Old 07-26-2020, 01:09 AM #1
thirteen thirteen is offline
thirteen will become famous soon enough
Awning or canopy?
I'm looking to get some cover for camping and for stops out on the trails. The roof rack awnings look great, but I'm wondering if it would be better to have a separate pop up canopy that I can put anywhere.
Any opinions from people who have used both? Are the awnings as cool as they look, or just a gimmick?
thirteen is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 03:23 AM #2
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
It really depends on what sort of outings you plan to take and how many people will be with you.
Pop-up canopies can give you more cover, more height underneath, and can withstand more extreme weather than awnings. But they are heavier, take up more space, and need at least two people to put up and take down - with three or four being better. They are generally superior to awnings for base camping with a group or family.
Awnings are lighter, take up less space and can be easily set up and put away by one person. They are less roomy underneath and more easily collapsed/blown around/damaged by bad weather. When space is at a premium or you're on your own, awnings are superior. Hence their popularity for overlanding.
Neither is really a replacement for the other. In the right situations, each is awesome and there's nothing wrong with eventually having both.
A third option is to set up a dining fly using a tarp, some paracord, and knowledge of how to tie a taut-line hitch. This does require trees to tie the rope around (remember to place three or four twigs between the rope and the tree to protect the bark) if you're solo. Tarp poles can be substituted for trees if there aren't any around and you're not alone. This can take up the least amount of space and weight and can also be at least as weather resistant as the pop-up when done right. Plus, it can cost just a few dollars.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 03:41 AM #3
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I really like the idea of a awning, but I just use a separate pop up canopy.
I generally go out there to drive the 4Runner around and have fun with it too. Not having to mess with attached to the truck when I want to drive it is better for how I use it.
Old 07-26-2020, 08:03 AM #4
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
@Harlock and @Bumbo pretty much spelled it out above.
Camping - Canopy
Trail Breaks - Awning
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 09:22 AM #5
curmudge1 curmudge1 is offline
Real Name: Dave
curmudge1 is on a distinguished road
Real Name: Dave
Post products to look at
If you're reading all the 5th gen posts, you might have seen mention of Slumberjack... they have a canopy that drapes over the hatch & extends off the back, and a small tent (shack) that extends a fly over the tailgate. I thought these looked pretty neat, have not tried them.
Tundra tarps for a canopy material with some flexibility.
FWIW, YMMV, etc.
curmudge1 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 01:34 PM #6
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Terrain and setup dependent. I enjoy my ARB awning. The walls are perfect for the family and I to have bug screen or weather protection. We have started to use it as a tent as well.
But we have been to places when being by the car is not an option, so obviously a canopy.
My awning and canopy are the same size.
I would recommend if you go with an awning figure out your needs. Just go out and see what would be nice. There are a lot of options on the market today. If it wasn’t for the wall option, I would get a 180 or 270.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:25 AM #7
It sounds like the best answer is both. An awning would be great for me most of the time, but I have been to some places where it would be useless. Joshua Tree National Park, for example. You need to park in your paved parking spot away from you camping spot. Only a canopy would work there.
Old 07-27-2020, 10:43 AM #8
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I'd vote awning and maybe something like a camping tarp. Advantage of an awning is that it's on the truck already and is always with you. It's a little tricky to setup by yourself but you get the hang of it. With two people it's a breeze. If you need more shade or something not attached to the vehicle itself the tarp, like the Kelty Noah's Tarp or even the Slumberjack one, would work well. They pack down pretty small and don't weigh much at all. The thing with an Ez-up Canopy is that they're large, bulky and heavy. So depending on your cargo layout it might take up a lot of space or you might have to load it up top. Another consideration is something like the Gazelle Tents Gazebo Room and I'd prefer that over a ez-up canopy.
Pop-Up Camping Hub Tents and Portable Gazebos - Gazelle Portable Gazebos for Outdoor Gatherings
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:51 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
a pop-up is a useful thing to have if you have somewhere to store it, i use mine all the time for tailgating or to setup a shaded work spot in the driveway or backyard.
i use it sometimes camping but it's big and bulky so that's really just been when camping with the wife and i'm already bringing enough gear to outfit a squad anyways
for beach days i do prefer a pop-up to a vehicle awning since it's easier to move to stay in the shade
i use a cheap kelty noah tarp (can't remember what size. 12' or 16') but am going to get an awning too. i will still use the tarp with the awning.
i used to have a slumberjack roadhouse screen tarp but it took longer to setup than a plain tarp so i sold it (i was otherwise satisfied with the quality)
jhguth is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 03:34 PM #10
Never heard of that Slumberjack. Looks like an interesting alternative to the roof rack awnings. Maybe even better?
Old 07-27-2020, 04:03 PM #11
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I was just having this dilemma, as monsoon season has started in Colorado. I like to camp an wheel a bit, so was very torn.
I ended up finding one of these Nemo Bugout 12x12 barely used for $80 with poles - going to try it out. It's huge but I think I can make some stuff work / use it as a hybrid awning, camp cover, etc.
I'll likely mount it too high to effectively use the bug mesh most of the time, as bugs aren't bad here. I like that it packs up to the size of a tent and is super light!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
awnings , canopy , cool , pop , put
FS: ARB 2000 awning, fortreks mounts, and awning screen room. $300 for all. Local pur 08runnertjb For Sale: Non-T4R Items 1 09-04-2019 01:37 AM
Yakima slim shady awning brackets for arb awning? Brimonahan 5th gen T4Rs 2 05-08-2019 01:19 AM
FS: ARB 2000 Awning + LabRak Awning Brackets - Richmond, Va cspicer For Sale: Non-T4R Items 12 09-25-2018 10:22 AM
Fs: Rago toyota 4runner canopy/ awning mounts for factory roof rail $80 shipped 209ers For Sale: T4R Items 0 06-22-2018 06:29 PM
