Bumping this thread ... I'd like to remove mine, too, in order to try and fix a problem with the door not being able to remain closed (the tabs on each end of the door that hold the door in place are stuck in the "in" position, so they don't "catch" in place when attempting to close the door).
Any help would be appreciated!
David
Found it! This thread is getting to the 4WD Computer, but have to remove the glove box to get to it. Hope this helps.
Did you ever figure out what was wrong with the latches, mine do the same thing. Have to jam a piece of paper in between the door and dash to keep it closed.
Hi BigEddie,
I wound up simply spraying it with a silicone lubricant spray and letting it sit overnight. Eventually the tabs became unstuck, and it's been working fine now for several months.
