11-14-2019, 12:43 PM
#16
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
12-29-2020, 05:14 AM
#17
Just had the same problems and dealership quoted me $6000 for replacing the harness. Anyone know if its ok I have just the wires fixed at some independent shop? Any affect on my warranty? Only had the 4R for two weeks
12-29-2020, 05:32 AM
#18
Ouch! Have you contacted your insurance to see if they will help? A coworker had to deal with a rodent case on their Honda and the dealer quoted 4.5k. Insurance covered it thankfully
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
12-29-2020, 09:06 AM
#19
I’ve had squirrels do damage to my 72 240z so I filled old medicine bottles with cotton and peppermint and lavender oil punched holes in it hung the bottle on fishing string around the garage and under the hood and never had another problem
12-29-2020, 10:21 PM
#20
Honda makes a wiring tape that is designed for rodents. Order that and get to wrapping! It works....stuff even has a dead mouse symbol on it!
12-31-2020, 12:13 AM
#21
If you have comprehensive coverage on your auto policy that should cover the cost of the damage minus your deductible.
09-11-2021, 10:28 PM
#22
Peppermint spray
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
06-01-2024, 03:04 PM
#23
Originally Posted by 2112 R
^^ Yes for this solution.
I have also tried the soap technique. Found some paw prints in my engine bay and now every winter I take a bar of Irish Spring soap, cut it into strips, put them in a sock and zip tie it somewhere in the engine bay. If it's up high enough it won't get wet and generate suds, you just need that soapy Irish Spring smell in the engine bay somewhere and it drives them off.
I leave it there all year and then replace it when winter comes ... thanks for the reminder, I'll probably do it this weekend.
Been doin this for years in the house with the irish springer. Solid plan!
02 TCM 4R
F5's, Shrockworks metal, Addison built HID's, sonoran steel 3", acoustically insulated, power antenna delete, satoshi, wet Okele's
06-01-2024, 03:10 PM
#24
Get a code reader. Pays for itself with one use.
06-02-2024, 12:04 AM
#25
Real Name: Dave
Real Name: Dave
What's worked for me is an electronic under hood ultrasound device and dryer sheets. It helps to have feral cats as well. Had mouse damage under hood, as well as nesting in the cabin air filter, on my '18 SR5 and my '12 Subaru Outback. Now each have an ultrasound device and plenty of dryer sheets stuffed in convenient places. And I've not seen any evidence of mice in either for several months now.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
