11-01-2019, 01:47 PM
#31
Originally Posted by raghu4026
Thank you!!! $50 for the aluminum, $15 to ship!
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
11-02-2019, 09:18 AM
#32
Does anyone have the dimensions of the stock rails? (Height of the rail, bottom to "slot", height of "slot", "slot" to top of rail) i'm toying with the idea of making cross bars for the stock rack using the info here as a guide, but find myself on the road for work.
Roof Rail Channel Dimensions
Hope it correct.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
11-08-2019, 01:48 PM
#33
Hope it correct.
If you are considering just crossbars, have you seen this thread?
DIY: Ultra Low Profile Custom Rack / Crossbars for OEM TE Roof Rails
That is what ended up doing, but may end up going in the direction of this post.
11-08-2019, 02:55 PM
#34
Originally Posted by nm_t4r
Yep, seen it.
05-03-2020, 04:38 PM
#35
My DIY rack
@ SuperfastMatt
inspired me to build a roof rack for my 4runner. I used the same materials as he did. I spent close to $500 since I had to buy everything online. Shipping costs add up quick! Here are some pics.
2019 4runner Limited, Blizzard Pearl, 3rd row seats, Factory cross bars and side steps
Mods - TRD Pro upper Grill conversion, XD HID low beams, Philips LED fogs, All LED interior, custom roof rack
05-03-2020, 05:24 PM
#36
I literally just watch this video yesterday. Great video and gives me lots of ideas.
One of my concerns is wind noise. What was the permanent fix for the wind noise?
05-03-2020, 05:41 PM
#37
If you build a full wind deflector like I did that hugs the roof line, you should be good.
05-03-2020, 09:43 PM
#38
really nice, even though I have no clue what I am looking for at the site you listed for the sides.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
05-03-2020, 11:23 PM
#39
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Nice work!
05-03-2020, 11:37 PM
#40
If you are talking about the side rails for the roof rack, look for 6061 Aluminum Flat Bar, 1/4" think, 2" wide, 8' long.
05-03-2020, 11:56 PM
#41
Originally Posted by momo.75
Nice work!
Thank you!
05-04-2020, 09:13 AM
#42
Do the stock rails not work for some reason? I would just need the inserts and the front wind dam.
The Build
05-04-2020, 09:14 AM
#43
@ SuperfastMatt
Can you post a link to the parts, I will need to get them all online also.
The Build
05-05-2020, 11:43 PM
#44
The stock rails only cover about half the roof length and are only rated for 165lbs I think. You cannot hook up the extruded aluminum bars to the stock rails
05-05-2020, 11:44 PM
#45
side rails and front wind deflector - Supplier of steel, stainless steel, aluminium and hardware products in Los Angeles, CA, USA | Bobco Metals
3003 Aluminum Sheet - 0.063
SKU: AL03SH.0634X8-custom-size
Width: 8 Inches X Length: 48 Inches Qty: 1
6061 Aluminum Flat Bars - 1/4 Inch X 2 Inch
SKU: AL61FB.250X2.00-custom-size - 8 Feet Qty 2
crossbars: TNUTZ | Your leader in T-Slotted Aluminum Hardware & Components
EX-1020-BLACK - 1" x 2" Smooth T-Slotted Aluminum Extrusion - Black Anodize
Length (in): 47, Quantity: 10
Others:
McMaster-Carr
McMaster-Carr
McMaster-Carr
https://www.mcmaster.com/#4869A71
https://www.mcmaster.com/#8982K61
https://www.mcmaster.com/#97763A267
https://www.mcmaster.com/#96765A140
https://www.mcmaster.com/#94407A104
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
