Old 10-28-2019, 01:39 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold Jetboy is a splendid one to behold
Jetboy's Avatar
I had a similar leak after a dealer oil change. The tech had over tightened the filter housing and cracked it. Dealer replaced it.
Old 10-28-2019, 09:52 PM #17
rageandlove's Avatar
rageandlove rageandlove is offline
rageandlove will become famous soon enough rageandlove will become famous soon enough
OK, when I was looking around this evening to see if there was a leak (no) I noticed this:
In another thread I remember reading that the metal clip is supposed to line up with the strip of metal running vertically up the metal housing attached to the engine.
So that probably means they over-tightened it by an eighth of a turn?
rageandlove is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:15 PM #18
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 will become famous soon enough
Yep, or a turn and and eighth, if that's even possible. Mine does click just a hair past it and that's where it likes to sit. Always has, just the way it's always been. Not quite that far though.
If it's only 1/8 turn then nothing to get worried about. If you think it's waaaaay tight that's different. I dont think they could get it a full turn over tight though without breaking something.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:41 AM #19
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
Id have to look but I don't think thats too far off, that "line" on the casing doesn't mean much. I'm sure its fine and I'm sure each truck is a bit different on where the final resting place is for the filter housing when tightened up.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:28 PM #20
headpaneer's Avatar
headpaneer headpaneer is offline
headpaneer will become famous soon enough
MY GARAGE
headpaneer's Avatar
MY GARAGE
Yes, I'm going to drive around for the next day or two sans skid plate and check for any more signs of oil. I didn't see any after my drive home from the dealer yesterday. I'll check again tonight after my commute to and from work.
My technique besides visual inspection was wiping the entire surface of the housing with a paper towel, which turned up nothing. Hopefully the same today after some more driving around.
There is part of me that just wants to just do the whole thing over right now to make sure it's done right ...
I just posted in one of the other oil change story threads about having the dealer loosen their over-torqued housing. They replaced the filter for me but somehow got quite a bit of oil on the housing. In my case I didn't notice any drips but cleaned the housing and everything was fine.
Hope you don't find any more drips! I would recommend, that you make sure the filter housing and housing drain plug are not over-torqued.
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
headpaneer is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:38 PM #21
Tuco Ramirez's Avatar
Tuco Ramirez Tuco Ramirez is offline
Tuco Ramirez is on a distinguished road
Mine never lines up all that well. Usually off a good bit. I am positive I do no over-tighten but just go until it is snug and I can feel no more gap between the housing and the block. ���� Never had any issues.
When you have to shoot, shoot....don't talk.
Tuco Ramirez is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 01:08 PM #22
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Originally Posted by MAXISTYLES View Post
If there's any way at all possible do the oil change yourself. Besides stripping skid-plate bolts and not correctly installing the oil filter, what are the chances they are putting in exactly 6.6 quarts of oil. I bet they are either dumping in 6 or 7 quarts.
I don't trust them either but a lot of heavy volume places have lube pumps that pull from a large drum. I'm not sure if they have a meter on them or if they check the dipstick. I don't think underfilling by 0.6 quarts is going to cause any long term damage but best to have the correct amount.
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 01:18 PM #23
Vwright14's Avatar
Vwright14 Vwright14 is offline
Vwright14 is on a distinguished road
Vwright14's Avatar
We have seen the o-rings from cheaper filters leak as well as cracked plastic housing. On the housing, Dorman makes a metal one that we have had good luck with when needed.
2012 Salsa Red Trail with KDSS
5100's with lift,285/70/17 Duratracs,some extra wattage and speakers in the stereo system.
2003 Chevy Tahoe 4x4 - 20in OE Concepts,MAC Exhaust, soon to be lowered with 3k watts of stereo.
Vwright14 is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 01:21 AM #24
Thanks for the thoughts folks!
Old 10-30-2019, 11:54 AM #25
QwikKotaTx's Avatar
QwikKotaTx's Avatar
I just snagged a new OEM metal housing off eBay for $18 shipped. Not worth chancing an aftermarket version IMO. You just need to swap over the metal perforated tube from the old plastic housing.
Old 11-05-2019, 01:18 PM #26
Vwright14's Avatar
Vwright14's Avatar
Yeah I totally forgot some of the factory ones are metal.
back , dealer , put , skid , yesterday
What's causing my Duratracs to cup guitarsail 5th gen T4Rs 32 05-24-2017 04:01 PM
VSC causing trouble TJM 3rd gen T4Rs 10 03-08-2017 10:53 AM
what is causing this noise ?? Mellemel 3rd gen T4Rs 3 07-11-2016 11:10 PM
Valve Cover Leak Causing Misfire? thrice1825 3rd gen T4Rs 13 01-24-2015 09:23 AM
What is causing this? [thud] ljwd 3rd gen T4Rs 17 10-18-2011 04:52 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
