Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-29-2019, 11:31 PM #16
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
Theres ao many unique ways to use that t- track. Turned out great!
Sent from my SM-G973U using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 01:15 AM #17
raghu4026 raghu4026 is offline
raghu4026 is on a distinguished road
Originally Posted by SuperfastMatt View Post
For fasteners, go to McMaster and get two packs of 97763A267 (black stainless bolts) and one of 96765A140 (washers)
Do you happen to have the part number for the nuts as well? Thanks
2019 4runner Limited, Blizzard Pearl, 3rd row seats, Factory cross bars and side steps
Mods - TRD Pro upper Grill conversion, XD HID low beams, Philips LED fogs, All LED interior, custom roof rack
raghu4026 is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 10:31 AM #18
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
This is why I laugh when people are paying $1,500 for a rack. This guy produced a one-off for a quarter of the price. Produce those at scale and it's even cheaper. Yea fit-and-finish might not be there, but that doesn't mean if you make your own you can't make modifications as you go.
Solid how-to
llDemonll is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 01:50 PM #19
SuperfastMatt SuperfastMatt is offline
SuperfastMatt will become famous soon enough
Originally Posted by Charlievee View Post
I'm cursing you and praising at the same time. Nice work. Can you share more detail on how the front shroud is mounted?
At the front I have an extruded aluminum cross bar that is at the same angle I cut the front of the side bars. I'm using some t-slot nuts and bolts, and I just drilled holes through at the right location. I can get a better picture this evening.
SuperfastMatt is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 01:51 PM #20
94407A104
McMaster-Carr
Old 10-30-2019, 03:17 PM #21
94407A104
McMaster-Carr
Excellent, thank you!
Old 10-30-2019, 08:48 PM #22
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Okay I think I’m gonna pull the trigger on doing this after your inspiration.
I need to find a local spot to find 1/4” aluminum in 2”x 8’. Metal Depot is 69 for the aluminum, 109 to ship it.
Home Depot had 1/8 strips in 2”x 8’. No 1/4”
Looks like hardware wise it’s gonna be 60 shipped for everything from McMaster-Carr, including the 1/4 3”x3” angle aluminum for the legs.
The cross bars are going to be $252 shipped.
One thing never brought up was what you made to wind deflector from and what hardware you used in the slots to mount the wind deflector. Thanks again!
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:34 AM #23
pDubs's Avatar
pDubs's Avatar
Interesting, if I plug in Quantity 4: 1/4 inch thick, 2 inch x 4 feet. the shipping goes down to $5, from $109 to just do Qty 2 8 feet length.
I wasn't planning on splitting it in 2 like you did to take up less room if I wanted to store somewhere, wanted to have 92" side plates the whole way through, but not paying that much for shipping.
2014 SR5P
Old 10-31-2019, 12:32 PM #24
I tried midweststeelsupply.com . 6061 aluminum plate 0.25" - $25.04 per plate - $50.08 for 2. Ground shipping $27.43
Old 10-31-2019, 12:37 PM #25
pDubs's Avatar
pDubs's Avatar
Funny, plugging in same specs I get 25.99 per plate. $189.10 ground shipping :/
Edit: This is doing 1/4"x 2", 2 8 feet pieces.
2014 SR5P
Old 10-31-2019, 01:04 PM #26
Try your local homedepot or lowes. I found these online
https://www.homedepot.com/p/Everbilt...2547/204273941
https://www.homedepot.com/p/Everbilt...2577/204273946
Old 10-31-2019, 01:07 PM #27
nm_t4r nm_t4r is offline
nm_t4r is on a distinguished road
There is always Amazon: $90.40 + $30.80 shipping for 2 - 6061 T6 Aluminum Bar - 1/4" x 2" x 96"
nm_t4r is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 01:17 PM #28
And eBay: 46.40 + 39.98 for shipping for 2 - 1/4" Aluminum 2" x 96" Bar Sheet Plate 6061-T6 Mill Finish
Old 10-31-2019, 06:11 PM #29
If you have a metal supply store in town it might be cheapest. We have IMS in Los Angeles that is great for this sort of stuff.
I made the wind deflector out of aluminum that was 6" wide and I think something like 1/16" thick. It was like $20 I think
Consider getting 3003 aluminum. It is cheaper and has great corrosion resistance. It is about half the strength of 6061 but at 1/4"x2" you're not going to have a problem. I'd stick with higher strength on the feet though.
Old 11-01-2019, 01:43 PM #30
Checkout 6061 Aluminum Flat Bars - 6061 Aluminum - Aluminum - Metals
$300 , cost , rack , roof , style
Roof Rack Showdown - Prinsu vs Southern Style Offroad Agent_Outside 5th gen T4Rs 35 09-04-2019 12:15 AM
Prinsu roof rack Whizz 5th gen T4Rs 18 06-17-2019 08:23 AM
Roof Rack - Prinsu VS SSO genesis712 5th gen T4Rs 9 04-24-2018 03:20 PM
FS: 5th Gen Prinsu 3/4 roof rack sn_85 For Sale: T4R Items 2 01-19-2018 12:24 AM
Feeler for Prinsu Roof Rack tristero 5th gen T4Rs 13 01-27-2016 06:38 PM
