Originally Posted by jhguth
can you turn them on and off with a physical switch, or do you have to use the wireless remote?
you can trigger a relay with the existing reverse lights, but that only works if you can turn them on and off without using the wireless remote
I appreciate you taking the time to reply!
I do have the option to turn it on and off with a physical switch, yes.
So both options: wireless and switched.
Here is a link to the harness if it helps at all:
Northpole Light Remote Control Wiring Harness for LED Light Bar, 40A Fuse Remote On Off Switch Relay Wiring Harness for LED Work Lights Driving fog lights
https://www.amazon.com/dp/B01M02ZFT8..._OiMRDb8WR29VV
