Old 10-31-2019, 03:06 PM #16
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
Just spend an afternoon and run 8 or 10ga from the battery, with a circuit breaker, to a blue seas 12v outlet and ground it to the body. Total cost about $40.
Your fridge will run better and longer.
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 06:43 PM #17
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
You guys are missing out on a nice little mod. An OEM style fridge switch in your dash, fuse and relay under the hood, mount your 12v outlet in one of the trays in the back that pop out. Wire routing is pretty easy along the firewall, through the firewall on the passenger side. Kick plates pop straight up and your practically there.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 09:23 AM #18
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
in the years i've been running my fridge i've so far never had an occasion where i would want or need to switch off the fridge outlet
when are you switching off your fridge outlet?
jhguth is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 10:14 AM #19
elnip's Avatar
elnip elnip is offline
elnip is on a distinguished road
elnip's Avatar
My Engle has never had a problem running off of the rear 12V plug. I did some digging and it looks like the ARB can draw about 2x the amps over the Engle.
'16 T4R Trail P
JFR equal length Y-pipe, URD High Clearance 3" exhaust, Volant resonator, ICON
elnip is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 10:17 AM #20
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
Well, my dometic comes on and turns off when it sees/doesn't see power at the outlet I installed. So its nice to power it off when it sits during the week. The ability to control the fridge power from the drivers seat should be an easy sell...But that's me, what do you do? Pop your hatch and unplug your fridge or just use the power switch on the fridge itself?
Old 11-01-2019, 01:00 PM #21
Soneill's Avatar
Soneill Soneill is online now
Soneill will become famous soon enough
Soneill's Avatar
Originally Posted by borfoo3 View Post
The rear cigarette lighter is useless for anything more than a phone charger IMO. If you see those skinny wires running the vehicle's length, it wouldn't surprise you why it can't keep the fridge on
I had trouble running the ARB fridge on it. Installed another cigarette outlet right next to it with proper wiring and now runs the fridge perfectly for days
Same here my Snowmaster wouldn't stay running on the rear outlet so I just hard wired it.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is online now   Reply With QuoteReply With Quote
Old 11-01-2019, 11:05 PM #22
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
After a year and a half of using a Goal Zero Yeti to run the fridge and having the Yeti recharge off of the rear a/c outlet when driving I just bit the bullet and ran the ARB wiring kit from the battery (always on power source) to the back making a new outlet. Well worth it IMO.
Write up here...post #246
Cymon's Weekend Warrior and MFD Thread
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 11:58 PM #23
N6WRV N6WRV is offline
N6WRV is on a distinguished road
Right on! The ARB 10900027 ARB Fridge Freezer Wiring Kit and ARB Threaded Socket is the only way to go. A cigarette lighter plug in a cigarette lighter socket can vibrate loose.
The fused 10-gauge wire included in the kit is more than adequate to carry the current and an ARB Threaded Plug in an ARB Threaded Socket will never vibrate loose.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This ARB plug is a match for the ARB Threaded Socket.
ARB 10910076 Power Cord Cable for ARB Fridge Freezers DC 12V
https://www.amazon.com/ARB-10910076-...Z8VMATBD6JGE4J
Also be sure to tie down your fridge securely and safely with front and rear ratchet tie downs.
A cargo cover will keep the sun from heating up your fridge.
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
N6WRV is offline   Reply With QuoteReply With Quote
5th , fridge , gen , power , stock
Is there a USB cigarette lighter that truly does put out 2A? coconutpete Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-20-2013 11:44 AM
Cigarette lighter Billyjake Problems & Warranty Issues 1 11-19-2009 02:03 PM
Cigarette Lighter On an 03? mklttdv 4th Gen T4Rs 3 11-30-2008 08:24 PM
cigarette lighter? burton6509 3rd gen T4Rs 6 02-29-2008 08:08 PM
Cigarette lighter - ON? ohio4runner4x4 3rd gen T4Rs 2 09-16-2005 09:45 AM
