10-29-2019, 02:57 AM
#16
My vote is for Viair as well but would ARB twin if I had to do it again. Nothing wrong with the Viair unit but ARB has a lot more flow.
10-29-2019, 03:37 AM
#17
Have both the MV-50 and ARB twin (rago mount). If you aren't going out often or doing multiple trails in a day, I'd say the MV-50 does the job well. I only went with the twin as I go out often and got tired of airing up all 4. Twin + morrflate has been great!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
10-29-2019, 04:32 AM
#18
Originally Posted by Metalman73
I have been running an ARB single for over 4 years and haven't had any issues. Not the fastest but it works.
Originally Posted by Ykket
Same here, got an ARB single this year and it has been great so far each time i used it.
Same here for 2 years now.. i have the one in a box with its hose
Slow, $$, and runs warm, but at least you know it'll work when you need it
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
10-29-2019, 07:22 AM
#19
Thanks for the replies everyone!
2019 TRD OR Premium. Dobinsons extended travel, Goodyear dura-trac 255/75's, pro wheels, sliders.
10-29-2019, 11:10 AM
#20
Originally Posted by mteolus
Shittybuilt one seems pretty good if it will last 5 years and if the CFM is accurate. That's over double the VIAIR CFM.
I have been more than impressed with it. I don't have a way to measure the output, but it moves a LOT of air. but, that aside, it airs up my tires quick. and, I actually air them down. in the deep snow, down to about 4. otherwise its 10-12. it gets them back up to 30 in about 3.5 minutes.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
10-29-2019, 11:23 AM
#21
VIAIR 88p here and no complaints.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
10-29-2019, 12:15 PM
#22
I have had the viair 400p in the bag for about 4 years now and it has always worked great. I recently installed it under the hood to save some cargo area. Really easy to install.
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
10-29-2019, 12:17 PM
#23
+1 for smittybuilt
10-29-2019, 12:38 PM
#24
For the VIAIR 400P-AUTO
31″ X 10.5″ FILL RATE
0 to 30 PSI 3 min. 00 sec. (± 10 sec.)
15 to 30 PSI 1 min. 35 sec. (± 05 sec.)
33″ X 12.5″ FILL RATE
0 to 30 PSI 4 min. 20 sec. (± 10 sec.)
15 to 30 PSI 2 min. 05 sec. (± 05 sec.)
35″ X 12.5″ FILL RATE
0 to 30 PSI 5 min. 20 sec. (± 15 sec.)
15 to 30 PSI 2 min. 45 sec. (± 05 sec.)
- from 400P-Automatic Portable Compressor | VIAIR
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
10-29-2019, 01:26 PM
#25
I assume you have beadlocks?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
10-29-2019, 02:07 PM
#26
I have ARB Twin after having and returning the 450P Auto. The Viair worked but it was slow. I was between the 400P and the 450 and decided on the 450 due to 100% duty.
Ended up with the ARB after finding used (never used) so it worked out for me. I ended up mounting with a 1 gallon tank using the Bandi mount. The one thing that really sold me on the ARB is that it's always in the truck, not just if i put it in there.
Yeah, it's expensive but its the cry once, buy once mentality.
2014 TEP - Icon 2.5" extended travel Front with Icon 2.0 rear w/ Toytec Superflex 2" springs; Budbuild full skids & HD Sliders, Black Rock Wheels, Nitto Ridge Graplers 295/70s, Eezi Awn K9 Rack, Warn Hybrid Bumper w/ Engo XR10S Winch
10-29-2019, 03:48 PM
#27
not on my 4runner.
zero issues with my 37" KO's at 4 psi on 9.5 wide aluminum wheels.
10-30-2019, 01:16 PM
#28
10-30-2019, 02:05 PM
#29
not on my 4runner.
Wow, pretty amazing.
02-11-2021, 12:54 PM
#30
smittybuilt for me.
Originally Posted by Avann
Not sure what you guys thought of as the best choice in 2019 but right now I have a very nice Dewalt which I bought for a low price!
