Old 10-29-2019, 08:44 AM #31
callihan_44 callihan_44 is offline
callihan_44 is on a distinguished road
a side note: using toyota filter and O rings, mobil 1 0w-20 advanced fuel economy ( I may switch to toyota oil next change for quieter performance) dorman drain plug gasket ....oh and it's nice to see the engine still full of oil when its time to change the oil because my last vehicle would have been down 1.5 qts
callihan_44 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 09:35 AM #32
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
Can anyone confirm that Toyota p/n 15620-31060 is correct for the '19 T4R 4.0 engine? I seem to get a message that that part doesn't fit on at least 1 website (Ebay).
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:24 AM #33
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Which Fumoto drain did you use? There appear to be three on the website, of various lengths.
Originally Posted by HanginInUtah View Post
I have been the only one to change my oil, and the first thing I did is add the Fumoto drain. The only problem with it is that it takes a bit longer to get all the oil drained out of that smaller opening. But it sits under the skid, and I don't have to worry about plug gaskets or stripping threads. And I haven't had any issues yet with the plastic housing, but I'm removing it myself. The one thing I bypass is trying to remove the plug and use the plastic adapter to pop up the valve and drain the oil. I just unthread the housing and let it drain like I would a normal oil filter before removing it. A little more wiping my hands off, but less frustration. That damn plastic adapter is a pain to get in there juuuuussst right, and I had oil sprayed all over the place before I finally got it right. I can catch all of the oil dripping down the sides of the housing. I can't guess where the plastic tool will get it to ricochet and then I have way more cleanup to do.
The only other thing I did was ditch the plastic retainer on the front air dam thing. One less tool to take with me underneath
rageandlove is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:25 AM #34
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
yes, PN 15620-31060 will work with all the 4R 4.0 5th gen engines.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:46 AM #35
drewsro's Avatar
drewsro drewsro is offline
drewsro has a spectacular aura about drewsro has a spectacular aura about
drewsro's Avatar
There are different types of the Fumoto drain valve. Some of no nipple, some have a small one, and some have the longer one. I ordered one with the small nipple so that I could attach a hose to it if I wanted to.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:21 AM #36
sclui56 sclui56 is offline
sclui56 is on a distinguished road
I ended up with the same one. While looking around, I also came across the ones from http://www.nospillsystems.com, these are similar to the Motiv drain for the filter housing. Thought about it and decided I didn't want to carry another tool around just to drain the oil.
sclui56 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:55 AM #37
Stabbi Stabbi is offline
Stabbi is on a distinguished road
same issue here - exactly the same. You have to get an oil filter wrench -shown by another post here- which uses the "flats" rather than the "ears." I got mine off by using a long wrench/breaker bar which my son slowly rotated as I held the oil filter wrench by pushing it up onto the oil filter housing from underneath. I will not go back to the dealer or anyone else for a oil change. It was clearly put on using the same wrench as all other tasks..ie wheel removal.
Stabbi is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:12 PM #38
headpaneer's Avatar
headpaneer headpaneer is offline
headpaneer will become famous soon enough
headpaneer's Avatar
Originally Posted by callihan_44 View Post
well the dealer got an earful and agreed to give me a courtesy car till the part arrives, reluctantly because " i attempted the oil change myself"... I then gave him a rundown of my experience of working on engines which included oil changes and letting him know what little torque it takes to tighten the oil filter and it was tight to the point of cracking the assembly
The first oil change I did after the two year "complimentary" service expired, I encountered the over-torqued filter housing. I stopped right there and took it to the dealer the next morning. The service manager did not seem the least bit surprised by my claim and replaced the filter. I only had to clean up a little residual mess.
While changing the oil for the second time yesterday, I found that the housing drain plug was over torqued! The entire filter housing rotated, when trying to loosen the plug. I eventually got it loose and now should have not issues the next oil change but I am going to swap to the metal housing for piece of mind next time.
Glad everything worked out for you!
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
headpaneer is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 02:18 PM #39
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Yep. It fits the 4 Runner engine. This part number actually is listed as OEM for Camrys, Avalon, Rav4, etc, but not 4Runners. Go figure.
BTW, I never trust part fitment advice from 3rd party sites like eBay or Amazon. Go to a real Toyota parts dealer online site or oempartsource. (But in this case you’d get the same no fit message).
Old 10-29-2019, 03:48 PM #40
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
Stories like this are the reason I have always changed my oil and filter since 1975.
The 4Runner is so super easy to work-on too.
GNB is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 03:54 PM #41
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
The 4Runner uses a taller perforated center tube but it can be swapped over. That's the reason it's "not compatible".
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:05 PM #42
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Originally Posted by nb rob View Post
you are correct. and the occasional hot drip of oil. And of course, fumes from melting plastic
I'm pretty sure the housing is made from thermoset plastic, meaning you had to actually burn through it instead of just melting it. Not fun for sure.
1000MPH is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:37 PM #43
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Any chance that these over tightened oil filter housings are bending or damaging the internal perforated tube?
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 09:16 PM #44
Thanks folks!
Old 11-05-2019, 03:42 PM #45
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
F-103 | Fumoto(R) Engine Oil Drain Valves
Just the first on on the list, F103. The picture doesn't show it well, but it's just a straight valve. It fits just fine under the access plate.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
assembly , change , dealer , filter , oil
Plastic Transmission shift assembly Sleeve toadybarker Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-04-2014 10:33 AM
Stupid dealer stories Jono.ful 5th gen T4Rs 17 09-14-2012 08:00 PM
Dealer says new carrier assembly ? kennyb3030 3rd gen T4Rs 11 03-06-2011 09:07 PM
Front End! Plastic Assembly.. **help** DEVILMAN 3rd gen T4Rs 5 08-12-2008 04:33 PM
Fron End! Plastic Assembly.. **help** DEVILMAN 3rd gen T4Rs 1 07-30-2008 11:10 AM
