in my rear bumper that are switched independently and when I tried to use them to help when backing up, the rear camera auto adjusts to the additional light and it was actually harder to see details in the screen.
I have found them great for camping and exterior lighting, but all but useless when in reverse.
The only time they actually help is when I need to see behind me using the side mirrors.
Just a though, not even an ounce of criticism.
2018 ORP - A bunch of stuff that is nice, and a bunch of stuff I don’t need.
Krej is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 07:05 AM #11
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
If you want to keep it simple add-a-circuit to the Towing-BKUP fuse (footwell box) and attach that wire to post 85 or 86 (whichever is NOT connected to battery -) of the kit relay.
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 12:37 PM #12
Originally Posted by Deep_palancar View Post
If you want to keep it simple add-a-circuit to the Towing-BKUP fuse (footwell box) and attach that wire to post 86 (probably white wire) of the kit relay.
That’s an incredibly idea. Soooo simple. I will try this. Thank you!!
Old 10-24-2019, 12:38 PM #13
It was not taken as criticism I assure you. Thank you for your thoughts!! Oddly enough my camera seems to like the extra output.. I do live in rural KY though and there is essentially no light at night near my home.
Thank you again!
component , harness , lights , reverse , vehicle
Reverse lights mlrff 5th gen T4Rs 1 03-09-2018 12:19 AM
aux reverse lights 7echo 3rd gen T4Rs 5 02-15-2016 02:10 PM
921 LED reverse lights GottaBeTRD Classifieds - buy & sell (no commercial ads please) 7 03-07-2011 09:05 PM
LED Tail Lights w/led turns & reverse lights 00328 4th Gen T4Rs 2 01-01-2008 11:06 PM
Aux. Reverse Lights ironadrenaline Engines / Suspension / Wheels / Tires / Audio / Accessories 10 08-14-2006 10:41 AM
