10-29-2019, 08:44 AM
#31
a side note: using toyota filter and O rings, mobil 1 0w-20 advanced fuel economy ( I may switch to toyota oil next change for quieter performance) dorman drain plug gasket ....oh and it's nice to see the engine still full of oil when its time to change the oil because my last vehicle would have been down 1.5 qts
10-29-2019, 09:35 AM
#32
Can anyone confirm that Toyota p/n 15620-31060 is correct for the '19 T4R 4.0 engine? I seem to get a message that that part doesn't fit on at least 1 website (Ebay).
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
10-29-2019, 10:24 AM
#33
Which Fumoto drain did you use? There appear to be three on the website, of various lengths.
Originally Posted by HanginInUtah
I have been the only one to change my oil, and the first thing I did is add the Fumoto drain. The only problem with it is that it takes a bit longer to get all the oil drained out of that smaller opening. But it sits under the skid, and I don't have to worry about plug gaskets or stripping threads. And I haven't had any issues yet with the plastic housing, but I'm removing it myself. The one thing I bypass is trying to remove the plug and use the plastic adapter to pop up the valve and drain the oil. I just unthread the housing and let it drain like I would a normal oil filter before removing it. A little more wiping my hands off, but less frustration. That damn plastic adapter is a pain to get in there juuuuussst right, and I had oil sprayed all over the place before I finally got it right. I can catch all of the oil dripping down the sides of the housing. I can't guess where the plastic tool will get it to ricochet and then I have way more cleanup to do.
The only other thing I did was ditch the plastic retainer on the front air dam thing. One less tool to take with me underneath
10-29-2019, 10:25 AM
#34
Real Name: Jeremy
Real Name: Jeremy
yes, PN 15620-31060 will work with all the 4R 4.0 5th gen engines.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
10-29-2019, 10:46 AM
#35
There are different types of the Fumoto drain valve. Some of no nipple, some have a small one, and some have the longer one. I ordered one with the small nipple so that I could attach a hose to it if I wanted to.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2012 Shoreline Blue TE
10-29-2019, 11:21 AM
#36
I ended up with the same one. While looking around, I also came across the ones from http://www.nospillsystems.com, these are similar to the Motiv drain for the filter housing. Thought about it and decided I didn't want to carry another tool around just to drain the oil.
10-29-2019, 11:55 AM
#37
same issue here - exactly the same. You have to get an oil filter wrench -shown by another post here- which uses the "flats" rather than the "ears." I got mine off by using a long wrench/breaker bar which my son slowly rotated as I held the oil filter wrench by pushing it up onto the oil filter housing from underneath. I will not go back to the dealer or anyone else for a oil change. It was clearly put on using the same wrench as all other tasks..ie wheel removal.
10-29-2019, 12:12 PM
#38
Originally Posted by callihan_44
well the dealer got an earful and agreed to give me a courtesy car till the part arrives, reluctantly because " i attempted the oil change myself"... I then gave him a rundown of my experience of working on engines which included oil changes and letting him know what little torque it takes to tighten the oil filter and it was tight to the point of cracking the assembly
The first oil change I did after the two year "complimentary" service expired, I encountered the over-torqued filter housing. I stopped right there and took it to the dealer the next morning. The service manager did not seem the least bit surprised by my claim and replaced the filter. I only had to clean up a little residual mess.
While changing the oil for the second time yesterday, I found that the housing drain plug was over torqued! The entire filter housing rotated, when trying to loosen the plug. I eventually got it loose and now should have not issues the next oil change but I am going to swap to the metal housing for piece of mind next time.
Glad everything worked out for you!
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
10-29-2019, 02:18 PM
#39
Banned
Real Name: Mark
Banned
Real Name: Mark
Yep. It fits the 4 Runner engine. This part number actually is listed as OEM for Camrys, Avalon, Rav4, etc, but not 4Runners. Go figure.
BTW, I never trust part fitment advice from 3rd party sites like eBay or Amazon. Go to a real Toyota parts dealer online site or oempartsource. (But in this case you’d get the same no fit message).
10-29-2019, 03:48 PM
#40
Stories like this are the reason I have always changed my oil and filter since 1975.
The 4Runner is so super easy to work-on too.
10-29-2019, 03:54 PM
#41
The 4Runner uses a taller perforated center tube but it can be swapped over. That's the reason it's "not compatible".
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
10-29-2019, 05:05 PM
#42
Originally Posted by nb rob
you are correct. and the occasional hot drip of oil. And of course, fumes from melting plastic
I'm pretty sure the housing is made from thermoset plastic, meaning you had to actually burn through it instead of just melting it. Not fun for sure.
10-29-2019, 08:37 PM
#43
Real Name: Buck
Real Name: Buck
Any chance that these over tightened oil filter housings are bending or damaging the internal perforated tube?
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
10-29-2019, 09:16 PM
#44
Thanks folks!
11-05-2019, 03:42 PM
#45
Real Name: Ben
Real Name: Ben
F-103 | Fumoto(R) Engine Oil Drain Valves
Just the first on on the list, F103. The picture doesn't show it well, but it's just a straight valve. It fits just fine under the access plate.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
