10-28-2019, 01:59 PM
Ignition Issues - After driving through deep water
2017 4Runner TRD ORP 50k miles.
Ran it through some deep water, then the temps fell below freezing. Started up ok the next morning but then 2 days later and now for the last 2 weeks sometimes it starts fine and then sometimes I have to move the key around in the start position several times to find just the right place for it to kick off the starter. Any ideas? Solenoid? I read some posts on older 4Runners that they took off the starter and replaced some copper contacts on the solenoid (apparently solenoid is part of the starter) to fix the issue. Or perhaps it is the ignition?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
10-28-2019, 06:55 PM
Real Name: Nick
Real Name: Nick
I had a similar issue last winter after getting into deep water out East. See if you can pull an error code but mine was having issues with the crank position sensor. Drove back home to Colorado and the dry air solved my problem lol. If it is indeed a crank position sensor error you can pull the cap, dry it out, and pop some dielectric grease in there.
10-28-2019, 07:16 PM
Bad crank position sensor would cause "crank/no start," not "no crank/no start" as the OP describes.
If jiggling the key in the ignition is actually having an effect and isn't just coincidental, then the problem is in the ignition switch, and is unrelated to the water crossing. If the water crossing really is the source of the problem, then jiggling the ignition key should have no effect, and the problem is likely in the starter or solenoid.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
10-28-2019, 10:40 PM
Sounds like the ignition switch. When I find out I'll let you know. Seems odd at 50k though.
10-28-2019, 11:01 PM
I had a similar issue... deep water crossing... no problems... several on/off cycles with no problems cranking/starting. Then two days later it wouldn't turn over. Turn the key to On, and everything would be normal. Turn the key to Start and dash would go dark but nothing would happen. Sometimes after a couple of attempts, or holding the key to Start for many seconds (2-10), it would crank and light off with no problem. No real error codes. Took to the dealer, and they couldn't track it down, as it became intermittent (sometimes it would crank no problem the first time, and other times it would take 20 attempts... you can guess how it acted at the dealer... never a problem). It ended up 'fixing' itself after about two months. I replaced the battery, starter relay, and ignition switch, all with no improvement.
My guess at this point is that the dealer installed 'alarm' (I didn't pay for it, but the dealership installs them on all the vehicles as soon as they roll off the rigs), somehow got it's kill-switch relay funked up by the water. I want to go in and short out the kill-switch relay, as I don't know when it will give me all heck again.
Good luck, and let us know what you find.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
10-28-2019, 11:29 PM
Sounds like the exact same thing.
One other note, if you run through deep water and then it freezes, don't use your emergency brake. I put it in gear and it wouldn't move the next morning. Finally I gave it enough gas and it broke loose. Pretty loud pop.
10-28-2019, 11:33 PM
if its your starter, replace it with the FJ starter... pretty sure its water proof. had some friends that found that out the hard way.
Troner envy... the struggle is real!
10-29-2019, 04:43 AM
Nope. Same starter. Water will kill them.
10-29-2019, 05:01 AM
Place your finger on the starter relay while someone turns the key. If you feel the relay click when the starter does not engage, then the starter is probably bad. $160, two bolts, < 1 hr.
10-29-2019, 07:07 AM
You're right. It was a a mod
Who has Scuba'd their starter? - Toyota FJ Cruiser Forum
10-29-2019, 01:31 PM
Well damn, at least it is only $160. Seems like a big flaw if the starters are not waterproof. I wonder if Taco's have this same problem....
And everyone was concerned around here about Diff breathers when the starter seems to be the biggest issue.
10-29-2019, 02:59 PM
it's mud that kills them, right, not just water? mud will also kill your alternator.
10-29-2019, 03:12 PM
Real Name: J
Real Name: J
Approximately how high is the starter off the ground in a stock configuration?
The real question is, what depth of water is too deep for the stater to become submerged? 12 inches, 16 inches?
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
10-29-2019, 03:49 PM
On a side note, ignition switch wear is compounded by heavy keyrings.
2019 SW TRDORP
10-29-2019, 05:13 PM
Water was up to the top of the back bumper (where the black plastic piece is right below the rear gate) and I have a 3" lift. I'll measure. So I guess the starter is lower than that or the wake made the water even higher than that. Seems like if Toyota put a snorkel on as a factory option they would upgrade the starter too but I bet not.
Anyone familiar with New Mexico, the creek crossing was at the beginning of the Goose Lake Trail in Red River which is very popular. The creek keeps getting deeper every year. My buddies stock Jeep Rubicon made it without any issues.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
