Old 10-25-2019, 12:03 PM #1
yognabologna yognabologna is offline
yognabologna is on a distinguished road
Brand new 5th gen vibrating when braking
hey guys,
the whole body of my brand new 5th gen SR5 (400 miles) vibrates when braking. it's especially worse when braking from higher speeds. separately (but related), i sometimes feel the transmission "jolt" a bit when i first start driving around and take a turn.
only thing that comes to mind is i recently drove down a mountain using engine braking to slow myself and perhaps did it wrong? i never went faster than 30-40 mph while on S3/S4 and nothing ever sounded or felt wrong.
thanks in advance
yognabologna is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 12:10 PM #2
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Originally Posted by yognabologna View Post
hey guys,
thanks in advance
Is it pulsing in the brake pedal and the steering wheel?
Sounds like "warped" rotors. I would start with replacing those. Go with Raybestos Advanced Technology slotted rotors.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 12:18 PM #3
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
Unless you have been driving those first 400 miles with your foot resting on the brake pedal you should not be having brake problems so soon. Also--have you checked the lug nuts on all wheels? Make sure they are tightened to the correct ft/lb torque for your wheels.
It is a new vehicle--I would have it checked by the dealer in case it is some flaw that is covered under warranty.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 01:06 PM #4
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
Take it to the dealer...it has 400 miles on it...
/end thread.
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 01:40 PM #5
thanks, i can look into the lug nuts. my only issue here is the dealer i bought it from is 1+ hr. away. can I take it to my local Toyota dealer?
Old 10-25-2019, 01:47 PM #6
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Take it to any dealer. you should not be paying for a damn thing on a car with 400 miles on it unless of course you caused an issue, but in this case they will handle it. They have to
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 02:56 PM #7
TOYO74's Avatar
TOYO74's Avatar
Yes, as SR5Bart said, you can have your vehicle checked at any Toyota dealer.
You should check the lug nuts for your own safety, but there is no reason to try to guess what is causing the vibration problem when you can have the service dept check it under warranty.
Old 10-26-2019, 06:03 PM #8
lukeskywalker's Avatar
lukeskywalker lukeskywalker is offline
lukeskywalker is on a distinguished road
It's probably warped rotors.
TRD PRO Trim - Bilstein 5100x4 @1.75 - Rear 1.5 Daystar Spacer - F(x) Pro Black Wheels - TRD Skid Plate - General Grabber AT2 @ 265/70R17 - Tail as Turn Rear Lights Mod - HID Low Beam Replacement - BAJA Rack - Flat Utility Mesh w/Sunroof - Sunroof - Fold Flat Cargo Platform - Raingler Cargo Ceiling Net
lukeskywalker is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 03:05 AM #9
Saker's Avatar
Saker Saker is offline
Saker's Avatar
So...…………… yes you can.
Best Regards,
Saker
Old 10-31-2019, 03:00 AM #10
thanks for the responses guys. planning on taking her in this week. issue is getting worse - see video below
it's icy/snowy outside and my car is now doing this when i break, and sometimes when i accelerate also. you obviously cant tell in the video but the break pedal and entire care vibrate pretty aggressively. same thing happens when i accelerate sometimes.
my transmission also jolts a ton.. sometimes just when going into reverse, sometimes when going from 2WD to 4WD. again, brand new car, 600 miles..
YouTube
Old 10-31-2019, 07:33 AM #11
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
That sounds like crap, I'd get that in ASAP.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 08:05 AM #12
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I smell a lemon.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 09:23 AM #13
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
As others have said, Toyota dealership only, don't try to diagnose yourself other than making sure there are no loose lug nuts.
This link might provide some understanding of what's commonly referred to as warped rotors:
THE REAL TRUTH ABOUT WARPED BRAKE ROTORS..
thennen is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:13 AM #14
Sounds like ABS engaging.
Old 10-31-2019, 10:34 AM #15
Jivewalker's Avatar
Jivewalker's Avatar
^this
I am fragile.
Not like a flower.
But like a bomb.
5th , braking , brand , gen , wrong
Sudden braking problem (when not braking) t4rjc 5th gen T4Rs 18 09-29-2016 09:53 AM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
Vibrating Cat Maritimer 3rd gen T4Rs 11 07-13-2012 10:05 AM
im vibrating everywhere! dsrtflcon7 3rd gen T4Rs 2 01-07-2011 05:16 PM
Vibrating @ Idle AlexH Problems & Warranty Issues 3 04-06-2007 04:10 AM
