Old 10-28-2019, 08:38 PM #1
MissouriBreaks MissouriBreaks is offline
MissouriBreaks will become famous soon enough
Resizing Garage Door
After being in my house for 17 years, I finally went from a 7 foot tall door to an 8 foot tall door.
For my house, it was a relatively easy job as I did not have to change the header over the door. All I had to do was re-size/re-frame the door opening.
The header over my door is all the way to the rafters in the garage and there was close to 3 feet of clearance above the old door.
I always knew the door opening could be changed as I had the house built new in 2002. I likely would have had an 8 foot door installed when new, but I do not recall that being one of the options offered (it may have been, but I just don't recall it as an option). When we put the original door opener on in 2002, my brother commented on how easy it would be to change the door height. At the time, I did not have a truck/4Runner, and did not have extra funds, so there was no real need. When I bought my FJ Cruiser in 2013, I checked the clearance before driving it into the garage the first time. Luckily, my FJ did not have the roof rack, as that would not have made it in the garage.
I checked the clearance after buying the 4Runner, and that made it in as well. However, this summer I purchased an off-road camper and that did not make it in the garage. In measuring the camper height, with rack, I realized that an 8 foot high door would allow me to park the camper inside.
So, I ordered a new door and spoke with the installer. He agreed that he could come out and remove the old door in the morning and install a new door in the afternoon.
So here are some photos.
The first one likely dates to 2003, shortly after I purchased the house. It shows the original door.
All I can say is note the height of the door in relation to the roof line above it and the window to the side of it.
On Wednesday of last week, the big day arrived and I was out working at 6:30 am to begin removing the siding. The door installer arrived around 8 am and removed the old door. I told him that I should be done resizing the opening around 1 to 2 pm. He and a helper came back around 2 pm and I was not quite done. They went to lunch and came back around 3 pm. By then I had the rough opening framed on the inside. Here are some pictures from the end of the day, on Wednesday, after the new door was installed.
The new door was installed, but it was late in the day, so the installer had to come back on Thursday afternoon to install the new opener. I again worked most of the day on Thursday to finish resizing the exterior of the opening and put the new trim on. However, I did not have time to re-install the siding.
I was able to park the camper inside.
Unfortunately on Friday I had to do real work and was not able to do anything.
Saturday, I worked to re-install the siding. I finished the siding work at 2:30 and 15 minutes later it was raining. Spent the next couple of hours working to put the insulation back on the inside of the opening and putting tools away. Parked the camper and the 4Runner inside Saturday night.
Sunday, I had a few minor things to do, such as re-install the house numbers above the door and buy a few drywall scraps to put up around the door to cover the insulation.
These pictures are from Sunday morning.
I am glad that the job is done and the camper is inside for the winter. Now I can even put a lift on the 4Runner, as I have clearance to get it inside the garage with a lift.
The house and garage both look so much better with the taller door installed. I am very pleased with the results.
2017 TRD Pro - Red
2012 FJ Cruiser - Sold
MissouriBreaks is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 08:48 PM #2
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
That’s one sweet little camper! I also suffer from a 7’ garage door, it sucks.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 09:44 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Looks like you could of squeezed a couple more feet out of it. I would of went straight to 10 if I could.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 09:52 PM #4
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
I originally planned for it in 97 when we built but the door guy said not enough room to pull it all the way up,I have a beam in the center runs left to right. He also said the door would be too heavy. You proved him wrong, Congrats!
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:02 PM #5
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
Good move, and looks great!
I am also super glad that I have 8ft garage doors......as I am still able to fit being lifted 3+ inches, having 34 inch tires, and a Gobi Rack + RTT;
....Just barely, but it fits! Less than an inch to spare.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:07 PM #6
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
9 ft. here. Even fits the Jeep without the CB antenna hitting the door. I dunno, someone had to be the jerk and say "mine is bigger than yours". Lol.
Nice work though. That's an investment you'll reap the benefits of on a daily basis. You will seriously not regret the time or money spent doing that.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:08 PM #7
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
Nice work!
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:48 PM #8
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
Nice work. Wifey and I are looking for a new house. Either it'll have 8ft + garage doors, or a garage that can be modified.
My parents built their house right. pretty sure they have 9 ft doors. Never realized how practical they really were.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 07:13 AM #9
I could not have done 10 feet due to the header, but 9 feet would have been possible. Oh Well.
2017 TRD Pro - Red
Old 10-29-2019, 07:33 AM #10
DoubleRGirl DoubleRGirl is offline
DoubleRGirl is on a distinguished road
That was a requirement when I bought my current house. Took the truck with me to go view them, and made sure the doors were tall enough.
I actually recently had one of the side mounted openers installed on one of the doors for more clearance
DoubleRGirl is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 07:44 AM #11
Brick Sprickly's Avatar
Brick Sprickly Brick Sprickly is offline
Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light
Good looking work. I used to be a residential framer so that's nice to see here.
I've been having the same concerns recently as well - we're closing on a house in WA right now, and I made absolutely sure that any home we'd settle on would have proper clearance for the truck plus a little in case I wanted to add anything. Realtor measured everything for me.
2019 TRD Pro Voodoo Blue "Cobra Commander"
Brick Sprickly is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 07:46 AM #12
Damn that's soooooo close haha
Old 10-29-2019, 09:24 AM #13
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
This is great to see. Here in San Francisco most of the homes have garages that are 6ft 10in or less. A 7 ft garage would accomodate my rig with a 3" lift 33s and a roof top tent! Y'all are lucky with all of your modern homes :P
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:12 AM #14
Cadesun's Avatar
Cadesun Cadesun is offline
Real Name: Insta: cadeandmollyadventures
Cadesun is on a distinguished road
Cadesun's Avatar
Nice work! We have been doing a little house shopping and were trying to figure out how hard this would be to do so we could keep our boat at home in the winter.
Looks like I need to pay attention to where the header is to determine if I would need to hire a professional or DIY the resize.
Cadeandmolly.com
2020 Venture
2015 TEP - wrecked
2005 SR5 - sold
Cadesun is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:26 AM #15
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
Nice! We just built a new house last year and our neighborhood requires 8' doors, I was happy to avoid paying the extra cost to do so.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
camper , door , garage , house , inside
RTT vs. Garage Door -- Will It Fit? Johnny4runner 4th Gen T4Rs 3 05-29-2018 08:48 PM
Garage door opener nvbirdman 5th gen T4Rs 3 11-12-2017 09:35 PM
Garage door opener Cory619 4th Gen T4Rs 4 04-27-2014 10:31 AM
Garage door opener xcamo82x 4th Gen T4Rs 5 12-06-2012 04:00 PM
Garage Door Openers Avet14 4th Gen T4Rs 2 09-15-2007 11:02 PM
